freman4543 Posted October 26, 2022 Share Posted October 26, 2022 Приветствую Просьба помочь настройкой OpenVPN на Omni (KN-1410) В целом создал конфигурацию, вставил в роутер, подключение происходит, но нет принятого/отправленного трафика и происходит обрыв спустя пару минут, использую cyberghostvpn Часть системного журнала: OpenVPN0 WARNING: OpenVPN was configured to add an IPv6 route over tun0. However, no IPv6 has been configured for this interface, therefore the route installation may fail or may not work as expected. OpenVPN0 GID set to nobody OpenVPN0 UID set to nobody OpenVPN0 Initialization Sequence Completed OpenVPN0 [huenenberg-rack412.nodes.gen4.ninja] Inactivity timeout (--ping-exit), exiting OpenVPN0 TCP/UDP: Closing socket OpenVPN0 Closing TUN/TAP interface OpenVPN0 SIGTERM[soft,ping-exit] received, process exiting ndm Service: "OpenVPN0": unexpectedly stopped. ndm Network::Interface::OpenVpn: "OpenVPN0": system failed [0xcffd0ab1], unable to set down tunnel interface: no such device. ndm Network::Interface::OpenVpn: "OpenVPN0": system failed [0xcffd0ac0], invalid argument. ndm Network::Interface::Ip: "OpenVPN0": IP address cleared. ndm Http::Nginx: loaded SSL certificate for "c253a9e1c27ca946cab8d5af.keenetic.io". Quote Link to comment Share on other sites More sharing options...
