Hello. I would like to talk about two shortcomings that I have identified.
1. When you want to use wisp as a backup connection in systems with mesh installed, mobile hotspot connection can only be made through the main router. If the mobile hotspot is out of range of the main router but within the mesh range, the connection cannot be established. I want wisp connection to be made over mobile hotspot over all nodes in mesh.
2. In order to reduce the load on the router in mesh systems, it should be possible to install modules separately at all nodes. For example, vpn should be installed on the main router, media server should be installed on the other node (mesh client). Thus, the processing load on the main router can be reduced.
proxtg
0 answers to this question
