Meccep45 Posted July 5, 2021 Share Posted July 5, 2021 Стесняюсь спросить, а по Simple Machines Forum нет описания настройки nginx+php-fpm+mariadb? Quote Link to comment Share on other sites More sharing options...
Meccep45 Posted July 12, 2021 Author Share Posted July 12, 2021 Скрытый текст user nobody; worker_processes 1; error_log /opt/var/log/nginx/error.log; pid /opt/var/run/nginx.pid; events { worker_connections 1024; } http { include mime.types; default_type application/octet-stream; access_log /opt/var/log/nginx/access.log; client_body_buffer_size 1K; client_max_body_size 6M; client_header_buffer_size 1k; large_client_header_buffers 2 1k; sendfile on; server_tokens off; client_body_timeout 10; client_header_timeout 10; keepalive_timeout 65; send_timeout 10; gzip on; ### перенаправить ip в domen server { listen 80; #listen [::]:80; server_name 000.00.00.000; return 301 https://domen name$request_uri; } ### закрыть доступ к ip server { listen 446 ssl http2; #listen [::]:446 ssl http2; server_name _; include ssl.conf; return 444; } ### окрыть доступ в domen server { listen 446 ssl http2; #listen [::]:446 ssl http2; server_name domen name; root /opt/share/nginx/html; index index.php index.html index.htm; include ssl.conf; resolver 1.1.1.1 1.0.0.1; charset utf-8; ### для ошибок location ~ /errors { internal; } ### ошибки error_page 403 /errors/403.html; error_page 404 /errors/404.html; error_page 500 502 503 504 /errors/50x.html; ### когда нет папки или файла отдать 404 location / { try_files $uri $uri/ =404; } ### отдать средствами сервера location ~* \.(js|css|gdf|ttf|ico|svg)$ { log_not_found off; access_log off; } ### когда нет файла отдать 404 location ~ \.php$ { try_files $uri =404; fastcgi_index index.php; fastcgi_pass unix:/opt/var/run/php8-fpm/php8-fpm.sock; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; include fastcgi_params; } ### досту всем для сертификации location ~ /\.well-known { try_files $uri =404; allow all; } ### защитить скрытые файлы location ~ /\. { return 403; deny all; allow 192.168.1.0/24; } } } сделал вот такой конфиг. скорее не правильный. но как мог. всё когда то начинается. буду счастлив любым подсказкам. Quote Link to comment Share on other sites More sharing options...
