rustrict Posted October 30, 2021 Share Posted October 30, 2021 В 3.7 Beta 4 встроенная ping6 постоянно отдает 100% packet loss на любой хост. (config)> tools ping6 fast.com count 5 sending ICMPv6 ECHO request to fast.com... PING fast.com (2a02:26f0:e2:59e::24fe) 56 (104) bytes of data. --- fast.com ping statistics --- 5 packets transmitted, 0 packets received, 100% packet loss, 0 duplicate(s), time 5002.81 ms. (config)> tools ping6 sprint.net count 5 sending ICMPv6 ECHO request to sprint.net... PING sprint.net (2600::) 56 (104) bytes of data. --- sprint.net ping statistics --- 5 packets transmitted, 0 packets received, 100% packet loss, 0 duplicate(s), time 5001.96 ms. В дампе при этом все ок: echo reply на месте. ping6 из busybox в Entware работает нормально. P. S. Между Beta 3 и Beta 4 изменился хэш /usr/sbin/ping. Так и должно быть? ~ # ndmc -c "sh ver" | grep release release: 3.07.B.3.0-0 ~ # md5sum /usr/sbin/ping 55a0085a80c246b44b508381d61fc97d /usr/sbin/ping ~ # ndmc -c "sh ver" | grep release release: 3.07.B.4.0-1 ~ # md5sum /usr/sbin/ping 311350af079d6bcc72d02cf2fcc736f1 /usr/sbin/ping 1 Link to comment Share on other sites More sharing options...
0 rustrict Posted November 8, 2021 Author Share Posted November 8, 2021 В 3.7 Beta 5 без изменений: 100-процентные потери. 1 1 Link to comment Share on other sites More sharing options...
0 vst Posted November 8, 2021 Share Posted November 8, 2021 (config)> sh ver release: 3.07.B.3.0-0 sandbox: draft title: 3.7 Beta 3 arch: mips hw_id: ku_rd (config)> tools ping6 fast.com count 5 sending ICMPv6 ECHO request to fast.com... PING fast.com (2a02:26f0:e2:785::24fe) 56 (104) bytes of data. 64 bytes from fast.com (2a02:26f0:e2:785::24fe): icmp_req=1, ttl=56, time=44.63 ms. 64 bytes from fast.com (2a02:26f0:e2:785::24fe): icmp_req=2, ttl=56, time=44.90 ms. 64 bytes from fast.com (2a02:26f0:e2:785::24fe): icmp_req=3, ttl=56, time=43.27 ms. 64 bytes from fast.com (2a02:26f0:e2:785::24fe): icmp_req=4, ttl=56, time=42.97 ms. 64 bytes from fast.com (2a02:26f0:e2:785::24fe): icmp_req=5, ttl=56, time=43.00 ms. --- fast.com ping statistics --- 5 packets transmitted, 5 packets received, 0% packet loss, 0 duplicate(s), time 4044.87 ms. Round-trip min/avg/max = 42.97/43.75/44.90 ms. (config)> tools ping6 sprint.net count 5 sending ICMPv6 ECHO request to sprint.net... PING sprint.net (2600::) 56 (104) bytes of data. 64 bytes from sprint.net (2600::): icmp_req=1, ttl=51, time=138.08 ms. 64 bytes from sprint.net (2600::): icmp_req=2, ttl=51, time=144.48 ms. 64 bytes from sprint.net (2600::): icmp_req=3, ttl=51, time=138.08 ms. 64 bytes from sprint.net (2600::): icmp_req=4, ttl=51, time=143.47 ms. 64 bytes from sprint.net (2600::): icmp_req=5, ttl=51, time=147.13 ms. --- sprint.net ping statistics --- 5 packets transmitted, 5 packets received, 0% packet loss, 0 duplicate(s), time 4149.71 ms. Round-trip min/avg/max = 138.08/142.24/147.13 ms. Не получилось воспроизвести. Подключение 6in4 ipv4market. Link to comment Share on other sites More sharing options...
0 rustrict Posted November 8, 2021 Author Share Posted November 8, 2021 6 минут назад, vst сказал: Не получилось воспроизвести. 7 минут назад, vst сказал: title: 3.7 Beta 3 Вы воспроизводили на 3.7 Beta 3, где все ок. Проблема началась с Beta 4. Link to comment Share on other sites More sharing options...
0 vst Posted November 8, 2021 Share Posted November 8, 2021 Да, вы правы. Разбираюсь... Link to comment Share on other sites More sharing options...
0 Dim McAlastair Posted November 9, 2021 Share Posted November 9, 2021 (edited) Подтверждаю: пропинговать google.com по IPv6 невозможно в Keenetic OS 3.7b4, 3.7b5 и 3.6.12 из канала delta (по поводу релизной версии 3.6.12 ничего сказать не могу). Upd.: Уточнение: в консоли на Версии дельта 3.6.12 пропинговать google.com по IPv6 получилось, а в веб-интерфейсе не вышло дважды. Но на 3.7b5 команда tools ping6 google.com count 5 выдаёт ответ: sending ICMPv6 ECHO request to google.com... PING google.com (2a00:1450:4010:c07::65) 56 (104) bytes of data. --- google.com ping statistics --- 5 packets transmitted, 0 packets received, 100% packet loss, 0 duplicate(s), time 5002.74 ms. Edited November 9, 2021 by Dim McAlastair Link to comment Share on other sites More sharing options...
0 rustrict Posted November 14, 2021 Author Share Posted November 14, 2021 Исправлено в 3.7 Beta 6. Спасибо! 1 Link to comment Share on other sites More sharing options...
rustrict
6 answers to this question
