38B1 на втором роутере не работает KeenDNS
vasek00
При схеме
KN1810(LAN)------(LAN)Keenetic-------Инет
KN1810 интернет-центр работает в режиме "Роутер" до обновления на 38B1 изумительно работал с KeenDNS ( ххххххх.keenetic.pro) и так же обновлялся без проблем. Настройки для этого Keenetic 192.168.1.10, KN1810 192.168.1.9
KN1810 38A4
interface Bridge0
    rename Home
    description "Home Lan"
    inherit GigabitEthernet0/Vlan1
    include AccessPoint
    include AccessPoint_5G
ip route default 192.168.1.10 Home !Default
ip name-server 192.168.130.10 "" on Home
[I] Apr 23 09:44:25 ndm: Acme::Client: obtained default domain: "4......5.keenetic.io".
[I] Apr 23 09:44:25 ndm: Dns::Manager: added static record for "4......5.keenetic.io", address 78.47.125.180.
[I] Apr 23 09:44:25 ndm: Http::Nginx: loaded SSL certificate for "4....5.keenetic.io".
[I] Apr 23 09:44:25 ndm: Http::Nginx: loaded SSL certificate for "хххххх.keenetic.pro".
[I] Apr 23 09:48:16 ndm: Dns::Manager: added static record for "ххххххх.keenetic.pro", address 78.47.125.180.
[I] Apr 23 09:48:17 ndm: Http::Nginx: loaded SSL certificate for "4....5.keenetic.io".
[I] Apr 23 09:48:17 ndm: Http::Nginx: loaded SSL certificate for "хххххх.keenetic.pro".
[I] Apr 23 09:49:16 ndm: Ndns::Client: updated a booked name.
[I] Apr 23 09:49:20 ndm: Ndns::Client: updated a booked name.
    <file name="temp:ndnproxymain.conf">
        <![CDATA[
rpc_port = 54321
rpc_ttl = 10000
rpc_wait = 10000
timeout = 7000
proceed = 500
stat_file = /var/ndnproxymain.stat
stat_time = 10000
dns_server = 192.168.1.10 .
static_a = my.keenetic.net 78.47.125.180
static_a = 4....5.keenetic.io 78.47.125.180
static_a = хххххх.keenetic.pro 78.47.125.180
norebind_ctl = on
norebind_ip4net = 192.168.1.9:24
norebind_ip4net = 255.255.255.255:32
set-profile-ip 127.0.0.1 0
set-profile-ip ::1 0
dns_tcp_port = 53
dns_udp_port = 53
    <file name="temp:ndnproxymain.stat">
        <![CDATA[
# ndnproxy statistics file
Total incoming requests: 10
Proxy requests sent:     10
Cache hits ratio:        0.000 (0)
Memory usage:            5.61K
DNS Servers
                      Ip   Port  R.Sent  A.Rcvd  NX.Rcvd  Med.Resp  Avg.Resp  Rank
            192.168.1.10     53      10      10        0       2ms       2ms     4
При переходе на 38B1 перестает работать, возврат на ранее сохраненную и все работает, опять на 38B1 и не работает.
38B1
        <![CDATA[
rpc_port = 54321
rpc_ttl = 10000
rpc_wait = 10000
timeout = 7000
proceed = 500
stat_time = 10000
norebind_ctl = on
dns_tcp_port = 53
dns_udp_port = 53
    </file>
    <error>file not found: temp:ndnproxysafe.conf</error>
        <![CDATA[
Total incoming requests: 0
Proxy requests sent:     0
Memory usage:            4.61K
DNS Servers
            192.168.1.10     53       0       0        0       0ms       0ms     1
~ # nslookup mail.ru
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost
Address 1: 217.69.139.200 mail.ru
Address 2: 217.69.139.202 mail.ru
Address 3: 94.100.180.201 mail.ru
Address 4: 94.100.180.200 mail.ru
Address 5: 2a00:1148:db00:0:b0b0::1 mail.ru
~ # ping ndss.keenetic.ndmsystems.com
PING ndss.keenetic.ndmsystems.com (92.63.195.7): 56 data bytes
64 bytes from 92.63.195.7: seq=0 ttl=54 time=26.320 ms
64 bytes from 92.63.195.7: seq=1 ttl=54 time=26.020 ms
^C
--- ndss.keenetic.ndmsystems.com ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 26.020/26.170/26.320 ms
~ # ping ru.master.keenetic.cloud
PING ru.master.keenetic.cloud (212.41.10.26): 56 data bytes
64 bytes from 212.41.10.26: seq=0 ttl=56 time=21.033 ms
64 bytes from 212.41.10.26: seq=1 ttl=56 time=20.781 ms
64 bytes from 212.41.10.26: seq=2 ttl=56 time=20.887 ms
^C
--- ru.master.keenetic.cloud ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 20.781/20.900/21.033 ms
По ошибке в логе
пр 23 10:38:13 ndm Ndns::Client: unable to get a booked name.
Апр 23 10:38:15 ndm Core::Ndss: [541] no internet connection.
Апр 23 10:38:17 ndm Ndns::Client: unable to get a booked name.
Апр 23 10:38:23 ndm Core::Ndss: [541] no internet connection.
Апр 23 10:38:24 ndm Ndns::Client: unable to get a booked name.
Апр 23 10:38:27 ndm Core::Ndss: [541] no internet connection.
Апр 23 10:38:28 ndm Ndns::Client: unable to get a booked name.
Апр 23 10:38:34 ndm Core::Ndss: [541] no internet connection.
Апр 23 10:38:35 ndm Ndns::Client: unable to get a booked name.
Апр 23 10:38:38 ndm Core::Ndss: [541] no internet connection.
Регион Россия на обоих, на основном Keenetic канал PPPoE RT т.е. так же нет ни какого VPN. Так же пропала возможность обновления.
На 38А8 так же работало но забыл сохраниться. Есть подозрения на исправления для обновления по регионам. Основной Keenetic пока на 38А8.
Вопрос это решаемо для 38B1 или можно забыть про такую работу KN1810 c KeenDNS.
Edited by vasek00
14 answers to this question
Словил еще один такой же на другой паре роутеров Keenetic при работе
KN1010(LAN)-----(LAN)KN1910---Интернет
38B1                   38B1
Это попадало во 😒
Проверка через 374 данной схемы на KN1810 все работает как не в чем не бывало, переход опять же на 38B1 (обновление из WEB) ведет к ошибке как по сервису обновления так по KeenDNS
Апр 23 18:13:35 ndm Core::Ndss: [1519] no internet connection.
Апр 23 18:13:41 ndm Core::Ndss: [540] no internet connection.
Апр 23 18:13:42 ndm Ndns::Client: unable to get a booked name.
Апр 23 18:13:44 ndm Core::Ndss: [1567] no internet connection.
Можно в двух словах описать ошибку
Апр 25 16:19:06 ndm Core::Ndss: [539] no internet connection.
Апр 25 16:19:07 ndm Ndns::Client: unable to get a booked name.
при
551053087_-3.jpg.2638db775e8936a426c5630dfb47bbe6.jpg1997865385_-2.jpg.4ae78fd4f060b7cae68edf08161ce582.jpg
но при наличие как такового интернета
~ # ip ro
default via 192.168.1.10 dev br0
192.168.1.0/24 dev br0  proto kernel  scope link  src 192.168.1.9
~ # nslookup ndss11.knt9.xyz
Server:    127.0.0.1
Address 1: 167.233.7.36 h4.knt9.xyz
Address 2: 185.103.134.193
Address 3: 92.63.195.7 vlan772.dci
Address 4: 91.142.81.244 vl2214.miran.ru
Address 5: 88.198.177.100 h2.ndm9.xyz
Address 6: 2a03:21c0:0:20d::244
Address 7: 2a01:230:2:85::7
Address 8: 2a0f:f6c0:ac0d:2009::134:193
Address 9: 2a01:4f8:d1:1d00::100 h2.ndm9.xyz
Address 10: 2a01:4f8:fff0:5d::36
<!-- show ndss -->
    <host>ndss.keenetic.ndmsystems.com</host>
    <registrator>
        <reasons>boot</reasons>
        <state>STOP</state>
        <delay>0</delay>
        <wan-ip>0.0.0.0</wan-ip>
        <sent-wan-ip>0.0.0.0</sent-wan-ip>
        <last-nr-reason/>
        <last-error>00000000</last-error>
        <since-last-call>0</since-last-call>
        <since-last-nr>0</since-last-nr>
        <failure-count>0</failure-count>
        <fallback>no</fallback>
    </registrator>
А на 38А4
    <!-- show ndss -->
    <registrator>
        <reasons>periodic</reasons>
        <state>PERIODIC</state>
        <delay>86376</delay>
        <wan-ip>192.168.1.9</wan-ip>
        <sent-wan-ip>192.168.1.9</sent-wan-ip>
        <last-nr-reason>periodic</last-nr-reason>
        <since-last-call>23</since-last-call>
        <since-last-nr>23</since-last-nr>
    </registrator>
Или в чем отличие 38B1 от draft 38A4 / релиза 374 на последнюю дату?
И естественно проблема с обновлением.
3 часа назад, Le ecureuil сказал:
self-test бы неплохо в момент когда не работает.
self-test еще нужен или уже проблема найдена.
50 минут назад, vasek00 сказал:
Чисто чтобы подтвердить что это уже исправленная проблема или (маловероятно, но все же) какая-то еще.
12 минуты назад, Le ecureuil сказал:
Отправил в личику
Проблема найдена, просьба проверить на следующей версии 3.8.
Проверим
Edited by vasek00
В 12.05.2022 в 18:39, Le ecureuil сказал:
Все ОК, работает на 38B2.
