TA3AS Posted November 8, 2020 Posted November 8, 2020 Hi, I bought a Keenetic Giga 5 days ago. I have a Fritz'box 7390 at another city. I installed IPSEC package to my Keenetic Giga. I tried to configure it for creating a VPN connection to my Fritz!Box but no luck. I can connect my Fritz!box via Shrewsoft VPN client but my Keenetic Giga could not establish a connection. My fritz!boz have a static IP. Any help for the configuration of My Keenetic Giga will be appreciated. Best Regards, Quote
0 ndm Posted November 9, 2020 Posted November 9, 2020 On 11/8/2020 at 7:41 PM, TA3AS said: Any help for the configuration of My Keenetic Giga will be appreciated. You can address your question to the official tech support in your country. Have you tried? Did you read this: https://help.keenetic.com/hc/en-us/articles/360000422620-IPSec-VPN-site-to-site Quote
0 TA3AS Posted November 9, 2020 Author Posted November 9, 2020 (edited) Quote You can address your question to the official tech support in your country. Have you tried? Yes I did. I searched and found this forum. I think that I'm at wrong place. Quote Did you read this: https://help.keenetic.com/hc/en-us/articles/360000422620-IPSec-VPN-site-to-site Yes I read it before asking. But if you read this article you will see that it is for site-to-site VPN and Keenetic routers are at both sides. I have one Keentic and one Fritz!Box. I'm mentioning about "Remote Access VPN" Best Regards, Edited November 9, 2020 by TA3AS Quote
0 Le ecureuil Posted November 9, 2020 Posted November 9, 2020 @TA3AS ShrewSoft VPN Client is an obsolete software for many years, so we can't recommend it to be used at all. But if you really want, try to follow this brief: At first, install IPsec package on Keenetic, perform configuration and enable Virtual IP (XAuth) server on Applications page (don't forget about users and their passwords). Next steps should be performed at VPN Access Manager app. Press "Add". Go to "General" tab, fill in the field "Remote Host / Hostname or IP Address" with Keeentic WAN IP address or assigned domain name. Leave other fields on the tab and on the "Client" and "Name Resolution" tabs default. Go to "Authentication", and in combo "Authentication Method" choose "Mutual PSK + XAuth". On subtab "Local Identity" choose "Identification Type" - "IP Address", and make sure that the checkbox "Use a discovered local host address" is set. Go to "Phase 1", then select "Exchange Type" - "main"; "DH Exchange" - "group 2"; "Cipher Algorithm" - "aes"; "Cipher Key Length" - "128"; "Hash Algorithm" - "sha1". Go to "Phase 2", then select "Transform Algorithm" - "esp-aes"; "Transform Key Length" - "128"; "HMAC Algorithm" - "sha1", "PFS Exchange" - "disabled", "Compress Algorithm" - "disabled". Leave settings on "Policy" tab unmodified. Save, select the created connection and press "Connect". Login and password you must know from Virtual IP configuration stage. Here you are, message "tunnel enabled" will show you that everything works. Quote
0 Le ecureuil Posted November 9, 2020 Posted November 9, 2020 If you need to install site-to-site connection to FB, we must know your settings from FB side at first. Quote
0 TA3AS Posted November 10, 2020 Author Posted November 10, 2020 Hi @Le ecureuil Quote ShrewSoft VPN Client is an obsolete software for many years, so we can't recommend it to be used at all. But if you really want, try to follow this brief: Thank you very much for this great tutor. But my problem is different. I'm not trying to connect my Keenetic via VPN Client software such as Shrew Soft. I'm trying to connect my Fritz!Box from my Keenetic Giga. I want to create remote access VPN to my Fritz!Box. I did not configure my Keenetic for Remote Access VPN to my Fritz!Box. I need help to configure my Keenetic. I'm asking about Keenetic configuration. I'm attaching a screen capture about my Fritz!Box settings. Maybe it can be a clue. Thank you very much again for your understanding and great support. Quote
TA3AS
Hi,
Best Regards,
5 answers to this question
