[I] Jan 1 00:00:03 kernel: 0x000000000000-0x000000020000 : "U-Boot"
[I] Jan 1 00:00:03 kernel: 0x000000020000-0x000000040000 : "U-Config"
[I] Jan 1 00:00:03 kernel: 0x000000040000-0x000000080000 : "RF-EEPROM"
[I] Jan 1 00:00:03 kernel: 0x000000080000-0x000000240000 : "Kernel_1"
[I] Jan 1 00:00:03 kernel: 0x000000240000-0x000001f40000 : "RootFS_1"
[I] Jan 1 00:00:03 kernel: mtd: device 4 (RootFS_1) set to be root filesystem
[I] Jan 1 00:00:03 kernel: 0x000000080000-0x000001f40000 : "Firmware_1"
[I] Jan 1 00:00:03 kernel: 0x000001f40000-0x000001fc0000 : "Config_1"
[I] Jan 1 00:00:03 kernel: 0x000001fc0000-0x000002000000 : "Dump"
[I] Jan 1 00:00:03 kernel: 0x000002000000-0x000003ae0000 : "Storage_A"
[I] Jan 1 00:00:03 kernel: 0x000003ae0000-0x000003b00000 : "U-State"
[I] Jan 1 00:00:03 kernel: 0x000003b00000-0x000003b20000 : "U-Config_res"
[I] Jan 1 00:00:03 kernel: 0x000003b20000-0x000003b60000 : "RF-EEPROM_res"
[I] Jan 1 00:00:03 kernel: random: fast init done
[I] Jan 1 00:00:03 kernel: 0x000003b60000-0x000005a20000 : "Firmware_2"
[I] Jan 1 00:00:03 kernel: 0x000005a20000-0x000005aa0000 : "Config_2"
[I] Jan 1 00:00:03 kernel: 0x000005aa0000-0x0000075e0000 : "Storage_B"
[I] Jan 1 00:00:03 kernel: 0x000000000000-0x0000075e0000 : "Full"
[I] Jan 1 00:00:05 kernel: Searching for suitable storage partitions...
[I] Jan 1 00:00:05 kernel: Found 1st storage partition of size 28180480 bytes
[I] Jan 1 00:00:05 kernel: Found 2nd storage partition of size 28573696 bytes
[I] Jan 1 00:00:05 kernel: Registering UBI data partitions parser
[W] Jan 1 00:00:05 kernel: Concatenating MTD devices:
[W] Jan 1 00:00:05 kernel: (0): "Storage_A"
[W] Jan 1 00:00:05 kernel: (1): "Storage_B"
[W] Jan 1 00:00:05 kernel: into device "NDM combined UBI partition"
[I] Jan 1 00:00:05 kernel: 1 ndmubipart partitions found on MTD device NDM combined UBI partition
[I] Jan 1 00:00:05 kernel: mtd: creating 1 MTD partitions on "NDM combined UBI partition":
[I] Jan 1 00:00:05 kernel: 0x000000000000-0x000003620000 : "Storage"
[I] Jan 1 00:00:05 kernel: Merging storage partitions OK
Но вот автоматом оно не монтируется:
/ # mount
/dev/root on / type squashfs (ro,relatime)
tmpfs on /dev type tmpfs (rw,nosuid,noexec,relatime)
none on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600,ptmxmode=000)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
даже после
(config)> opkg disk storage:/
Пытаюсь сделать руками:
(config)> exec sh
BusyBox v1.24.2 () built-in shell (ash)
/ # modprobe ubi
/ # modprobe ubifs
/ # ubinfo
UBI version: 1
Count of UBI devices: 0
UBI control device major/minor: 10:59
/ # mknod /dev/ubi_ctrl c 10 59
/ # ubiattach /dev/ubi_ctrl -m 16
UBI device number 0, total 433 LEBs (54980608 bytes, 52.4 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
/ # ubinfo /dev/ubi0
ubi0
Volumes count: 0
Logical eraseblock size: 126976 bytes, 124.0 KiB
Total amount of logical eraseblocks: 433 (54980608 bytes, 52.4 MiB)
Amount of available logical eraseblocks: 428 (54345728 bytes, 51.8 MiB)
Maximum count of volumes 128
Count of bad physical eraseblocks: 0
Count of reserved physical eraseblocks: 1
Current maximum erase counter value: 1
Minimum input/output unit size: 2048 bytes
Character device major/minor: 241:0
/ # ubimkvol /dev/ubi0 -N storage -s 54345728
Volume ID 0, size 428 LEBs (54345728 bytes, 51.8 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "storage", alignment 1
/ # ubinfo /dev/ubi0_0
Volume ID: 0 (on ubi0)
Type: dynamic
Alignment: 1
Size: 428 LEBs (54345728 bytes, 51.8 MiB)
State: OK
Character device major/minor: 241:1
Смонтировать вручную
/ # mount -t ubifs -o compr=zlib ubi0_0 /storage
/ # mount -t ubifs -o compr=zlib ubi0_0 /opt
/ # mount
ubi0_0 on /storage type ubifs (rw,relatime,compr=zlib)
ubi0_0 on /opt type ubifs (rw,relatime,compr=zlib)
Но вот дальше Opkg::Manager не хочет устанавливать ничего из папки /storage/install
При перезагрузке /dev/ubi_ctrl пропадает, и, по прежнему автоматом ничего не монтируется и не устанавливается.
srgsf
Всем привет!
Дано:
KN-3710, Ноут с Apple M1 Pro процессором.
Требуется:
Получить на KN-3710 рабочий OPKG наподобие того, что описывается вот в этой инструкции.
=== Подготовка ===
=== Проверка ===
Собираю по инструкции из readme в kinetic-sdk. Если всё прошло успешно, то в папке /bin/en7528/ появляется файл прошивки с расширением .bin
Переименовываю файл в KN-3710_recovery.bin и складываю его в папку /private/tftpboot/ на ноуте.
Далее по вот этой инструкции прошиваю девайс.
=== Настройка прошивки ===
Для начала в оригинальной прошивке нужно включить OPKG компонент, затем выгрузить прошивку и на ней сделать
make dirclean ./unpack.sh <файл прошивки>
Далее:
make menuconfig
Доступ к ash
NDM -> Debug -> ndm-mod-shell
NDM -> Opkg -> ndm-mod-opkg
UBIFS
Kernel modules -> Other modules -> kmod-ndm-storage
Kernel modules -> Filesystems -> kmod-fs-ubi
Kernel modules -> Filesystems -> kmod-fs-ubifs
Kernel modules -> Cryptographic API modules -> kmod-crypto-lzo
Kernel modules -> Libraries -> kmod-lib-lzo
Libraries -> liblzo
Utilities -> ubi-utils
Utilities
Debug suite -> curl
Libraries -> libarchive
Возможно что-то ещё...
Cоздаю папку files/storage
Сохраняю, собираю (make), прошиваю через recovery
Теперь в CLI доступно:
(config)> exec ash BusyBox v1.24.2 () built-in shell (ash) / #
в логах появились Storage_A и Storage_B
[I] Jan 1 00:00:03 kernel: 0x000000000000-0x000000020000 : "U-Boot" [I] Jan 1 00:00:03 kernel: 0x000000020000-0x000000040000 : "U-Config" [I] Jan 1 00:00:03 kernel: 0x000000040000-0x000000080000 : "RF-EEPROM" [I] Jan 1 00:00:03 kernel: 0x000000080000-0x000000240000 : "Kernel_1" [I] Jan 1 00:00:03 kernel: 0x000000240000-0x000001f40000 : "RootFS_1" [I] Jan 1 00:00:03 kernel: mtd: device 4 (RootFS_1) set to be root filesystem [I] Jan 1 00:00:03 kernel: 0x000000080000-0x000001f40000 : "Firmware_1" [I] Jan 1 00:00:03 kernel: 0x000001f40000-0x000001fc0000 : "Config_1" [I] Jan 1 00:00:03 kernel: 0x000001fc0000-0x000002000000 : "Dump" [I] Jan 1 00:00:03 kernel: 0x000002000000-0x000003ae0000 : "Storage_A" [I] Jan 1 00:00:03 kernel: 0x000003ae0000-0x000003b00000 : "U-State" [I] Jan 1 00:00:03 kernel: 0x000003b00000-0x000003b20000 : "U-Config_res" [I] Jan 1 00:00:03 kernel: 0x000003b20000-0x000003b60000 : "RF-EEPROM_res" [I] Jan 1 00:00:03 kernel: random: fast init done [I] Jan 1 00:00:03 kernel: 0x000003b60000-0x000005a20000 : "Firmware_2" [I] Jan 1 00:00:03 kernel: 0x000005a20000-0x000005aa0000 : "Config_2" [I] Jan 1 00:00:03 kernel: 0x000005aa0000-0x0000075e0000 : "Storage_B" [I] Jan 1 00:00:03 kernel: 0x000000000000-0x0000075e0000 : "Full" ... [I] Jan 1 00:00:05 kernel: Searching for suitable storage partitions... [I] Jan 1 00:00:05 kernel: Found 1st storage partition of size 28180480 bytes [I] Jan 1 00:00:05 kernel: Found 2nd storage partition of size 28573696 bytes [I] Jan 1 00:00:05 kernel: Registering UBI data partitions parser [W] Jan 1 00:00:05 kernel: Concatenating MTD devices: [W] Jan 1 00:00:05 kernel: (0): "Storage_A" [W] Jan 1 00:00:05 kernel: (1): "Storage_B" [W] Jan 1 00:00:05 kernel: into device "NDM combined UBI partition" [I] Jan 1 00:00:05 kernel: 1 ndmubipart partitions found on MTD device NDM combined UBI partition [I] Jan 1 00:00:05 kernel: mtd: creating 1 MTD partitions on "NDM combined UBI partition": [I] Jan 1 00:00:05 kernel: 0x000000000000-0x000003620000 : "Storage" [I] Jan 1 00:00:05 kernel: Merging storage partitions OK
/ # mount /dev/root on / type squashfs (ro,relatime) tmpfs on /dev type tmpfs (rw,nosuid,noexec,relatime) none on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600,ptmxmode=000) proc on /proc type proc (rw,nosuid,nodev,noexec,relatime) tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime) sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
даже после
(config)> opkg disk storage:/ Opkg::Manager: Disk is set to: storage:/.
(config)> exec sh BusyBox v1.24.2 () built-in shell (ash) / # modprobe ubi / # modprobe ubifs / # ubinfo UBI version: 1 Count of UBI devices: 0 UBI control device major/minor: 10:59 / # mknod /dev/ubi_ctrl c 10 59 / # ubiattach /dev/ubi_ctrl -m 16 UBI device number 0, total 433 LEBs (54980608 bytes, 52.4 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) / # ubinfo /dev/ubi0 ubi0 Volumes count: 0 Logical eraseblock size: 126976 bytes, 124.0 KiB Total amount of logical eraseblocks: 433 (54980608 bytes, 52.4 MiB) Amount of available logical eraseblocks: 428 (54345728 bytes, 51.8 MiB) Maximum count of volumes 128 Count of bad physical eraseblocks: 0 Count of reserved physical eraseblocks: 1 Current maximum erase counter value: 1 Minimum input/output unit size: 2048 bytes Character device major/minor: 241:0 / # ubimkvol /dev/ubi0 -N storage -s 54345728 Volume ID 0, size 428 LEBs (54345728 bytes, 51.8 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "storage", alignment 1 / # ubinfo /dev/ubi0_0 Volume ID: 0 (on ubi0) Type: dynamic Alignment: 1 Size: 428 LEBs (54345728 bytes, 51.8 MiB) State: OK Name: storage Character device major/minor: 241:1
/ # mount -t ubifs -o compr=zlib ubi0_0 /storage / # mount -t ubifs -o compr=zlib ubi0_0 /opt / # mount /dev/root on / type squashfs (ro,relatime) tmpfs on /dev type tmpfs (rw,nosuid,noexec,relatime) none on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600,ptmxmode=000) proc on /proc type proc (rw,nosuid,nodev,noexec,relatime) tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime) sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime) ubi0_0 on /storage type ubifs (rw,relatime,compr=zlib) ubi0_0 on /opt type ubifs (rw,relatime,compr=zlib)
Помогите, plz.
Следующий шаг.
12 answers to this question
