Дмитрий Сысоев Posted February 11, 2022 Share Posted February 11, 2022 Уважаемыу гуру! подскажите. пожалуйста, что можно сделать для подключения кинетика с sstp серверу? с windows клиента подключается без проблем, хотелось бы настроить и на уровне роутера логи следующие коннекта: [I] Feb 11 12:49:58 ndm: Network::Interface::Base: "SSTP0": interface is up. [I] Feb 11 12:49:58 ndm: Network::Interface::PppTunnel: "SSTP0": remote endpoint is resolved to "xxxxx". [I] Feb 11 12:49:58 ndm: Network::Interface::PppTunnel: "SSTP0": connecting via CdcEthernet0 (CdcEthernet0). [I] Feb 11 12:49:58 ndm: Network::Interface::PppTunnel: "SSTP0": local endpoint is resolved to "192.168.8.140". [I] Feb 11 12:49:58 ndm: Network::Interface::PppTunnel: "SSTP0": added host route to xxxxxx via 192.168.8.1 (CdcEthernet0). [I] Feb 11 12:49:58 ndm: Network::Interface::Ppp: "SSTP0": enabled connection via any interface. [I] Feb 11 12:50:00 pppd[1231]: Plugin sstp-pppd-plugin.so loaded. [I] Feb 11 12:50:00 pppd[1231]: pppd 2.4.4-4 started by root, uid 0 [I] Feb 11 12:50:00 pppd[1231]: Using interface ppp0 [I] Feb 11 12:50:00 pppd[1231]: Connect: ppp0 <--> /dev/pts/0 [I] Feb 11 12:50:00 sstpc_SSTP0[1232]: Error: Expected HTTP code 200 [I] Feb 11 12:50:00 sstpc_SSTP0[1232]: HTTP handshake with server failed [I] Feb 11 12:50:00 pppd[1231]: Modem hangup [I] Feb 11 12:50:00 ndm: Network::Interface::PppTunnel: "SSTP0": added host route to xxxxx via 192.168.8.1 (CdcEthernet0). [E] Feb 11 12:50:00 pppd[1231]: Could not connect to sstp-client (/var/run/sstpc-SSTP0), Connection refused (146) [I] Feb 11 12:50:00 pppd[1231]: Exit. [E] Feb 11 12:50:00 ndm: Service: "SSTP0": unexpectedly stopped. Как понять что именно не нравится кинетику? понимаю, что загвоздка тут Expected HTTP code 200 но что именно приходит ? как это продебажить? Quote Link to comment Share on other sites More sharing options...
