OpenVPN problem
Posted (edited)
Hello everyone! I need help with OpenVPN.
Problem is going about 2-3 weeks since trying to make OpenVPN work properly on Keenetic and Mikrotik
Once OpenVPN isn't working because off "TLS Error: TLS handshake failed" i trying to fix that with guides that i ever can find.
After that OpenVPN on Keenitc can't connect and appear even more failure:
  • VERIFY ERROR: depth=0, error=unsupported certificate purpose: C=XX, O=XX, OU=IT, CN=ca
  • OpenSSL: error:1416F086:lib(20):func(367):reason(134)
  • TLS_ERROR: BIO read tls_read_plaintext error
  • TLS Error: TLS object -> incoming plaintext read error
  • TLS Error: TLS handshake failed
  • Fatal TLS error (check_tls_errors_co), restarting
  • Service: "OpenVPN0": unexpectedly stopped.
Here is the configuration on Keenetic
  • client
  • dev tun
  • proto tcp
  • remote 9X.XXX.XXX.XXX 1194
  • nobind
  • persist-key
  • persist-tun
  • <ca>
  • -----BEGIN CERTIFICATE-----
  • XXX
  • -----END CERTIFICATE-----
  • </cert>
  • <key>
  • -----BEGIN ENCRYPTED PRIVATE KEY-----
  • XXXX
  • -----END ENCRYPTED PRIVATE KEY-----
  • </key>
  • <auth-user-pass>
  • username
  • password
  • </auth-user-pass>
  • remote-cert-tls server
  • verb 3
Does it even possible to make Mikrotic and Keenetic working properly with each other?
I hope i described my problem normaly and can get help with that problem
P.S.Configuration was taken from: https://habr.com/ru/post/269679/
(2tun)
Edited by newvier21
1 answer to this question
Posted
if it help you.
This is my configs:
client(Keenetic):
Spoiler
dev tun
proto udp
remote ***.***.***.*** ????
client
resolv-retry infinite
auth SHA256
auth-nocache
cipher AES-256-CBC
data-ciphers AES-256-CBC
persist-key
persist-tun
nobind
comp-lzo
verb 3
<ca>
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
<tls-crypt>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-crypt>
server (Centos7):
Spoiler
port ????
proto udp
dev tun
crl-verify /etc/openvpn/server/crl.pem # my revoked certs list # real revoked certs list /etc/openvpn/keys/easyrsa/pki/crl.pem
sndbuf 393216
rcvbuf 393216
push "sndbuf 393216"
push "rcvbuf 393216"
ca /etc/openvpn/server/ca.crt
cert /etc/openvpn/server/ASvps.crt
key /etc/openvpn/server/ASvps.key
dh /etc/openvpn/server/dh.pem
auth SHA256
cipher AES-256-CBC
tls-version-min 1.2
tls-crypt tc.key
server ***.***.***.0 255.255.255.0
topology subnet
local ***.***.***.*** # Internet server IP
ifconfig-pool-persist ipp.txt #  clinet - ip
client-to-client #
client-config-dir /etc/openvpn/ccd
keepalive 10 120
comp-lzo
explicit-exit-notify 1 # if tcp, change for "0"
persist-key
persist-tun
status /var/log/openvpn/openvpn-status.log
log /var/log/openvpn/openvpn.log
user nobody
group nobody
verb 3
