Обновление роутера на 4.0.11, два канала интернет один в WAN порт и PPPoE основное (плюс на нем проверял расписание с 00:00 до 07:00) и провод DHCP от второго провайдера резервное плюс
1. PPPoE (WAN) - основной и подняты OpenVPN0 и Wireguard0 (Warp) + поднят Wireguard4 (Proton) + расписание 00:00 - 07:00
2. ISP (Inet-2/GigabitEthernet0/Vlan9) - резервный канал
3. WifiMaster1/AccessPoint0 - расписание 00:00 - 07:00
имеем такое поведение системы :
Сработало расписание на 00:00 на PPPoE и на WifiMaster1/AccessPoint0
[I] Mar 3 23:59:22 kernel: Core::Syslog: last message repeated 2 times.
[I] Mar 4 00:00:00 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster1/AccessPoint0": STA(хх:хх:хх:хх:хх:ab) had disassociated by AP (reason: due to inactivity).
[I] Mar 4 00:00:00 kernel: br0: port 3(rai0) entered disabled state
[I] Mar 4 00:00:00 ndm: Network::Interface::Base: "WifiMaster1/AccessPoint0": "schedule" changed "conf" layer state "running" to "pending".
[I] Mar 4 00:00:00 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster1/AccessPoint0": STA(хх:хх:хх:хх:хх:6c) had disassociated by AP (reason: due to inactivity).
[I] Mar 4 00:00:00 pppd[888]: Modem hangup
[I] Mar 4 00:00:00 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "running" to "pending".
[I] Mar 4 00:00:00 ndm: Network::Interface::Ppp: "PPPoE0": connection service standby.
[I] Mar 4 00:00:00 pppd[888]: Connect time 126.7 minutes.
[I] Mar 4 00:00:00 pppd[888]: Sent 93802173 bytes, received 3916587284 bytes.
[I] Mar 4 00:00:00 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "pending" to "running".
[I] Mar 4 00:00:00 ndm: Network::Interface::Base: "PPPoE0": "schedule" changed "conf" layer state "running" to "pending".
[I] Mar 4 00:00:00 pppd[888]: Connection terminated.
[I] Mar 4 00:00:00 pppd[888]: Sent PADT
[I] Mar 4 00:00:00 ndm: Network::Interface::Ip: "PPPoE0": IP address cleared.
[I] Mar 4 00:00:00 pppd[888]: Terminating on signal 15
[I] Mar 4 00:00:00 pppd[888]: Exit.
2. Напомню есть резервный канал -> основной профиль и приоритеты каналов в нем
interface PPPoE0
description RT
role inet
ip global 65431
interface GigabitEthernet0/Vlan9
description Inet-2
ip global 65380
3. Cамое интересное - поведение интерфейсов в данной конфигурации
[I] Mar 4 00:00:00 ndm: Wireguard::Interface: "Wireguard0": underlying interface "PPPoE0" of peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" is down, reconnecting.
[I] Mar 4 00:00:00 ndm: Network::RoutingTable: deleted route: 162.159.193.9/32 via PPPoE0.
[I] Mar 4 00:00:00 ndm: Wireguard::Interface: "Wireguard0": added a host route to peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (162.159.193.9) via 10.10.8.1 (GigabitEthernet0/Vlan9).
[I] Mar 4 00:00:00 ndm: Wireguard::Interface: "Wireguard4": underlying interface "PPPoE0" of peer "YBI............iLDY=" is down, reconnecting.
[I] Mar 4 00:00:00 ndm: Network::RoutingTable: deleted route: 169.СерверProton/32 via PPPoE0.
[I] Mar 4 00:00:00 ndm: Wireguard::Interface: "Wireguard4": added a host route to peer "YBI.....iLDY=" (169.СерверProton) via 10.10.8.1 (GigabitEthernet0/Vlan9).
[I] Mar 4 00:00:00 ndm: Network::Interface::Ip: "PPPoE0": removing default route via PPPoE0.
[I] Mar 4 00:00:00 ndm: Network::Interface::Base: "PPPoE0": interface pending by "schedule".
[I] Mar 4 00:00:00 ndm: Network::InterfaceFlusher: flushed PPPoE0 conntrack and route cache.
[I] Mar 4 00:00:00 ndm: Network::InternetChecker: Internet access lost (status: 0x0000).
[I] Mar 4 00:00:00 upnp: shutting down MiniUPnPd
[I] Mar 4 00:00:00 ndm: Core::Session: client disconnected.
[I] Mar 4 00:00:00 ndm: Network::InterfaceFlusher: flushed GigabitEthernet0/Vlan9 conntrack and route cache.
[I] Mar 4 00:00:00 ndm: Network::InternetChecker: Internet access detected.
[I] Mar 4 00:00:00 ndm: Http::Nginx: loaded SSL certificate for "01....................1b.keenetic.io".
[I] Mar 4 00:00:00 ndm: Http::Nginx: loaded SSL certificate for "XXXXXXXXXXX.keenetic.pro".
Закрытие OpenVPN
[I] Mar 4 00:00:00 ndm: Network::Interface::Ip: "OpenVPN0": IP address cleared.
[I] Mar 4 00:00:00 ndm: OpenVpn::Routing4: "OpenVPN0": remove installed accepted routes.
[E] Mar 4 00:00:00 OpenVPN0: event_wait : Interrupted system call (fd=-1,code=4)
[I] Mar 4 00:00:00 OpenVPN0: /tmp/openvpn/OpenVPN0/openvpn-down tun0 1500 0 192.168.116.74 255.255.248.0 init
[I] Mar 4 00:00:01 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Mar 4 00:00:01 ndm: Core::Session: client disconnected.
[I] Mar 4 00:00:01 OpenVPN0: SIGTERM[hard,] received, process exiting
[I] Mar 4 00:00:01 ndm: OpenVpn::Interface: "OpenVPN0": via interface is not ready, standby.
[I] Mar 4 00:00:01 ndm: Http::Manager: updated configuration.
[I] Mar 4 00:00:01 ndm: Network::RoutingTable: cleanup route to 8.8.8.8/32 via 192.168.112.1 ovpn_br0.
[I] Mar 4 00:00:01 ndm: Network::RoutingTable: cleanup route to 192.168.104.1/32 via 192.168.112.1 ovpn_br0.
[I] Mar 4 00:00:01 ndm: Network::RoutingTable: cleanup route to 10.224.0.0/15 via 192.168.112.1 ovpn_br0.
Очистка маршрутов OpenVPN
[I] Mar 4 00:00:01 ndm: Network::RoutingTable: cleanup route to 74.82.64.0/19 via 192.168.112.1 ovpn_br0.
[I] Mar 4 00:00:01 ndm: Http::Nginx: loaded SSL certificate for "01......1b.keenetic.io".
[I] Mar 4 00:00:01 ndm: Http::Nginx: loaded SSL certificate for ".......keenetic.pro".
[I] Mar 4 00:00:02 ndm: Http::Manager: updated configuration.
[I] Mar 4 00:00:02 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Mar 4 00:00:02 ndm: Core::Session: client disconnected.
[I] Mar 4 00:00:02 upnp: HTTP listening on port 1900
[I] Mar 4 00:00:02 upnp: Listening for NAT-PMP/PCP traffic on port 5351
[I] Mar 4 00:00:10 kernel: wireguard: Wireguard0: retrying handshake with peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (7) (162.159.193.9:хххх) because we stopped hearing back after 15 seconds
[I] Mar 4 00:00:16 kernel: wireguard: Wireguard0: handshake for peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (7) (162.159.193.9:хххх) did not complete after 5 seconds, retrying (try 2)
[I] Mar 4 00:00:38 ndm: Http::Nginx: loaded SSL certificate for "01....1b.keenetic.io".
[I] Mar 4 00:00:39 ndm: Http::Nginx: loaded SSL certificate for "............keenetic.pro".
[I] Mar 4 00:00:39 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Mar 4 00:00:39 ndm: Core::Session: client disconnected.
[I] Mar 4 00:00:39 ndm: Http::Manager: updated configuration.
[I] Mar 4 00:43:23 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec.
[I] Mar 4 03:23:25 ndhcpc: Core::Syslog: last message repeated 16 times.
[I] Mar 4 03:33:25 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec.
[I] Mar 4 03:43:25 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec.
[E] Mar 4 03:50:15 ndm: Io::TcpSocket: failed to connect: operation in progress.
[E] Mar 4 03:50:15 ndm: Cloud::Tunnel: "NDMP/9хххххххa": failed to connect to 95.217.20.77:9801 (RAW): operation timeout.
[C] Mar 4 03:50:15 ndm: Cloud::DialTunnel: system failed [0xcffd00c9].
[I] Mar 4 03:53:25 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec.
[I] Mar 4 04:00:13 kernel: wireguard: Wireguard4: handshake for peer "YBI......iLDY=" (8) (169.СерверProton) did not complete after 5 seconds, retrying (try 2)
[I] Mar 4 04:00:19 kernel: wireguard: Wireguard4: handshake for peer "YBI.....iLDY=" (8) (169.СерверProton) did not complete after 5 seconds, retrying (try 3)
[I] Mar 4 04:00:24 kernel: wireguard: Wireguard4: handshake for peer "YBI.....iLDY=" (8) (169.СерверProton) did not complete after 5 seconds, retrying (try 4)
[I] Mar 4 04:03:26 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec.
[I] Mar 4 04:06:06 kernel: wireguard: Wireguard0: handshake for peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (7) (162.159.193.9:хххх) did not complete after 5 seconds, retrying (try 2)
[I] Mar 4 04:10:14 kernel: wireguard: Wireguard0: handshake for peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (7) (162.159.193.9:хххх) did not complete after 5 seconds, retrying (try 2)
[I] Mar 4 04:13:26 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec.
[I] Mar 4 05:03:26 ndhcpc: Core::Syslog: last message repeated 5 times.
[E] Mar 4 05:10:21 ndm: Io::TcpSocket: failed to connect: operation in progress.
[E] Mar 4 05:10:21 ndm: Cloud::Tunnel: "NDMP/eххххххх9": failed to connect to 95.217.20.77:9801 (RAW): operation timeout.
[C] Mar 4 05:10:21 ndm: Cloud::DialTunnel: system failed [0xcffd00c9].
[I] Mar 4 05:13:26 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec.
[I] Mar 4 06:13:27 ndhcpc: Core::Syslog: last message repeated 6 times.
В итоге PPPoE как основного нет, он потянул за собой OpenVPN0 и Wireguard0 и Wireguard4 (так и должно быть) так как доступ к их серверам был через стат маршрут интерфейса PPPoE. Никакого переключения на резервный канал не было ISP (Inet-2/GigabitEthernet0/Vlan9) до 07:00. Так же это потянуло за собой и Cloud::Tunnel.
4. 07:00 отработало расписание по включению PPPoE и WifiMaster1/AccessPoint0
Сработало расписание на 07:00
[I] Mar 4 06:53:28 ndhcpc: Core::Syslog: last message repeated 3 times.
[I] Mar 4 07:00:00 kernel: IPv6: ADDRCONF(NETDEV_UP): rai0: link is not ready
[I] Mar 4 07:00:00 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): rai0: link becomes ready
[I] Mar 4 07:00:00 ndm: Network::Interface::Base: "WifiMaster1/AccessPoint0": "schedule" changed "conf" layer state "pending" to "running".
[I] Mar 4 07:00:00 kernel: br0: port 3(rai0) entered blocking state
[I] Mar 4 07:00:00 kernel: br0: port 3(rai0) entered listening state
[I] Mar 4 07:00:00 ndm: Network::Interface::Base: "PPPoE0": "schedule" changed "conf" layer state "pending" to "running".
[I] Mar 4 07:00:02 wind: version 1.0.3 started on br0.
[I] Mar 4 07:00:02 pppd[11305]: Plugin rp-pppoe.so loaded.
[I] Mar 4 07:00:02 pppd[11305]: pppd 2.4.4-4 started by root, uid 0
[I] Mar 4 07:00:02 pppd[11305]: Found unterminated session: 30539:90:хх:хх:хх:хх:ed
[I] Mar 4 07:00:03 pppd[11305]: Sent PADT
[I] Mar 4 07:00:03 kernel: br0: port 3(rai0) entered learning state
[I] Mar 4 07:00:03 pppd[11305]: PPP session is 28750
[I] Mar 4 07:00:03 pppd[11305]: Using interface ppp0
[I] Mar 4 07:00:03 pppd[11305]: Connect: ppp0 <--> eth3
[I] Mar 4 07:00:03 ndm: Network::Interface::Base: "PPPoE0": interface is up.
[I] Mar 4 07:00:03 ndm: Network::Interface::Ip: "PPPoE0": interface "PPPoE0" is global, priority 65431.
[I] Mar 4 07:00:03 ndm: Network::Interface::Ip: "PPPoE0": adding default route via PPPoE0.
[I] Mar 4 07:00:03 ndm: Network::Interface::Ip: "PPPoE0": IP address is ххх.ххх.ххх.202/32.
[I] Mar 4 07:00:03 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "connecting" to "running".
[I] Mar 4 07:00:03 ndm: Network::InterfaceFlusher: flushed GigabitEthernet0/Vlan9 conntrack and route cache.
[I] Mar 4 07:00:03 ndm: Network::InternetChecker: Internet access lost (status: 0x0000).
[I] Mar 4 07:00:03 upnp: shutting down MiniUPnPd
[I] Mar 4 07:00:03 ndm: Core::Session: client disconnected.
[I] Mar 4 07:00:03 ndm: Wireguard::Interface: "Wireguard0": reconnecting peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" via "PPPoE0".
[I] Mar 4 07:00:03 ndm: Network::RoutingTable: deleted route: 162.159.193.9/32 via 10.10.8.1 (GigabitEthernet0/Vlan9).
[I] Mar 4 07:00:03 ndm: Wireguard::Interface: "Wireguard0": added a host route to peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (162.159.193.9) via PPPoE0 (PPPoE0).
[I] Mar 4 07:00:03 ndm: Wireguard::Interface: "Wireguard4": reconnecting peer "YBI..........iLDY=" via "PPPoE0".
[I] Mar 4 07:00:03 ndm: Network::RoutingTable: deleted route: 169.СерверProton/32 via 10.10.8.1 (GigabitEthernet0/Vlan9).
[I] Mar 4 07:00:03 ndm: Wireguard::Interface: "Wireguard4": added a host route to peer "YBI.......iLDY=" (169.СерверProton) via PPPoE0 (PPPoE0).
[I] Mar 4 07:00:03 ndm: Network::InternetChecker: Internet access detected.
[I] Mar 4 07:00:04 ndm: Http::Nginx: loaded SSL certificate for "01.......b.keenetic.io".
[I] Mar 4 07:00:04 ndm: Http::Nginx: loaded SSL certificate for "xxxxxxxxx.keenetic.pro".
[I] Mar 4 07:00:04 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Mar 4 07:00:04 ndm: Core::Session: client disconnected.
[I] Mar 4 07:00:04 ndm: Http::Manager: updated configuration.
[I] Mar 4 07:00:05 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Mar 4 07:00:05 upnp: HTTP listening on port 1900
[I] Mar 4 07:00:05 upnp: Listening for NAT-PMP/PCP traffic on port 5351
В итоге два Wireguard0 и Wireguard4 поднялись - так как стат маршрут до их серверов сработал через PPPoE :
Wireguard0 - канал через PPPoE
Wireguard4 - канал GigabitEthernet0/Vlan9
OpenVPN чуток не понятно с отображением в WEB (надо еще проверить), но так же поднялся
[I] Mar 4 07:00:06 OpenVPN0: OpenVPN 2.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
[I] Mar 4 07:00:06 OpenVPN0: library versions: OpenSSL 3.0.8 7 Feb 2023, LZO 2.10
[I] Mar 4 07:00:06 OpenVPN0: Attempting to establish TCP connection with [AF_INET]51.75.75.245:1194
[I] Mar 4 07:00:06 kernel: br0: port 3(rai0) entered forwarding state
[I] Mar 4 07:00:06 kernel: br0: topology change detected, propagating
[I] Mar 4 07:00:06 OpenVPN0: TCP connection established with [AF_INET]51.75.75.245:1194
[I] Mar 4 07:00:06 OpenVPN0: TCPv4_CLIENT link local (bound): [AF_INET]ххх.PPPoE.ххх.ххх:48920
[I] Mar 4 07:00:06 OpenVPN0: TCPv4_CLIENT link remote: [AF_INET]51.75.75.245:1194
[I] Mar 4 07:00:06 OpenVPN0: NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
[I] Mar 4 07:00:07 OpenVPN0: [antizapret-server] Peer Connection Initiated with [AF_INET]51.75.75.245:1194
[I] Mar 4 07:00:07 ndm: OpenVpn::Routing4: "OpenVPN0": connecting via PPPoE0 (PPPoE0).
[I] Mar 4 07:00:07 ndm: OpenVpn::Routing4: "OpenVPN0": added host route to remote endpoint 51.75.75.245 via PPPoE0.
[I] Mar 4 07:00:08 OpenVPN0: TUN/TAP device tun0 opened
[I] Mar 4 07:00:08 OpenVPN0: net_iface_mtu_set: mtu 1500 for tun0
[I] Mar 4 07:00:08 ndm: Network::Interface::Ip: "OpenVPN0": IP address is 192.168.108.183/21.
[I] Mar 4 07:00:08 OpenVPN0: /tmp/openvpn/OpenVPN0/openvpn-up tun0 1500 0 192.168.108.183 255.255.248.0 init
[I] Mar 4 07:00:08 ndm: OpenVpn::Routing4: "OpenVPN0": install accepted route to 8.8.8.8/255.255.255.255 via 192.168.104.1.
[I] Mar 4 07:00:08 ndm: OpenVpn::Routing4: "OpenVPN0": install accepted route to 10.224.0.0/255.254.0.0 via 192.168.104.1.
Полученв маршруты
[I] Mar 4 07:00:08 ndm: OpenVpn::Routing4: "OpenVPN0": install accepted route to 74.82.64.0/255.255.224.0 via 192.168.104.1.
[I] Mar 4 07:00:08 OpenVPN0: UID set to nobody
[I] Mar 4 07:00:08 OpenVPN0: GID set to nobody
[I] Mar 4 07:00:08 OpenVPN0: Capabilities retained: CAP_NET_ADMIN
[I] Mar 4 07:00:08 OpenVPN0: Initialization Sequence Completed
При отработке в ручном режиме - отключение основного PPPoE (через WEB) все переключилось на резервный GigabitEthernet0/Vlan9 и поднялись Wireguard0 с Wireguard4. C OpenVPN речь отдельная пока не понятно что с ним.
Включение основного (опять через WEB) PPPoE все вернулось через него.
OpenVPN - не понятно пока
Мар 4 09:55:51 OpenVPN0 OpenVPN 2.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Мар 4 09:55:51 OpenVPN0 library versions: OpenSSL 3.0.8 7 Feb 2023, LZO 2.10
Мар 4 09:55:51 OpenVPN0 Attempting to establish TCP connection with [AF_INET]51.158.181.161:1194
Мар 4 09:55:51 OpenVPN0 TCP connection established with [AF_INET]51.158.181.161:1194
Мар 4 09:55:51 OpenVPN0 TCPv4_CLIENT link local (bound): [AF_INET]ххх.PPPoE:48920
Мар 4 09:55:51 OpenVPN0 TCPv4_CLIENT link remote: [AF_INET]51.158.181.161:1194
Мар 4 09:55:51 OpenVPN0 NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
Мар 4 09:55:52 OpenVPN0 [antizapret-server] Peer Connection Initiated with [AF_INET]51.158.181.161:1194
Мар 4 09:55:52 ndm OpenVpn::Routing4: "OpenVPN0": connecting via PPPoE0 (PPPoE0).
Мар 4 09:55:52 ndm OpenVpn::Routing4: "OpenVPN0": added host route to remote endpoint 51.158.181.161 via PPPoE0.
Мар 4 09:55:53 OpenVPN0 TUN/TAP device tun0 opened
Мар 4 09:55:53 OpenVPN0 net_iface_mtu_set: mtu 1500 for tun0
Мар 4 09:55:53 ndm Network::Interface::Ip: "OpenVPN0": IP address is 192.168.124.218/21.
Мар 4 09:55:53 OpenVPN0 /tmp/openvpn/OpenVPN0/openvpn-up tun0 1500 0 192.168.124.218 255.255.248.0 init
Мар 4 09:55:53 ndm OpenVpn::Routing4: "OpenVPN0": install accepted route to 8.8.8.8/255.255.255.255 via 192.168.120.1.
Мар 4 09:55:53 ndm OpenVpn::Routing4: "OpenVPN0": install accepted route to 192.168.104.1/255.255.255.255 via 192.168.120.1.
Мар 4 09:55:53 ndm OpenVpn::Routing4: "OpenVPN0": install accepted route to 10.224.0.0/255.254.0.0 via 192.168.120.1.
Куча полученных маршрутов
Мар 4 09:55:53 ndm OpenVpn::Routing4: "OpenVPN0": install accepted route to 74.82.64.0/255.255.224.0 via 192.168.120.1.
Мар 4 09:55:53 OpenVPN0 UID set to nobody
Мар 4 09:55:53 OpenVPN0 GID set to nobody
Мар 4 09:55:53 OpenVPN0 Capabilities retained: CAP_NET_ADMIN
Мар 4 09:55:53 OpenVPN0 Initialization Sequence Completed
Но в реале маршрутов нет и в WEB
~ # ip ro
default dev ppp0 scope link
10.10.8.0/24 dev eth2.9 proto kernel scope link src 10.10.8.13
51.158.181.161 dev ppp0 scope link **** Сервер для OpenVPN
162.159.193.9 dev ppp0 scope link **** Сервер WG0
169.СерверProton dev ppp0 scope link **** Сервер WG4
192.168.120.0/21 dev ovpn_br0 proto kernel scope link src 192.168.124.218 **** OpenVPN
192.168.130.0/24 dev br0 proto kernel scope link src 192.168.130.101
192.168.130.101 dev nwg0 scope link
ovpn_br0 Link encap:Ethernet HWaddr хх:хх:хх:хх:хх:CF
inet addr:192.168.124.218 P-t-P:192.168.124.218 Bcast:0.0.0.0 Mask:255.255.248.0
UP BROADCAST POINTOPOINT RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:232 (232.0 B)
~ # ping 192.168.120.1
PING 192.168.120.1 (192.168.120.1): 56 data bytes
64 bytes from 192.168.120.1: seq=0 ttl=64 time=67.334 ms
64 bytes from 192.168.120.1: seq=1 ttl=64 time=101.969 ms
^C
--- 192.168.120.1 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 67.334/84.651/101.969 ms
~ # traceroute 192.168.120.1
traceroute to 192.168.120.1 (192.168.120.1), 30 hops max, 46 byte packets
1 192.168.120.1 (192.168.120.1) 66.826 ms 67.227 ms 68.861 ms
~ # ip ro add 8.8.8.8/32 dev ovpn_br0
~ # ip ro
8.8.8.8 dev ovpn_br0 scope link
~ # traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 46 byte packets
1 192.168.120.1 (192.168.120.1) 74.320 ms 67.464 ms 81.577 ms
2 192.168.120.1 (192.168.120.1) 78.635 ms 67.636 ms 66.933 ms
vasek00
[I] Mar 3 23:59:22 kernel: Core::Syslog: last message repeated 2 times. [I] Mar 4 00:00:00 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster1/AccessPoint0": STA(хх:хх:хх:хх:хх:ab) had disassociated by AP (reason: due to inactivity). [I] Mar 4 00:00:00 kernel: br0: port 3(rai0) entered disabled state [I] Mar 4 00:00:00 ndm: Network::Interface::Base: "WifiMaster1/AccessPoint0": "schedule" changed "conf" layer state "running" to "pending". [I] Mar 4 00:00:00 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster1/AccessPoint0": STA(хх:хх:хх:хх:хх:6c) had disassociated by AP (reason: due to inactivity). [I] Mar 4 00:00:00 pppd[888]: Modem hangup [I] Mar 4 00:00:00 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "running" to "pending". [I] Mar 4 00:00:00 ndm: Network::Interface::Ppp: "PPPoE0": connection service standby. [I] Mar 4 00:00:00 pppd[888]: Connect time 126.7 minutes. [I] Mar 4 00:00:00 pppd[888]: Sent 93802173 bytes, received 3916587284 bytes. [I] Mar 4 00:00:00 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "pending" to "running". [I] Mar 4 00:00:00 ndm: Network::Interface::Base: "PPPoE0": "schedule" changed "conf" layer state "running" to "pending". [I] Mar 4 00:00:00 pppd[888]: Connection terminated. [I] Mar 4 00:00:00 pppd[888]: Sent PADT [I] Mar 4 00:00:00 ndm: Network::Interface::Ip: "PPPoE0": IP address cleared. [I] Mar 4 00:00:00 pppd[888]: Terminating on signal 15 [I] Mar 4 00:00:00 pppd[888]: Exit.
interface PPPoE0 description RT role inet ip global 65431 interface GigabitEthernet0/Vlan9 description Inet-2 ip global 65380
[I] Mar 4 00:00:00 ndm: Wireguard::Interface: "Wireguard0": underlying interface "PPPoE0" of peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" is down, reconnecting. [I] Mar 4 00:00:00 ndm: Network::RoutingTable: deleted route: 162.159.193.9/32 via PPPoE0. [I] Mar 4 00:00:00 ndm: Wireguard::Interface: "Wireguard0": added a host route to peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (162.159.193.9) via 10.10.8.1 (GigabitEthernet0/Vlan9). [I] Mar 4 00:00:00 ndm: Wireguard::Interface: "Wireguard4": underlying interface "PPPoE0" of peer "YBI............iLDY=" is down, reconnecting. [I] Mar 4 00:00:00 ndm: Network::RoutingTable: deleted route: 169.СерверProton/32 via PPPoE0. [I] Mar 4 00:00:00 ndm: Wireguard::Interface: "Wireguard4": added a host route to peer "YBI.....iLDY=" (169.СерверProton) via 10.10.8.1 (GigabitEthernet0/Vlan9). [I] Mar 4 00:00:00 ndm: Network::Interface::Ip: "PPPoE0": removing default route via PPPoE0. [I] Mar 4 00:00:00 ndm: Network::Interface::Base: "PPPoE0": interface pending by "schedule". [I] Mar 4 00:00:00 ndm: Network::Interface::Ppp: "PPPoE0": connection service standby. [I] Mar 4 00:00:00 ndm: Network::InterfaceFlusher: flushed PPPoE0 conntrack and route cache. [I] Mar 4 00:00:00 ndm: Network::InternetChecker: Internet access lost (status: 0x0000). [I] Mar 4 00:00:00 upnp: shutting down MiniUPnPd [I] Mar 4 00:00:00 ndm: Core::Session: client disconnected. [I] Mar 4 00:00:00 ndm: Network::InterfaceFlusher: flushed GigabitEthernet0/Vlan9 conntrack and route cache. [I] Mar 4 00:00:00 ndm: Network::InterfaceFlusher: flushed PPPoE0 conntrack and route cache. [I] Mar 4 00:00:00 ndm: Network::InternetChecker: Internet access detected. [I] Mar 4 00:00:00 ndm: Http::Nginx: loaded SSL certificate for "01....................1b.keenetic.io". [I] Mar 4 00:00:00 ndm: Http::Nginx: loaded SSL certificate for "XXXXXXXXXXX.keenetic.pro". Закрытие OpenVPN [I] Mar 4 00:00:00 ndm: Network::Interface::Ip: "OpenVPN0": IP address cleared. [I] Mar 4 00:00:00 ndm: OpenVpn::Routing4: "OpenVPN0": remove installed accepted routes. [E] Mar 4 00:00:00 OpenVPN0: event_wait : Interrupted system call (fd=-1,code=4) [I] Mar 4 00:00:00 OpenVPN0: /tmp/openvpn/OpenVPN0/openvpn-down tun0 1500 0 192.168.116.74 255.255.248.0 init [I] Mar 4 00:00:01 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 00:00:01 ndm: Core::Session: client disconnected. [I] Mar 4 00:00:01 OpenVPN0: SIGTERM[hard,] received, process exiting [I] Mar 4 00:00:01 ndm: OpenVpn::Interface: "OpenVPN0": via interface is not ready, standby. [I] Mar 4 00:00:01 ndm: Http::Manager: updated configuration. [I] Mar 4 00:00:01 ndm: Network::RoutingTable: cleanup route to 8.8.8.8/32 via 192.168.112.1 ovpn_br0. [I] Mar 4 00:00:01 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 00:00:01 ndm: Network::RoutingTable: cleanup route to 192.168.104.1/32 via 192.168.112.1 ovpn_br0. [I] Mar 4 00:00:01 ndm: Network::RoutingTable: cleanup route to 10.224.0.0/15 via 192.168.112.1 ovpn_br0. Очистка маршрутов OpenVPN [I] Mar 4 00:00:01 ndm: Network::RoutingTable: cleanup route to 74.82.64.0/19 via 192.168.112.1 ovpn_br0. [I] Mar 4 00:00:01 ndm: Core::Session: client disconnected. [I] Mar 4 00:00:01 ndm: Http::Nginx: loaded SSL certificate for "01......1b.keenetic.io". [I] Mar 4 00:00:01 ndm: Http::Nginx: loaded SSL certificate for ".......keenetic.pro". [I] Mar 4 00:00:01 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 00:00:01 ndm: Core::Session: client disconnected. [I] Mar 4 00:00:02 ndm: Http::Manager: updated configuration. [I] Mar 4 00:00:02 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 00:00:02 ndm: Core::Session: client disconnected. [I] Mar 4 00:00:02 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 00:00:02 upnp: HTTP listening on port 1900 [I] Mar 4 00:00:02 upnp: Listening for NAT-PMP/PCP traffic on port 5351 [I] Mar 4 00:00:10 kernel: wireguard: Wireguard0: retrying handshake with peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (7) (162.159.193.9:хххх) because we stopped hearing back after 15 seconds [I] Mar 4 00:00:16 kernel: wireguard: Wireguard0: handshake for peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (7) (162.159.193.9:хххх) did not complete after 5 seconds, retrying (try 2) [I] Mar 4 00:00:38 ndm: Http::Nginx: loaded SSL certificate for "01....1b.keenetic.io". [I] Mar 4 00:00:39 ndm: Http::Nginx: loaded SSL certificate for "............keenetic.pro". [I] Mar 4 00:00:39 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 00:00:39 ndm: Core::Session: client disconnected. [I] Mar 4 00:00:39 ndm: Http::Manager: updated configuration. [I] Mar 4 00:00:39 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 00:00:39 ndm: Core::Session: client disconnected. [I] Mar 4 00:43:23 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec. [I] Mar 4 03:23:25 ndhcpc: Core::Syslog: last message repeated 16 times. [I] Mar 4 03:33:25 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec. [I] Mar 4 03:43:25 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec. [E] Mar 4 03:50:15 ndm: Io::TcpSocket: failed to connect: operation in progress. [E] Mar 4 03:50:15 ndm: Cloud::Tunnel: "NDMP/9хххххххa": failed to connect to 95.217.20.77:9801 (RAW): operation timeout. [C] Mar 4 03:50:15 ndm: Cloud::DialTunnel: system failed [0xcffd00c9]. [I] Mar 4 03:53:25 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec. [I] Mar 4 04:00:13 kernel: wireguard: Wireguard4: handshake for peer "YBI......iLDY=" (8) (169.СерверProton) did not complete after 5 seconds, retrying (try 2) [I] Mar 4 04:00:19 kernel: wireguard: Wireguard4: handshake for peer "YBI.....iLDY=" (8) (169.СерверProton) did not complete after 5 seconds, retrying (try 3) [I] Mar 4 04:00:24 kernel: wireguard: Wireguard4: handshake for peer "YBI.....iLDY=" (8) (169.СерверProton) did not complete after 5 seconds, retrying (try 4) [I] Mar 4 04:03:26 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec. [I] Mar 4 04:06:06 kernel: wireguard: Wireguard0: handshake for peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (7) (162.159.193.9:хххх) did not complete after 5 seconds, retrying (try 2) [I] Mar 4 04:10:14 kernel: wireguard: Wireguard0: handshake for peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (7) (162.159.193.9:хххх) did not complete after 5 seconds, retrying (try 2) [I] Mar 4 04:13:26 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec. [I] Mar 4 05:03:26 ndhcpc: Core::Syslog: last message repeated 5 times. [E] Mar 4 05:10:21 ndm: Io::TcpSocket: failed to connect: operation in progress. [E] Mar 4 05:10:21 ndm: Cloud::Tunnel: "NDMP/eххххххх9": failed to connect to 95.217.20.77:9801 (RAW): operation timeout. [C] Mar 4 05:10:21 ndm: Cloud::DialTunnel: system failed [0xcffd00c9]. [I] Mar 4 05:13:26 ndhcpc: GigabitEthernet0/Vlan9: received ACK for 10.10.8.13 from 10.10.10.100 lease 1200 sec. [I] Mar 4 06:13:27 ndhcpc: Core::Syslog: last message repeated 6 times.
[I] Mar 4 06:13:27 ndhcpc: Core::Syslog: last message repeated 6 times. Сработало расписание на 07:00 [I] Mar 4 06:53:28 ndhcpc: Core::Syslog: last message repeated 3 times. [I] Mar 4 07:00:00 kernel: IPv6: ADDRCONF(NETDEV_UP): rai0: link is not ready [I] Mar 4 07:00:00 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): rai0: link becomes ready [I] Mar 4 07:00:00 ndm: Network::Interface::Base: "WifiMaster1/AccessPoint0": "schedule" changed "conf" layer state "pending" to "running". [I] Mar 4 07:00:00 kernel: br0: port 3(rai0) entered blocking state [I] Mar 4 07:00:00 kernel: br0: port 3(rai0) entered listening state [I] Mar 4 07:00:00 ndm: Network::Interface::Base: "PPPoE0": "schedule" changed "conf" layer state "pending" to "running". [I] Mar 4 07:00:02 wind: version 1.0.3 started on br0. [I] Mar 4 07:00:02 pppd[11305]: Plugin rp-pppoe.so loaded. [I] Mar 4 07:00:02 pppd[11305]: pppd 2.4.4-4 started by root, uid 0 [I] Mar 4 07:00:02 pppd[11305]: Found unterminated session: 30539:90:хх:хх:хх:хх:ed [I] Mar 4 07:00:03 pppd[11305]: Sent PADT [I] Mar 4 07:00:03 kernel: br0: port 3(rai0) entered learning state [I] Mar 4 07:00:03 pppd[11305]: PPP session is 28750 [I] Mar 4 07:00:03 pppd[11305]: Using interface ppp0 [I] Mar 4 07:00:03 pppd[11305]: Connect: ppp0 <--> eth3 ... [I] Mar 4 07:00:03 ndm: Network::Interface::Base: "PPPoE0": interface is up. [I] Mar 4 07:00:03 ndm: Network::Interface::Ip: "PPPoE0": interface "PPPoE0" is global, priority 65431. [I] Mar 4 07:00:03 ndm: Network::Interface::Ip: "PPPoE0": adding default route via PPPoE0. [I] Mar 4 07:00:03 ndm: Network::Interface::Ip: "PPPoE0": IP address is ххх.ххх.ххх.202/32. [I] Mar 4 07:00:03 ndm: Network::Interface::Base: "PPPoE0": "ppp" changed "link" layer state "connecting" to "running". [I] Mar 4 07:00:03 ndm: Network::InterfaceFlusher: flushed GigabitEthernet0/Vlan9 conntrack and route cache. [I] Mar 4 07:00:03 ndm: Network::InternetChecker: Internet access lost (status: 0x0000). [I] Mar 4 07:00:03 upnp: shutting down MiniUPnPd [I] Mar 4 07:00:03 ndm: Core::Session: client disconnected. [I] Mar 4 07:00:03 ndm: Wireguard::Interface: "Wireguard0": reconnecting peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" via "PPPoE0". [I] Mar 4 07:00:03 ndm: Network::RoutingTable: deleted route: 162.159.193.9/32 via 10.10.8.1 (GigabitEthernet0/Vlan9). [I] Mar 4 07:00:03 ndm: Wireguard::Interface: "Wireguard0": added a host route to peer "bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo=" (162.159.193.9) via PPPoE0 (PPPoE0). [I] Mar 4 07:00:03 ndm: Wireguard::Interface: "Wireguard4": reconnecting peer "YBI..........iLDY=" via "PPPoE0". [I] Mar 4 07:00:03 ndm: Network::RoutingTable: deleted route: 169.СерверProton/32 via 10.10.8.1 (GigabitEthernet0/Vlan9). [I] Mar 4 07:00:03 ndm: Wireguard::Interface: "Wireguard4": added a host route to peer "YBI.......iLDY=" (169.СерверProton) via PPPoE0 (PPPoE0). [I] Mar 4 07:00:03 ndm: Network::InternetChecker: Internet access detected. [I] Mar 4 07:00:04 ndm: Http::Nginx: loaded SSL certificate for "01.......b.keenetic.io". [I] Mar 4 07:00:04 ndm: Http::Nginx: loaded SSL certificate for "xxxxxxxxx.keenetic.pro". [I] Mar 4 07:00:04 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 07:00:04 ndm: Core::Session: client disconnected. [I] Mar 4 07:00:04 ndm: Http::Manager: updated configuration. [I] Mar 4 07:00:04 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 07:00:04 ndm: Core::Session: client disconnected. [I] Mar 4 07:00:05 ndm: Core::Server: started Session /var/run/ndm.core.socket. [I] Mar 4 07:00:05 upnp: HTTP listening on port 1900 [I] Mar 4 07:00:05 upnp: Listening for NAT-PMP/PCP traffic on port 5351
[I] Mar 4 07:00:05 upnp: HTTP listening on port 1900 [I] Mar 4 07:00:05 upnp: Listening for NAT-PMP/PCP traffic on port 5351 [I] Mar 4 07:00:06 OpenVPN0: OpenVPN 2.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] [I] Mar 4 07:00:06 OpenVPN0: library versions: OpenSSL 3.0.8 7 Feb 2023, LZO 2.10 [I] Mar 4 07:00:06 OpenVPN0: Attempting to establish TCP connection with [AF_INET]51.75.75.245:1194 [I] Mar 4 07:00:06 kernel: br0: port 3(rai0) entered forwarding state [I] Mar 4 07:00:06 kernel: br0: topology change detected, propagating [I] Mar 4 07:00:06 OpenVPN0: TCP connection established with [AF_INET]51.75.75.245:1194 [I] Mar 4 07:00:06 OpenVPN0: TCPv4_CLIENT link local (bound): [AF_INET]ххх.PPPoE.ххх.ххх:48920 [I] Mar 4 07:00:06 OpenVPN0: TCPv4_CLIENT link remote: [AF_INET]51.75.75.245:1194 [I] Mar 4 07:00:06 OpenVPN0: NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay [I] Mar 4 07:00:07 OpenVPN0: [antizapret-server] Peer Connection Initiated with [AF_INET]51.75.75.245:1194 [I] Mar 4 07:00:07 ndm: OpenVpn::Routing4: "OpenVPN0": connecting via PPPoE0 (PPPoE0). [I] Mar 4 07:00:07 ndm: OpenVpn::Routing4: "OpenVPN0": added host route to remote endpoint 51.75.75.245 via PPPoE0. [I] Mar 4 07:00:08 OpenVPN0: TUN/TAP device tun0 opened [I] Mar 4 07:00:08 OpenVPN0: net_iface_mtu_set: mtu 1500 for tun0 [I] Mar 4 07:00:08 ndm: Network::Interface::Ip: "OpenVPN0": IP address is 192.168.108.183/21. [I] Mar 4 07:00:08 OpenVPN0: /tmp/openvpn/OpenVPN0/openvpn-up tun0 1500 0 192.168.108.183 255.255.248.0 init [I] Mar 4 07:00:08 ndm: OpenVpn::Routing4: "OpenVPN0": install accepted route to 8.8.8.8/255.255.255.255 via 192.168.104.1. [I] Mar 4 07:00:08 ndm: OpenVpn::Routing4: "OpenVPN0": install accepted route to 10.224.0.0/255.254.0.0 via 192.168.104.1. Полученв маршруты [I] Mar 4 07:00:08 ndm: OpenVpn::Routing4: "OpenVPN0": install accepted route to 74.82.64.0/255.255.224.0 via 192.168.104.1. [I] Mar 4 07:00:08 OpenVPN0: UID set to nobody [I] Mar 4 07:00:08 OpenVPN0: GID set to nobody [I] Mar 4 07:00:08 OpenVPN0: Capabilities retained: CAP_NET_ADMIN [I] Mar 4 07:00:08 OpenVPN0: Initialization Sequence Completed
Мар 4 09:55:51 OpenVPN0 OpenVPN 2.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] Мар 4 09:55:51 OpenVPN0 library versions: OpenSSL 3.0.8 7 Feb 2023, LZO 2.10 Мар 4 09:55:51 OpenVPN0 Attempting to establish TCP connection with [AF_INET]51.158.181.161:1194 Мар 4 09:55:51 OpenVPN0 TCP connection established with [AF_INET]51.158.181.161:1194 Мар 4 09:55:51 OpenVPN0 TCPv4_CLIENT link local (bound): [AF_INET]ххх.PPPoE:48920 Мар 4 09:55:51 OpenVPN0 TCPv4_CLIENT link remote: [AF_INET]51.158.181.161:1194 Мар 4 09:55:51 OpenVPN0 NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay Мар 4 09:55:52 OpenVPN0 [antizapret-server] Peer Connection Initiated with [AF_INET]51.158.181.161:1194 Мар 4 09:55:52 ndm OpenVpn::Routing4: "OpenVPN0": connecting via PPPoE0 (PPPoE0). Мар 4 09:55:52 ndm OpenVpn::Routing4: "OpenVPN0": added host route to remote endpoint 51.158.181.161 via PPPoE0. Мар 4 09:55:53 OpenVPN0 TUN/TAP device tun0 opened Мар 4 09:55:53 OpenVPN0 net_iface_mtu_set: mtu 1500 for tun0 Мар 4 09:55:53 ndm Network::Interface::Ip: "OpenVPN0": IP address is 192.168.124.218/21. Мар 4 09:55:53 OpenVPN0 /tmp/openvpn/OpenVPN0/openvpn-up tun0 1500 0 192.168.124.218 255.255.248.0 init Мар 4 09:55:53 ndm OpenVpn::Routing4: "OpenVPN0": install accepted route to 8.8.8.8/255.255.255.255 via 192.168.120.1. Мар 4 09:55:53 ndm OpenVpn::Routing4: "OpenVPN0": install accepted route to 192.168.104.1/255.255.255.255 via 192.168.120.1. Мар 4 09:55:53 ndm OpenVpn::Routing4: "OpenVPN0": install accepted route to 10.224.0.0/255.254.0.0 via 192.168.120.1. Куча полученных маршрутов Мар 4 09:55:53 ndm OpenVpn::Routing4: "OpenVPN0": install accepted route to 74.82.64.0/255.255.224.0 via 192.168.120.1. Мар 4 09:55:53 OpenVPN0 UID set to nobody Мар 4 09:55:53 OpenVPN0 GID set to nobody Мар 4 09:55:53 OpenVPN0 Capabilities retained: CAP_NET_ADMIN Мар 4 09:55:53 OpenVPN0 Initialization Sequence Completed
~ # ip ro default dev ppp0 scope link 10.10.8.0/24 dev eth2.9 proto kernel scope link src 10.10.8.13 51.158.181.161 dev ppp0 scope link **** Сервер для OpenVPN .... 162.159.193.9 dev ppp0 scope link **** Сервер WG0 169.СерверProton dev ppp0 scope link **** Сервер WG4 ... 192.168.120.0/21 dev ovpn_br0 proto kernel scope link src 192.168.124.218 **** OpenVPN 192.168.130.0/24 dev br0 proto kernel scope link src 192.168.130.101 192.168.130.101 dev nwg0 scope link ... ~ # ovpn_br0 Link encap:Ethernet HWaddr хх:хх:хх:хх:хх:CF inet addr:192.168.124.218 P-t-P:192.168.124.218 Bcast:0.0.0.0 Mask:255.255.248.0 ... UP BROADCAST POINTOPOINT RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:2 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:232 (232.0 B) ~ # ping 192.168.120.1 PING 192.168.120.1 (192.168.120.1): 56 data bytes 64 bytes from 192.168.120.1: seq=0 ttl=64 time=67.334 ms 64 bytes from 192.168.120.1: seq=1 ttl=64 time=101.969 ms ^C --- 192.168.120.1 ping statistics --- 2 packets transmitted, 2 packets received, 0% packet loss round-trip min/avg/max = 67.334/84.651/101.969 ms ~ # traceroute 192.168.120.1 traceroute to 192.168.120.1 (192.168.120.1), 30 hops max, 46 byte packets 1 192.168.120.1 (192.168.120.1) 66.826 ms 67.227 ms 68.861 ms ~ # ~ # ip ro add 8.8.8.8/32 dev ovpn_br0 ~ # ip ro default dev ppp0 scope link 8.8.8.8 dev ovpn_br0 scope link ... 192.168.120.0/21 dev ovpn_br0 proto kernel scope link src 192.168.124.218 ... ~ # traceroute 8.8.8.8 traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 46 byte packets 1 192.168.120.1 (192.168.120.1) 74.320 ms 67.464 ms 81.577 ms 2 192.168.120.1 (192.168.120.1) 78.635 ms 67.636 ms 66.933 ms
0 answers to this question
