Проблемы с установкой firebase через npm
Всем доброго времени суток!
Keenetic Extra  (прошивка 3.5.6) + свежеустановленная OPKG (node, node-red), zRam=128Mb, SWAP=1.5Gb
Не получается установить тяжелый пакет firebase, который в зависимостях у node-red-contribute-alice. Установка заканчивается сообщением "Killed..."
Первая попытка установки (чистый кэш npm):
~ # npm install firebase --loglevel verbose
npm info it worked if it ends with ok
npm verb cli [
npm verb cli   '/opt/bin/node',
npm verb cli   '/opt/bin/npm',
npm verb cli   'install',
npm verb cli   'firebase',
npm verb cli   '--loglevel',
npm verb cli   'verbose'
npm verb cli ]
npm info using npm@6.14.8
npm info using node@v12.19.0
npm verb config Skipping project config: /opt/root/.npmrc. (matches userconfig)
npm verb npm-session 9976124988c0445b
npm http fetch GET 200 https://registry.npmjs.org/firebase 5993ms
npm http fetch GET 200 https://registry.npmjs.org/firebase/-/firebase-8.2.10.tgz 11027ms
npm timing stage:loadCurrentTree Completed in 20354ms
npm timing stage:loadIdealTree:cloneCurrentTree Completed in 12ms
npm timing stage:loadIdealTree:loadShrinkwrap Completed in 46ms
npm http fetch GET 200 https://registry.npmjs.org/@firebase%2fpolyfill 139647ms
npm http fetch GET 200 https://registry.npmjs.org/@firebase%2fapp-types 141314ms
npm http fetch GET 200 https://registry.npmjs.org/@firebase%2fdatabase 141680ms
Killed
Следующая попытка установки (часть пакетов уже в кэше)
npm verb cli [
npm verb cli ]
npm verb npm-session 9890f2e7ef2b27d9
npm http fetch GET 304 https://registry.npmjs.org/firebase 7128ms (from cache)
npm timing stage:loadCurrentTree Completed in 10069ms
npm timing stage:loadIdealTree:cloneCurrentTree Completed in 16ms
npm timing stage:loadIdealTree:loadShrinkwrap Completed in 100ms
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fapp-types 38895ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fpolyfill 39563ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2finstallations 41016ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fauth 44061ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fapp 51715ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fmessaging 65407ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fstorage 82739ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2ffunctions 152923ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fdatabase 204696ms (from cache)
npm http fetch GET 200 https://registry.npmjs.org/@firebase%2fperformance 364032ms
npm http fetch GET 200 https://registry.npmjs.org/@firebase%2fremote-config 375082ms
npm http fetch GET 200 https://registry.npmjs.org/@firebase%2fanalytics 605445ms
Killed.............] - fetchMetadata: http fetch GET 200 https://registry.npmjs.org/@firebase%2fanalytics 605445ms
Всё идёт долго, загрузка процессора под 100%.
Такое впечатление, что система устает ждать и прибивает установщик. Когда не было zRam и свопа, убийством заканчивалась каждая попытка установки, как только кончалась память.
Прошу совета, как поправить ситуацию?
Обратил внимание, что время жизни установщика похоже на +/- 600 секунд
npm verb cli [
npm verb cli ]
npm verb npm-session 4bc5766c790c8eb2
npm http fetch GET 304 https://registry.npmjs.org/firebase 7928ms (from cache)
npm timing stage:loadCurrentTree Completed in 11144ms
npm timing stage:loadIdealTree:cloneCurrentTree Completed in 7ms
npm timing stage:loadIdealTree:loadShrinkwrap Completed in 47ms
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fapp-types 37767ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fpolyfill 39222ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2finstallations 41434ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fauth 43400ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fapp 52208ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fstorage 56149ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fmessaging 65055ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2ffunctions 66929ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fdatabase 111458ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2ffirestore 176383ms (from cache)
npm http fetch GET 200 https://registry.npmjs.org/@firebase/functions/-/functions-0.6.2.tgz 88600ms attempt #2
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fremote-config 215150ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fanalytics 226180ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fperformance 326621ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2futil 419104ms (from cache)
npm timing stage:rollbackFailedOptional Completed in 3302ms
npm timing stage:runTopLevelLifecycles Completed in 595012ms
npm verb type system
npm verb stack FetchError: request to https://registry.npmjs.org/@firebase/database/-/database-0.9.4.tgz failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
npm verb stack     at ClientRequest.<anonymous> (/opt/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)
npm verb stack     at ClientRequest.emit (events.js:314:20)
npm verb stack     at TLSSocket.socketErrorListener (_http_client.js:428:9)
npm verb stack     at TLSSocket.emit (events.js:314:20)
npm verb stack     at emitErrorNT (internal/streams/destroy.js:92:8)
npm verb stack     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
npm verb stack     at processTicksAndRejections (internal/process/task_queues.js:84:21)
npm verb cwd /opt/root
npm verb Linux 4.9-ndm-4
npm verb argv "/opt/bin/node" "/opt/bin/npm" "install" "firebase" "--loglevel" "verbose"
npm verb node v12.19.0
npm verb npm  v6.14.8
npm ERR! code EAI_AGAIN
npm ERR! errno EAI_AGAIN
npm ERR! request to https://registry.npmjs.org/@firebase/database/-/database-0.9.4.tgz failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
npm verb exit [ 1, true ]
npm timing npm Completed in 618657ms
npm ERR! A complete log of this run can be found in:
npm ERR!     /opt/root/.npm/_logs/2021-03-09T19_32_42_540Z-debug.log
npm verb cli [
npm verb cli ]
npm verb npm-session c7e563664dbb5eca
npm http fetch GET 304 https://registry.npmjs.org/firebase 7219ms (from cache)
npm timing stage:loadCurrentTree Completed in 10176ms
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fapp-types 36301ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fpolyfill 37559ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2finstallations 39055ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fauth 43809ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fapp 48260ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fstorage 51680ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fmessaging 57454ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2ffunctions 61233ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fdatabase 99435ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2ffirestore 151074ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fremote-config 171764ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fanalytics 181501ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2fperformance 276528ms (from cache)
npm http fetch GET 304 https://registry.npmjs.org/@firebase%2futil 326343ms (from cache)
npm timing stage:rollbackFailedOptional Completed in 12543ms
npm timing stage:runTopLevelLifecycles Completed in 538157ms
npm timing npm Completed in 619629ms
npm ERR!     /opt/root/.npm/_logs/2021-03-09T19_43_52_969Z-debug.log
Проблема решилась после отключения ZRAM (swap остался, без него не хватает памяти).
Загрузка процессора снизилась с постоянных 100% до плавающих 10-100%, видимо, какие-то вачдоги/таймеры стали успевать перевзводиться, и убийства прекратились. Ставилось минут 15.
Для node-red важна его личная папка node_modules. Установка в /opt/root/.node-red/ (командой npm install без доп. ключей) не помогает - red не видит плагина. Установка из-под gui node-red прошла успешно, плагин сразу обнаружился. Устанавливать глобально (-g) не пробовал.
