r13 Posted November 26, 2020 Share Posted November 26, 2020 @vst Нужна помощь с объяснением поведения DHCP клиента Смотрю клиента на wisp интерфейсе(Ultra 2.16.D.8.0-2), время аренды 72 часа, но при этом у клиента идет какая-то ежечасная активность в которой периодически что-то идет не так и происходит сброс соединения сильно раньше полуаренды Что это за активность такая? Пример, в 3:20 что-то пошло не так: Скрытый текст [I] Nov 26 02:29:56 ndhcpc: WifiMaster0/WifiStation0: dispatch all, res: 0 [I] Nov 26 02:29:56 ndhcpc: WifiMaster0/WifiStation0: terminate: 0 [I] Nov 26 02:29:56 ndhcpc: WifiMaster0/WifiStation0: timer 130046.580707329, now 25647.280396649 [I] Nov 26 02:29:56 ndhcpc: WifiMaster0/WifiStation0: timeout 130046.580707329, now 25647.280560769 [I] Nov 26 02:29:56 ndhcpc: WifiMaster0/WifiStation0: set timeout 3600000 ms [I] Nov 26 02:29:56 ndhcpc: WifiMaster0/WifiStation0: set fd: 6, events: 0x39, revents: 0x0 [I] Nov 26 02:29:56 ndhcpc: WifiMaster0/WifiStation0: start poll: 1, 3600000, 0x7337c8 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: poll return error! [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: dispatch all, res: -1 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: signal callback: received signal: Terminated (15) [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: del socket 0x733050 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: add sock 6, flags: 0x2, handler: 0x40de8c, data: 0x733098 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: add socket 0x733050 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: terminate: 0 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: timer 130046.580707329, now 28672.333610439 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: timeout 130046.580707329, now 28672.333710493 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: set timeout 3600000 ms [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: set fd: 6, events: 0x3c, revents: 0x0 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: start poll: 1, 3600000, 0x7337c8 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: dispatch all, res: 1 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: terminate: 0 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: timer 130046.580707329, now 28672.336558236 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: disp fd: 6, events: 0x3c, revents: 0x4 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: socket write event [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: DHCP client state is RELEASING [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: sending RELEASE for 192.168.1.6 to 192.168.1.1 [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: starting client script with reason "leasefail" Quote Link to comment Share on other sites More sharing options...
slomblobov Posted November 27, 2020 Share Posted November 27, 2020 В селфтесте 3 рестарта DHCP, вызванные отправкой сигнала SIGTERM, первые два связаны с посылкой команды dhcp client debug. Цитата [I] Nov 25 19:28:08 ndm: Core::Scgi::Auth: opened session WUXTPMROXWEXFUDW for user ***. [I] Nov 25 19:28:31 ndm: Dhcp::Client: WifiMaster0/WifiStation0 DHCP client debug enabled. Цитата [I] Nov 25 19:29:33 ndm: Core::Authenticator: "admin" logged in, SSH authenticated. [I] Nov 25 19:29:44 ndhcpc: WifiMaster0/WifiStation0: signal callback: received signal: Terminated (15) [I] Nov 25 19:29:44 ndm: Dhcp::Client: WifiMaster0/WifiStation0 DHCP client debug enabled. Третий рестарт произошел по неизвестной причине: Цитата [I] Nov 26 03:20:21 ndhcpc: WifiMaster0/WifiStation0: signal callback: received signal: Terminated (15) [I] Nov 26 03:20:22 kernel: Wi-Fi client: probe request: SSID=momwifi, BSSID=00:13:33:81:0a:e9 [I] Nov 26 03:20:22 kernel: Wi-Fi client: probe response: SSID=momwifi, BSSID=00:13:33:81:0a:e9 Срабатывает какой-то триггер и ndm перезапускает DHCP. Это может быть связано с изменением линка, настроек устройства. Пока сделаю следующее: не перезапускать DHCP если состояние debug не изменилось. Quote Link to comment Share on other sites More sharing options...
r13 Posted November 27, 2020 Author Share Posted November 27, 2020 (edited) 11 минуту назад, vst сказал: В селфтесте 3 рестарта DHCP, вызванные отправкой сигнала SIGTERM, первые два связаны с посылкой команды dhcp client debug. Третий рестарт произошел по неизвестной причине: Срабатывает какой-то триггер и ndm перезапускает DHCP. Это может быть связано с изменением линка, настроек устройства. Пока сделаю следующее: не перезапускать DHCP если состояние debug не изменилось. Да этот в 3 часа как раз и не ясен, по логу вроде все чисто и тем не менее идут рестарты периодически Стстусы в телегу прилетают. Что то еще могу проверить со своей стороны? Может сам интерфейс тоже в debug перевести? Edited November 27, 2020 by r13 Quote Link to comment Share on other sites More sharing options...
slomblobov Posted November 29, 2020 Share Posted November 29, 2020 Давайте ещё несколько селфтестов посмотрим, может прояснится ситуация. Далее будем расширять отладку. Quote Link to comment Share on other sites More sharing options...
r13 Posted November 30, 2020 Author Share Posted November 30, 2020 8 часов назад, vst сказал: Давайте ещё несколько селфтестов посмотрим, может прояснится ситуация. Далее будем расширять отладку. Есть селфтест подревнее, еще без отладки dhcp клиета + pcap dhcp клиента События: Nov 24 15:49:13 Nov 25 02:23:49 Nov 25 06:06:24 Quote Link to comment Share on other sites More sharing options...
