Товарищи, а есть-ли у кого проблема на 4.0 Alpha 10 c OVPN подключением. Есть VPN от Surfshark ранее вроде все работало, сейчас не пашет (трафик по нулям, время соединения тоже ну и статус "Нет соединения")
Думал проблема с блокировкой от РТ но на Windows машине за роутером работает.
i81
[spoiler=Конфиг]
[code]client
dev tun
proto udp
remote tr-ist.prod.surfshark.com 1194
resolv-retry infinite
remote-random
pull-filter ignore 'block-outside-dns'
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
ping 15
ping-restart 0
ping-timer-rem
reneg-sec 0
remote-cert-tls server
<auth-user-pass>
Логин
Пароль
</auth-user-pass>
#comp-lzo
verb 3
pull
fast-io
cipher AES-256-CBC
auth SHA512
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
key-direction 1
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-auth>[/code][/spoiler]
Попробовал вместо cipher AES-256-CBC написать data-ciphers-fallback AES-256-CBC - результат тот же
[spoiler=log][code][I] Feb 25 15:45:16 ndm: Core::Syslog: the system log has been cleared.
[I] Feb 25 15:45:31 ndm: Network::Interface::Supplicant: "OpenVPN0": authentication is unchanged.
[I] Feb 25 15:45:31 ndm: Network::Interface::Base: "OpenVPN0": description saved.
[I] Feb 25 15:45:31 ndm: Network::Interface::Base: "OpenVPN0": deleted all roles.
[I] Feb 25 15:45:31 ndm: Network::Interface::Base: "OpenVPN0": assigned role "misc" for OpenVPN0.
[I] Feb 25 15:45:31 ndm: Network::Interface::Ip: "OpenVPN0": IP address cleared.
[I] Feb 25 15:45:31 ndm: Network::Interface::Base: "OpenVPN0": static MTU reset to default.
[I] Feb 25 15:45:31 ndm: Dns::InterfaceSpecific: "OpenVPN0": cleared static name server list.
[I] Feb 25 15:45:31 ndm: Network::Interface::Ip: "OpenVPN0": TCP-MSS adjustment enabled.
[I] Feb 25 15:45:31 ndm: OpenVpn::Interface: "OpenVPN0": configuration successfully saved.
[I] Feb 25 15:45:31 ndm: OpenVpn::Interface: "OpenVPN0": enable automatic routes accept via tunnel.
[I] Feb 25 15:45:31 ndm: OpenVpn::Interface: "OpenVPN0": set connection via any interface.
[I] Feb 25 15:45:31 ndm: Network::Interface::Base: "OpenVPN0": schedule cleared.
[I] Feb 25 15:45:31 ndm: Core::System::StartupConfig: saving (http/rci).
[W] Feb 25 15:45:33 ndm: Process: "OpenVPN0" has been killed.
[I] Feb 25 15:45:34 ndm: Core::System::StartupConfig: configuration saved.
[I] Feb 25 15:45:35 OpenVPN0: OpenVPN 2.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
[I] Feb 25 15:45:35 OpenVPN0: library versions: OpenSSL 3.0.8 7 Feb 2023, LZO 2.10 [/code][/spoiler]
7 answers to this question
