3.9 Alpha 8: sending SIGSEGV to transmissiond
r3L4x
Цитата
Сен 5 23:35:50
kernel
ra = 00452758 in transmissiond[400000+93000]
Сен 5 23:35:50
ndm
Core::Session: client disconnected.
Сен 5 23:35:50
ndm
Service: "transmission": unexpectedly stopped.
Сен 5 23:35:53
ndm
Core::Server: started Session /var/run/ndm.core.socket.
Сен 5 23:35:54
kernel
do_page_fault(): sending SIGSEGV to transmissiond for invalid read access from 00000000
Сен 5 23:35:54
kernel
epc = 76cc1ac4 in libcrypto.so.3[76b9e000+2af000]
Сен 5 23:35:54
kernel
Сен 5 23:35:54
ndm
Сен 5 23:35:54
ndm
Сен 5 23:35:57
ndm
Сен 5 23:35:59
kernel
Сен 5 23:35:59
kernel
epc = 76fe5ac4 in libcrypto.so.3[76ec2000+2af000]
Сен 5 23:35:59
kernel
Сен 5 23:35:59
ndm
Сен 5 23:35:59
ndm
весь лог забит таким.
1910 | 3.9.8
  • Upvote 3
12 answers to this question
398 на KN1011 без проблем запустился
[I] Sep  6 13:03:08 transmissiond: Transmission 3.00 (319215a162) started
[I] Sep  6 13:03:08 transmissiond: RPC Server Adding address to whitelist: *.*.*.*
[I] Sep  6 13:03:08 transmissiond: RPC Server Serving RPC and Web requests on 0.0.0.0:8090/transmission/
[I] Sep  6 13:03:08 transmissiond: RPC Server Whitelist enabled
[I] Sep  6 13:03:08 transmissiond: RPC Server Password required
[I] Sep  6 13:03:08 transmissiond: Port Forwarding Stopped
[I] Sep  6 13:03:08 transmissiond: DHT Reusing old id
[I] Sep  6 13:03:08 transmissiond: DHT Bootstrapping from 112 IPv4 nodes
[I] Sep  6 13:03:08 transmissiond: Using settings from "/tmp/mnt/0....0/Torrent"
[I] Sep  6 13:03:08 transmissiond: Saved "/tmp/mnt/0.....0/Torrent/settings.json"
[I] Sep  6 13:03:08 transmissiond: transmissiond requiring authentication
[I] Sep  6 13:03:08 transmissiond: Watching "/tmp/mnt/0.....0/Torrent/watch" for new .torrent files
[I] Sep  6 13:03:08 transmissiond: Loaded 1 torrents
[I] Sep  6 13:03:54 transmissiond: Добыча.2022.WEB-DL.2160p.SDR.mkv Starting IPv4 DHT announce (poor, 19 nodes)
    <process>
        <comm>transmissiond</comm>
        <oom-adj>16</oom-adj>
        <oom-score>990</oom-score>
        <oom-score-adj>990</oom-score-adj>
        <arg>-Q</arg>
        <arg>0</arg>
        <arg>-f</arg>
        <arg>-a</arg>
        <arg>*.*.*.*</arg>
        <arg>-t</arg>
        <arg>-c</arg>
        <arg>/tmp/mnt/0....0/Torrent/watch</arg>
        <arg>-w</arg>
        <arg>/tmp/mnt/0.....0/Torrent/download</arg>
        <arg>-g</arg>
        <arg>/tmp/mnt/0.....0/Torrent</arg>
        <arg>-P</arg>
        <arg>51413</arg>
        <arg>-p</arg>
        <arg>8090</arg>
        <arg>-s</arg>
        <arg>/var/run/transmission-feedback</arg>
        <state>S (sleeping)</state>
        <pid>7896</pid>
        <ppid>268</ppid>
        <vm-size>7680 kB</vm-size>
        <vm-rss>5304 kB</vm-rss>
        <vm-data>1000 kB</vm-data>
        <vm-stk>132 kB</vm-stk>
        <vm-exe>588 kB</vm-exe>
        <vm-lib>5932 kB</vm-lib>
        <vm-swap>0 kB</vm-swap>
        <threads>3</threads>
        <fds>24</fds>
        <statistics>
            <interval>30</interval>
            <cpu>
                <now>14005.196851</now>
                <min>0</min>
                <max>0</max>
                <avg>0</avg>
                <cur>0</cur>
            </cpu>
        </statistics>
        <env name="HOME">/tmp/mnt/0.....0/Torrent</env>
        <object>
            <id>transmission</id>
            <state>RUNNING</state>
        </object>
        <service>
            <configured>yes</configured>
            <alive>yes</alive>
            <started>yes</started>
            <state>STARTED</state>
        </service>
    </process>
добавление закачки так же проблем не возникло
[I] Sep  6 13:14:29 transmissiond: Saved "/tmp/mnt/0.....0/Torrent/torrents/fd75cc9eaeb6cacde72fc5de8a895c57032545d3.torrent"
[I] Sep  6 13:14:29 transmissiond: VC.2022.Pa.TS.1O8Op.mkv Queued for verification
[I] Sep  6 13:14:29 transmissiond: VC.2022.Pa.TS.1O8Op.mkv Verifying torrent
[I] Sep  6 13:14:43 transmissiond: VC.2022.Pa.TS.1O8Op.mkv Starting IPv4 DHT announce (firewalled, 241 nodes)
[I] Sep  6 13:15:07 transmissiond: Saved "/tmp/mnt/0......0/Torrent/resume/fd75cc9eaeb6cacde72fc5de8a895c57032545d3.resume"
    <process>
        <arg>-p</arg>
        <arg>8090</arg>
        <arg>-s</arg>
        <pid>7896</pid>
        <ppid>268</ppid>
        <vm-size>17664 kB</vm-size>
        <vm-rss>15040 kB</vm-rss>
        <vm-data>10984 kB</vm-data>
        <fds>32</fds>
        <statistics>
            <cpu>
                <now>14591.195628</now>
                <min>0</min>
                <max>15</max>
                <avg>10</avg>
                <cur>5</cur>
            </cpu>
        </statistics>
20 минут назад, r3L4x сказал:
@vasek00а опция "шифрования" включена в настройках сети для Transmission? Судя по логам, там поломка связана с новой либой OpenSSL.
Да при включение шифрования Transmission отвалился
[I] Sep  6 13:49:11 transmissiond: Transmission 3.00 (319215a162) started
[I] Sep  6 13:49:11 transmissiond: RPC Server Adding address to whitelist: *.*.*.*
[I] Sep  6 13:49:11 transmissiond: RPC Server Serving RPC and Web requests on 0.0.0.0:8090/transmission/
[I] Sep  6 13:49:11 transmissiond: RPC Server Whitelist enabled
[I] Sep  6 13:49:11 transmissiond: RPC Server Password required
[I] Sep  6 13:49:11 transmissiond: Port Forwarding Stopped
[I] Sep  6 13:49:11 transmissiond: DHT Reusing old id
[I] Sep  6 13:49:11 transmissiond: DHT Bootstrapping from 202 IPv4 nodes
[I] Sep  6 13:49:11 transmissiond: Using settings from "/tmp/mnt/01D8485127BE8DA0/Torrent"
[I] Sep  6 13:49:11 transmissiond: Saved "/tmp/mnt/01D8485127BE8DA0/Torrent/settings.json"
[I] Sep  6 13:49:11 transmissiond: transmissiond requiring authentication
[I] Sep  6 13:49:11 transmissiond: Watching "/tmp/mnt/01.....0/Torrent/watch" for new .torrent files
[I] Sep  6 13:49:11 transmissiond: Loaded 2 torrents
[W] Sep  6 13:49:11 kernel: do_page_fault(): sending SIGSEGV to transmissiond for invalid read access from 00000000
[W] Sep  6 13:49:11 kernel: epc = 77b5cac4 in libcrypto.so.3[77a39000+2af000]
[W] Sep  6 13:49:11 kernel: ra  = 00452758 in transmissiond[400000+93000]
[I] Sep  6 13:49:11 ndm: Core::Session: client disconnected.
[E] Sep  6 13:49:11 ndm: Service: "transmission": unexpectedly stopped.
Исправление в настройках settings.json параметра "encryption": 0 приводит его в чувства.
Edited by vasek00
  • Thanks 2
21 минуту назад, vasek00 сказал:
Что вполне логично. ;) Будем ждать фикс. У меня почти все анонсеры юзают https.
Да, ошибка в работе клиента возникает при включении "encryption": 1, - это связано с обновлением openssl 3.
В следующей версии драфта будет исправлено. Всем спасибо!
@KYTECHNGAMING yes, thnks, issue found.
  • Thanks 3
3 hours ago, enpa said:
Yes, an error in the client's work occurs when "encryption": 1 is enabled, - this is due to the updates of openssl 3.
It will be fixed in the next version of the draft. Thanks to all!
I used encryption: 2 too. Thanks for all effort. Waiting fix. 🤘
Edited by KYTECHNGAMING
