Marassa Posted February 18 Share Posted February 18 Feb 18 12:41:58 OpenVPN0 OpenVPN 2.6_git [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] Feb 18 12:41:58 OpenVPN0 library versions: OpenSSL 3.0.7 1 Nov 2022, LZO 2.10 Feb 18 12:41:58 OpenVPN0 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead. Feb 18 12:41:58 OpenVPN0 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication Feb 18 12:41:58 OpenVPN0 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication Feb 18 12:41:58 OpenVPN0 Socket Buffers: R=[155648->1048576] S=[155648->1048576] Feb 18 12:41:58 OpenVPN0 UDPv4 link local: (not bound) Feb 18 12:41:58 OpenVPN0 UDPv4 link remote: [AF_INET]173.239.207.44:1195 Feb 18 12:41:58 OpenVPN0 NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay Feb 18 12:42:58 OpenVPN0 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Feb 18 12:42:58 OpenVPN0 TLS Error: TLS handshake failed Feb 18 12:42:58 OpenVPN0 SIGTERM[soft,tls-error] received, process exiting Feb 18 12:42:58 ndm Service: "OpenVPN0": unexpectedly stopped. Совпадение? У кого-нибудь OpenVPN client работает нормально в 3.9.3? Quote Link to comment Share on other sites More sharing options...
keenet07 Posted February 18 Share Posted February 18 (edited) Проверьте TLS ключ в конфиге VPN на роутере, на всякий случай. Сверьте и другие параметры соединения. В целом на 3.9.3 OpenVPN работает. Edited February 18 by keenet07 Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 18 Author Share Posted February 18 1 минуту назад, keenet07 сказал: Проверьте TLS ключ в конфиге VPN на роутере, на всякий случай. Да он не менялся много лет, и я пробовал новый конфиг загружать с другой географией. А по симптомам похоже, что ТСПУ у провайдера начал резать VPN? Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 18 Author Share Posted February 18 Провел еще эксперимент: поставил на телефон (андроид) приложение от ExpressVPN и оно прекрасно работает по любым протоколам - хоть Lightway, хоть OpenVPN. Стало быть дело не в провайдере, а именно в роутере... Насколько помню, простого и безгеморного способа откатиться на предыдущую прошивку нет? Quote Link to comment Share on other sites More sharing options...
keenet07 Posted February 18 Share Posted February 18 (edited) 1 час назад, Marassa сказал: Провел еще эксперимент: поставил на телефон (андроид) приложение от ExpressVPN и оно прекрасно работает по любым протоколам - хоть Lightway, хоть OpenVPN. Стало быть дело не в провайдере, а именно в роутере... Насколько помню, простого и безгеморного способа откатиться на предыдущую прошивку нет? Почему нет. Самый простой и безгеморный это загрузить ранее стоявшие прошивку и конфиг. Перед обновлением же оболочка предлагает всегда сохранить их. Не стоит это игнорировать. Удалить два ненужных файлика всегда успеете. Ну если их у вас всё таки нет, то временно вернуться на любую предыдущую версию прошивки с базовым набором компонентов из облака без возможности изменить компоненты. Edited February 18 by keenet07 Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 18 Author Share Posted February 18 1 минуту назад, keenet07 сказал: Перед обновлением же оболочка предлагает всегда сохранить их. Это если не включено автообновление... Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 15 часов назад, keenet07 сказал: временно вернуться на любую предыдущую версию прошивки с базовым набором компонентов из облака без возможности изменить компоненты. А можно чуть подробнее как это сделать? Я нашел предыдущую прошивку 3.9.2, если я просто заменю ее без конфига, насколько велика вероятность получить кирпич? Quote Link to comment Share on other sites More sharing options...
Mamay Posted February 19 Share Posted February 19 52 минуты назад, Marassa сказал: Я нашел предыдущую прошивку 3.9.2, если я просто заменю ее без конфига, насколько велика вероятность получить кирпич? Не надо ничего выдумывать и что-то там искать левого! Официальные файлы с прошивками лежат тут. Но это крайний вариант! Самый надёжный и просто способ - смена каналов в cli. Смотрите какой канал используется: show version и затем выбираете нужный вам.components list draft components commitcomponents list delta components commit components list beta components commit components list stable components commit components list legacy components commit P.S. Кирпича не будет, можете доверится, но всё ВСЕГДА нужно иметь копию рабочего варианта startup-config & firmware!!! И обязательно уберите автообновление, чтобы не выхватывать такой геморрой вновь и вновь... 1 Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 1 минуту назад, Mamay сказал: Не надо ничего выдумывать и что-то там искать левого! Официальные файлы с прошивками лежат тут Так я именно там и нашел, не в даркнете же 3 минуты назад, Mamay сказал: Самый надёжный и просто способ - смена каналов в cli Не до конца понял - канал у меня выбран Main, каким образом выбор другого канала даст более старую версию? Preview и Dev ведь дадут более новую и нестабильную версию, разве нет? 5 минут назад, Mamay сказал: ВСЕГДА нужно иметь копию рабочего варианта startup-config & firmware!!! И обязательно уберите автообновление, чтобы не выхватывать такой геморрой вновь и вновь... Да я уж понял и отключил, но увы, немножко поздно... Чую, что всё дело в каких-то тонких настройках OpenVPN, но их там миллион, и непонятно что дёргать. Quote Link to comment Share on other sites More sharing options...
Mamay Posted February 19 Share Posted February 19 1 минуту назад, Marassa сказал: Не до конца понял - канал у меня выбран Main, каким образом выбор другого канала даст более старую версию? Preview и Dev ведь дадут более новую и нестабильную версию, разве нет? Привык общаться с альфа тестерами и их перегнать на stable - решение проблемы. Но вы уже на канале stable. Залив 3.9.2 даст вам базовый вариант, без плюшек и вы не сможете доустановить ничего, так как в канале уже 3.9.3. Пробуйте legacy или вперёд в ТП, ибо сам себе злобный Буратино безбекапный и с включённым автообновлением! 1 Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 21 минуту назад, Mamay сказал: Залив 3.9.2 даст вам базовый вариант, без плюшек и вы не сможете доустановить ничего, так как в канале уже 3.9.3. В базовом ведь небось и OpenVPN не будет, так что у меня не получится даже удостовериться что дело именно в смене прошивки? 23 минуты назад, Mamay сказал: Пробуйте legacy ? 23 минуты назад, Mamay сказал: или вперёд в ТП ?? Прошу пояснить - я ж не настоящий сисадмин, а токмо волею пославшей мя жены не слишком продвинутый юзер... Quote Link to comment Share on other sites More sharing options...
Mamay Posted February 19 Share Posted February 19 Есть шанс что на 4.хх бага пофиксена. Попробуйте draft ))) 1 Quote Link to comment Share on other sites More sharing options...
Mamay Posted February 19 Share Posted February 19 legacy - один из древних каналов из 2-ой ветки. https://help.keenetic.com/hc/ru - официальная Техническая Поддержка = ТП. 2 Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 2 минуты назад, Mamay сказал: Есть шанс что на 4.хх бага пофиксена. Попробуйте draft ))) Я правильно понял правильную процедуру? Сохранить firmware и startup-config Переключив канал, обновиться до 4. В случае факапа восстановить ранее сохраненные firmware и startup-config ? Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 Поставил 4.0 Alpha 9. Теперь OpenVPN даже не пытается подняться: Feb 19 10:16:52 OpenVPN0 OpenVPN 2.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] Feb 19 10:16:52 OpenVPN0 library versions: OpenSSL 3.0.8 7 Feb 2023, LZO 2.10 И это всё, дальше вообще ничего... Quote Link to comment Share on other sites More sharing options...
keenet07 Posted February 19 Share Posted February 19 (edited) Выложите сюда в текстовом виде ваш конфиг OpenVPN, предварительно убрав из него всю чувствительную информацию. Edited February 19 by keenet07 Quote Link to comment Share on other sites More sharing options...
Mamay Posted February 19 Share Posted February 19 1 минуту назад, keenet07 сказал: Выложите сюда в текстовом виде ваш конфиг OpenVPN, предварительно убрав из него всю чувствительную информацию. 20 часов назад, Marassa сказал: Да он не менялся много лет 1 Quote Link to comment Share on other sites More sharing options...
keenet07 Posted February 19 Share Posted February 19 (edited) 3 минуты назад, Mamay сказал: Да он не менялся много лет Это только со слов автора. @MarassaСкажите, обновление на 3.9.3 у вас когда произошло? За сколько до этого вы ещё благополучно пользовались этим VPN. А то ведь может и правда ваш провайдер мог что-нибудь заблокировать. Edited February 19 by keenet07 Quote Link to comment Share on other sites More sharing options...
Mamay Posted February 19 Share Posted February 19 Вообще-то, согласно местных правил, мы должны ТС сразу отправить с актуальной версией в ТП, так как тут обсуждают лишь альфы и беты! Давайте не будем гадать на кофейной гуще и лишать работы людей... 1 Quote Link to comment Share on other sites More sharing options...
keenet07 Posted February 19 Share Posted February 19 (edited) Т.к. автор написал в ветку Обмена опытом, а не в ветку для Баг репортов, то почему бы и не рассмотреть альтернативные варианты решения проблемы и не попытаться помочь. К тому же наши рассуждения в теме помогают более подробно раскрыть обстоятельства. А селф-тест пока запрошен не был. Edited February 19 by keenet07 1 1 Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 16 минут назад, keenet07 сказал: Выложите сюда в текстовом виде ваш конфиг OpenVPN, предварительно убрав из него всю чувствительную информацию. Эх, знать бы еще что в нем чувствительное, а что нет dev tun fast-io persist-key persist-tun nobind remote usa-newyork-ca-version-2.expressnetw.com 1195 remote-random pull comp-lzo no tls-client verify-x509-name Server name-prefix ns-cert-type server key-direction 1 route-method exe route-delay 2 tun-mtu 1500 fragment 1300 mssfix 1200 verb 3 data-ciphers-fallback AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 auth SHA512 sndbuf 524288 rcvbuf 524288 <cert> -----BEGIN CERTIFICATE----- -----END CERTIFICATE----- </cert> <key> -----BEGIN RSA PRIVATE KEY----- -----END RSA PRIVATE KEY----- </key> <tls-auth> # # 2048 bit OpenVPN static key # -----BEGIN OpenVPN Static key V1----- -----END OpenVPN Static key V1----- </tls-auth> <ca> -----BEGIN CERTIFICATE----- -----END CERTIFICATE----- </ca> <auth-user-pass> ******************** ******************** </auth-user-pass> Quote Link to comment Share on other sites More sharing options...
Mamay Posted February 19 Share Posted February 19 Только что, keenet07 сказал: Т.к. автор написал в ветку Обмена опытом, а не в ветку для Баг репортов, то почему бы и не рассмотреть альтернативные варианты решения проблемы и не попытаться помочь. Пытаюсь не в первый раз уже ТС помогать. Пару раз вышло, нынче что-то выходит туго. Мы просто теряем время... 1 Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 14 минуты назад, keenet07 сказал: обновление на 3.9.3 у вас когда произошло? Вот в этом-то и главная загадка. Утром 18.02 всё ещё работало. Потом перестало, и я начал с перезагрузки роутера. Потом пришло сообщение, что роутер обновился на 3.9.3. То есть вроде бы как обновился он ПОСЛЕ того, как я начал разбираться с неполадками. Но по опыту сообщения эти частенько приходят с задержками, а когда я полез в лог, этой информации там уже не было. И теперь я смутно припоминаю, что мог перегружать роутер тем же утром как раз ДО того, как начались проблемы... 18 минут назад, keenet07 сказал: А то ведь может и правда ваш провайдер мог что-нибудь заблокировать. Я сразу же обратился к провайдеру, он сказал, что сами они ничего не блокировали, но весь трафик с января идет через ТСПУ, а что там происходит провайдеру недоступно. Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 11 минуту назад, Mamay сказал: тут обсуждают лишь альфы и беты! Так я уж на альфе по Вашему совету Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 5 минут назад, Mamay сказал: Пару раз вышло, нынче что-то выходит туго Верю, что и в этот раз выйдет! Quote Link to comment Share on other sites More sharing options...
keenet07 Posted February 19 Share Posted February 19 3 минуты назад, Marassa сказал: Я сразу же обратился к провайдеру, он сказал, что сами они ничего не блокировали, но весь трафик с января идет через ТСПУ, а что там происходит провайдеру недоступно. Чаще блокируют на магистральных провайдерах, а не на местных. Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 22 минуты назад, keenet07 сказал: может и правда ваш провайдер мог что-нибудь заблокировать. Тут ведь вот какой нюанс: приложение ExpressVPN через того же провайдера работает блестяще, и по Lightway, и по OpenVPN TCP/UDP. Каким образом провайдер мог заблокировать трафик OpenVPN, обработанный кинетиком, и не блокировать тот же трафик, обработанный приложением на андроиде? Quote Link to comment Share on other sites More sharing options...
keenet07 Posted February 19 Share Posted February 19 Только что, Marassa сказал: Тут ведь вот какой нюанс: приложение ExpressVPN через того же провайдера работает блестяще, и по Lightway, и по OpenVPN TCP/UDP. Каким образом провайдер мог заблокировать трафик OpenVPN, обработанный кинетиком, и не блокировать тот же трафик, обработанный приложением на андроиде? Так вы с телефона по WIFI проверяли? Не по мобильному интернету? Quote Link to comment Share on other sites More sharing options...
Marassa Posted February 19 Author Share Posted February 19 Только что, keenet07 сказал: Так вы с телефона по WIFI проверяли? Не по мобильному интернету? Да, конечно! И не только с телефона, а и с планшета без симки. Так что фактор кривых рук исключен) Quote Link to comment Share on other sites More sharing options...
keenet07 Posted February 19 Share Posted February 19 2 минуты назад, Marassa сказал: Да, конечно! И не только с телефона, а и с планшета без симки. Так что фактор кривых рук исключен) В таком случае вариант с блокировкой отпадает. Quote Link to comment Share on other sites More sharing options...
