Le ecureuil Posted August 17, 2016 Share Posted August 17, 2016 54 минуты назад, vlad сказал: настроил как описано,выдает такую ошибку. 07[IKE] received NAT-T (RFC 3947) vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID Aug 17 12:29:09ipsec 07[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID Aug 17 12:29:09ipsec 07[IKE] received XAuth vendor ID Aug 17 12:29:09ipsec 07[IKE] received Cisco Unity vendor ID Aug 17 12:29:09ipsec 07[IKE] received FRAGMENTATION vendor ID Aug 17 12:29:09ipsec 07[IKE] received DPD vendor ID Aug 17 12:29:09ipsec 07[IKE] 192.168.1.82 is initiating a Main Mode IKE_SA Aug 17 12:29:09ipsec 07[CFG] received proposals: IKE:AES_CBC=256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_2048/#, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048/#, IKE:AES_CBC=256/HMAC_MD5_96/PRF_HMAC_MD5/MODP_2048/#, IKE:AES_CBC=256/HMAC_SHA2_512_256/PRF_HMAC_SHA2_512/MODP_2048/#, IKE:AES_CBC=256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_1536/#, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536/#, IKE:AES_CBC=256/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1536/#, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:AES_CBC=256/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024/#, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:AES_CBC=128/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024/#, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:3DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024/#, IKE:DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024/# Aug 17 12:29:09ipsec 07[CFG] configured proposals: IKE:AES_CBC=128/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768/# Aug 17 12:29:09ipsec 07[IKE] no proposal found Включите в DH-группе в Фазе 1 IKE галки в полях 2 и 3 (modp1024 и modp1536). Quote Link to comment Share on other sites More sharing options...
vlad Posted August 17, 2016 Share Posted August 17, 2016 настроил по новой,теперь вот такие ошибки Aug 17 14:57:47ipsec 06[IKE] received NAT-T (RFC 3947) vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID Aug 17 14:57:47ipsec 06[IKE] received XAuth vendor ID Aug 17 14:57:47ipsec 06[IKE] received Cisco Unity vendor ID Aug 17 14:57:47ipsec 06[IKE] received FRAGMENTATION vendor ID Aug 17 14:57:47ipsec 06[IKE] received DPD vendor ID Aug 17 14:57:47ipsec 06[IKE] 192.168.1.82 is initiating a Main Mode IKE_SA Aug 17 14:57:47ipsec 07[IKE] linked key for crypto map '(unnamed)' is not found, still searching Aug 17 14:57:57ipsec 04[IKE] received NAT-T (RFC 3947) vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID Aug 17 14:57:57ipsec 04[IKE] received XAuth vendor ID Aug 17 14:57:57ipsec 04[IKE] received Cisco Unity vendor ID Aug 17 14:57:57ipsec 04[IKE] received FRAGMENTATION vendor ID Aug 17 14:57:57ipsec 04[IKE] received DPD vendor ID Aug 17 14:57:57ipsec 04[IKE] 192.168.1.82 is initiating a Main Mode IKE_SA Aug 17 14:57:57ipsec 08[IKE] linked key for crypto map '(unnamed)' is not found, still searching Aug 17 14:57:58ipsec 12[CFG] looking for XAuthInitPSK peer configs matching ........192.168.1.82[192.168.1.82] Aug 17 14:57:58ipsec 12[CFG] selected peer config "vpn" Aug 17 14:57:58ipsec 11[IKE] message parsing failed Aug 17 14:57:58ipsec 11[IKE] ignore malformed INFORMATIONAL request Aug 17 14:57:58ipsec 11[IKE] INFORMATIONAL_V1 request with message ID 3616003100 processing failed Aug 17 14:57:58ndm IpSec::Configurator: IKE message parsing error for IPsec crypto map "vpn". Aug 17 14:57:58ndm IpSec::Configurator: (possibly because of wrong pre-shared key). Aug 17 14:58:06ipsec 10[IKE] sending retransmit 1 of request message ID 915551114, seq 1 Quote Link to comment Share on other sites More sharing options...
vlad Posted August 17, 2016 Share Posted August 17, 2016 Есть инструкция по настройки ipSec и iphone? Просьба помочь в настройке..! Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 17, 2016 Share Posted August 17, 2016 1 час назад, vlad сказал: настроил по новой,теперь вот такие ошибки Aug 17 14:57:47ipsec 06[IKE] received NAT-T (RFC 3947) vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID Aug 17 14:57:47ipsec 06[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID Aug 17 14:57:47ipsec 06[IKE] received XAuth vendor ID Aug 17 14:57:47ipsec 06[IKE] received Cisco Unity vendor ID Aug 17 14:57:47ipsec 06[IKE] received FRAGMENTATION vendor ID Aug 17 14:57:47ipsec 06[IKE] received DPD vendor ID Aug 17 14:57:47ipsec 06[IKE] 192.168.1.82 is initiating a Main Mode IKE_SA Aug 17 14:57:47ipsec 07[IKE] linked key for crypto map '(unnamed)' is not found, still searching Aug 17 14:57:57ipsec 04[IKE] received NAT-T (RFC 3947) vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID Aug 17 14:57:57ipsec 04[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID Aug 17 14:57:57ipsec 04[IKE] received XAuth vendor ID Aug 17 14:57:57ipsec 04[IKE] received Cisco Unity vendor ID Aug 17 14:57:57ipsec 04[IKE] received FRAGMENTATION vendor ID Aug 17 14:57:57ipsec 04[IKE] received DPD vendor ID Aug 17 14:57:57ipsec 04[IKE] 192.168.1.82 is initiating a Main Mode IKE_SA Aug 17 14:57:57ipsec 08[IKE] linked key for crypto map '(unnamed)' is not found, still searching Aug 17 14:57:58ipsec 12[CFG] looking for XAuthInitPSK peer configs matching ........192.168.1.82[192.168.1.82] Aug 17 14:57:58ipsec 12[CFG] selected peer config "vpn" Aug 17 14:57:58ipsec 11[IKE] message parsing failed Aug 17 14:57:58ipsec 11[IKE] ignore malformed INFORMATIONAL request Aug 17 14:57:58ipsec 11[IKE] INFORMATIONAL_V1 request with message ID 3616003100 processing failed Aug 17 14:57:58ndm IpSec::Configurator: IKE message parsing error for IPsec crypto map "vpn". Aug 17 14:57:58ndm IpSec::Configurator: (possibly because of wrong pre-shared key). Aug 17 14:58:06ipsec 10[IKE] sending retransmit 1 of request message ID 915551114, seq 1 Необходим self-test после подключения и подробное описание клиента с версией ПО, которым вы пытаетесь подключиться, а также его настройками. Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 17, 2016 Share Posted August 17, 2016 1 час назад, vlad сказал: Есть инструкция по настройки ipSec и iphone? Просьба помочь в настройке..! Вам для чего нужно - для выхода в Интернет через Keenetic, или для доступа в локальную сеть за ним? Quote Link to comment Share on other sites More sharing options...
vlad Posted August 17, 2016 Share Posted August 17, 2016 4 минуты назад, Le ecureuil сказал: Вам для чего нужно - для выхода в Интернет через Keenetic, или для доступа в локальную сеть за ним? Для выхода в интернет через кинетик. Quote Link to comment Share on other sites More sharing options...
pachalia Posted August 20, 2016 Share Posted August 20, 2016 В 17.08.2016 в 12:32, vlad сказал: - Добавьте пользователя с тегом IPsec Xauth, и используйте именно эти учетные данные в клиенте. А как добавить пользователя? Quote Link to comment Share on other sites More sharing options...
KorDen Posted August 20, 2016 Share Posted August 20, 2016 41 минуту назад, pachalia сказал: А как добавить пользователя? Система -> Пользователи Quote Link to comment Share on other sites More sharing options...
vlad Posted August 20, 2016 Share Posted August 20, 2016 У кого нибудь получилось настроить на работу с iOS? Если да, то опишите как это делали! Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 20, 2016 Share Posted August 20, 2016 1 час назад, vlad сказал: У кого нибудь получилось настроить на работу с iOS? Если да, то опишите как это делали! У меня нет на руках эппловских девайсов, но на днях добавлю описание. Quote Link to comment Share on other sites More sharing options...
vlad Posted August 20, 2016 Share Posted August 20, 2016 57 минут назад, Le ecureuil сказал: У меня нет на руках эппловских девайсов, но на днях добавлю описание. Спасибо вам добрый человек ;)! Quote Link to comment Share on other sites More sharing options...
JIABP Posted August 21, 2016 Share Posted August 21, 2016 В 20.08.2016 в 13:25, Le ecureuil сказал: У меня нет на руках эппловских девайсов, но на днях добавлю описание. То же только что поставил 2.08, и именно из-за возможности настройки IPSec на iOS. Будем подождать = ) Quote Link to comment Share on other sites More sharing options...
JIABP Posted August 21, 2016 Share Posted August 21, 2016 (edited) Вдруг пригодится. Скрытый текст Edited August 21, 2016 by JIABP 2 Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 21, 2016 Share Posted August 21, 2016 Вот это хорошие скриншоты, респект. По ним и напишем. Когда проверял на iPad друга забыл заскринить 1 Quote Link to comment Share on other sites More sharing options...
JIABP Posted August 21, 2016 Share Posted August 21, 2016 12 часа назад, Le ecureuil сказал: Вот это хорошие скриншоты, респект. По ним и напишем. Когда проверял на iPad друга забыл заскринить [emoji4] Если будет ещё что-то нужно - пишите, я могу даже куда нибудь к Вам подключиться (хотя могу и у себя настроить) - что бы ускорить процесс написания мануала. В целом - готов в этом вопросе помогать. Что бы добраться до VPN, нужно "Настройки"> "Основные"-> "VPN" У меня, правда, там куча всего, в то время как у остальных людей там зачастую пусто. Скрины сняты с iPhone 5S, iOS 8.4 Скрытый текст 1 Quote Link to comment Share on other sites More sharing options...
KorDen Posted August 21, 2016 Share Posted August 21, 2016 На 9.3.3 / 9.3.4 немножко по-другому (у самого яблочной техники нет, прошелся по знакомым..) Скрытый текст 3 Quote Link to comment Share on other sites More sharing options...
vlad Posted August 21, 2016 Share Posted August 21, 2016 Добавлю свои скрины. iOS 10 iPhone 5S Скрытый текст 2 Quote Link to comment Share on other sites More sharing options...
JIABP Posted August 24, 2016 Share Posted August 24, 2016 (edited) В 20.08.2016 в 13:25, Le ecureuil сказал: У меня нет на руках эппловских девайсов, но на днях добавлю описание. Описание ещё не готово? Хотя бы драфт, не обязательно на zyxel.ru/kb - я бы и тут потестил. Edited August 24, 2016 by JIABP 1 Quote Link to comment Share on other sites More sharing options...
_hydra_ Posted August 24, 2016 Share Posted August 24, 2016 3 часа назад, JIABP сказал: Описание ещё не готово? Хотя бы драфт, не обязательно на zyxel.ru/kb - я бы и тут потестил. на предыдущей странице есть описание настроек для virtual ip Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 24, 2016 Share Posted August 24, 2016 В прошлые билды затесался небольшой досадный баг, который не дает пока использовать эту настройку. В эту пятницу выйдет новая 2.08, и для нее уже сразу будет опубликовано описание. 3 Quote Link to comment Share on other sites More sharing options...
JIABP Posted August 24, 2016 Share Posted August 24, 2016 35 минут назад, Le ecureuil сказал: В прошлые билды затесался небольшой досадный баг, который не дает пока использовать эту настройку. В эту пятницу выйдет новая 2.08, и для нее уже сразу будет опубликовано описание. Круто, теперь вдвойне жду пятницу. Кстати, Shrew VPN Client на одной из моих виндовых машинок не ставится ни в какую. Какой ещё можно клиент для этого использовать? Quote Link to comment Share on other sites More sharing options...
KorDen Posted August 24, 2016 Share Posted August 24, 2016 3 часа назад, JIABP сказал: Кстати, Shrew VPN Client на одной из моих виндовых машинок не ставится ни в какую. Какой ещё можно клиент для этого использовать? А я вот пытаюсь понять, вроде же как в винде есть штатная поддержка IPsec через правила фаервола.. Но попытка настроить пока приводит к "no IKE config found for a.a.a.a...b.b.b.b, sending NO_PROPOSAL_CHOSEN", хотя на кинетике указаны все возможные методы согласования в обоих фазах.. Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 24, 2016 Share Posted August 24, 2016 3 часа назад, KorDen сказал: А я вот пытаюсь понять, вроде же как в винде есть штатная поддержка IPsec через правила фаервола.. Но попытка настроить пока приводит к "no IKE config found for a.a.a.a...b.b.b.b, sending NO_PROPOSAL_CHOSEN", хотя на кинетике указаны все возможные методы согласования в обоих фазах.. Это в кинетике такой лог? Тогда нужно в нем прописать в качестве ID обоих сторон IP-адреса (то есть выбрать тип Address) и строго их задать в виде a.a.a.a для одной, b.b.b.b для другой стороны. Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 24, 2016 Share Posted August 24, 2016 6 часов назад, JIABP сказал: Круто, теперь вдвойне жду пятницу. Кстати, Shrew VPN Client на одной из моих виндовых машинок не ставится ни в какую. Какой ещё можно клиент для этого использовать? С виндой вообще все отвратно, думал что Cisco VPN Client подойдет, но у него свои косяки (хотя попробую еще разок к снаряду подступиться). 1 Quote Link to comment Share on other sites More sharing options...
JIABP Posted August 25, 2016 Share Posted August 25, 2016 С виндой вообще все отвратно, думал что Cisco VPN Client подойдет, но у него свои косяки (хотя попробую еще разок к снаряду подступиться). Грусть) А то этот шрю впн даже на чистой виртуалке (там только каспер и браузер амиго были установлены) не завелся. Пришлось откатываться на снапшот где вообще ничего не установлено - и он поставился без ошибок. Наверно, с каспером несовместимость. Отправлено с моего iPhone используя Tapatalk Quote Link to comment Share on other sites More sharing options...
KorDen Posted August 25, 2016 Share Posted August 25, 2016 10 часов назад, Le ecureuil сказал: Это в кинетике такой лог? Тогда нужно в нем прописать в качестве ID обоих сторон IP-адреса (то есть выбрать тип Address) и строго их задать в виде a.a.a.a для одной, b.b.b.b для другой стороны. Да, IP настоящие там, это я "замазал" Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted August 25, 2016 Share Posted August 25, 2016 Радостные новости, удалось завести и Cisco VPN тоже. Все мануалы будут написаны в пятницу в отдельных темах для OS X/iOS, Android и Windows, на пятничной же сборке будете пробовать и сообщать об ошибках. 3 Quote Link to comment Share on other sites More sharing options...
JIABP Posted August 25, 2016 Share Posted August 25, 2016 (edited) 3 минуты назад, Le ecureuil сказал: Радостные новости Goog news everyone (c) Спасибо, жду с нетерпением! А доступ к интернету будет? Или только к локальной сети? Edited August 25, 2016 by JIABP 1 Quote Link to comment Share on other sites More sharing options...
r13 Posted August 25, 2016 Share Posted August 25, 2016 @Le ecureuil А как насчет давнего предложения @ndm увеличить число активных карт (сейчас 2) на топовых железках в отладочной версии? 1 Quote Link to comment Share on other sites More sharing options...
KorDen Posted August 25, 2016 Share Posted August 25, 2016 6 часов назад, JIABP сказал: А доступ к интернету будет? Или только к локальной сети Как я понимаю, доступ к интернету будет, когда запилят IPIP/EoIP-туннели, т.е. позже... Quote Link to comment Share on other sites More sharing options...
