4.0 Alpha 14: nacct_ntce_process:107 - out of memory
AndreBA
Версия ОС 4.0 Alpha 14 не доступен web интерфейс, лог забивается (настроен Syslog) записями:
Mar 18 07:46:26 Peak-2710 kernel: nacct: nacct_ntce_process:107 - out of memory
Mar 18 07:46:26 Peak-2710 kernel: nacct: OOM
Пока откатился на 4.0.13 - работает нормально.
Более полный log прикреплю следующим скрытым сообщением.
  • Need more info 1
8 answers to this question
Posted (edited)
@Le ecureuil @hellonowСейчас опять опробовал обновить до 4.0.14.
Немного из log:
ar 18 14:17:28 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:17:33 Peak-2710 ndm: Ntce::Database: lowering limit to 7085 datasets.
Mar 18 14:17:33 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:17:34 Peak-2710 ndm: Ntce::Database: lowering limit to 5904 datasets.
Mar 18 14:17:34 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:17:34 Peak-2710 ndm: Ntce::Database: lowering limit to 4920 datasets.
Mar 18 14:17:43 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:17:58 Peak-2710 ndm: Ntce::Database: lowering limit to 4100 datasets.
Mar 18 14:17:58 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:18:43 Peak-2710 https-dns-proxy: 5341: "https://security.cloudflare-dns.com/dns-query": CURLINFO_SSL_VERIFYRESULT: Error (unable to establish TLS connection)
Mar 18 14:18:43 Peak-2710 https-dns-proxy: F04B: "https://security.cloudflare-dns.com/dns-query": CURLINFO_SSL_VERIFYRESULT: Error (unable to establish TLS connection)
Mar 18 14:18:43 Peak-2710 https-dns-proxy: 81F9: "https://security.cloudflare-dns.com/dns-query": CURLINFO_SSL_VERIFYRESULT: Error (unable to establish TLS connection)
Mar 18 14:19:35 Peak-2710 ndm: Core::Ndss: [1742] cannot connect to the server.
Mar 18 14:19:47 Peak-2710 ndm: Ntce::Database: lowering limit to 3416 datasets.
Mar 18 14:19:47 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:20:09 Peak-2710 ndm: Ntce::Database: lowering limit to 2846 datasets.
Mar 18 14:20:10 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:20:12 Peak-2710 ntce-pace2: unable to send event: Resource temporarily unavailable, exiting.
Mar 18 14:20:12 Peak-2710 ndm: Ntce::EventSink: system failed [0xcffd010f], events reordering detected: expected 6754, got 6755.
Mar 18 14:20:48 Peak-2710 ndm: Ntce::Database: lowering limit to 2371 datasets.
Mar 18 14:20:52 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:20:53 Peak-2710 ndm: Ntce::Database: lowering limit to 1975 datasets.
Mar 18 14:21:24 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:21:24 Peak-2710 ndm: Ntce::Database: lowering limit to 1645 datasets.
Mar 18 14:21:26 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:21:26 Peak-2710 ndm: Ntce::Database: lowering limit to 1370 datasets.
Mar 18 14:21:38 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:21:38 Peak-2710 ndm: Ntce::Database: lowering limit to 1141 datasets.
Mar 18 14:21:40 Peak-2710 ndm: Linux::MemoryPressureWatcher: "Ntce::Database": high memory pressure detected: threshold 9% of 2000 ms.
Mar 18 14:21:53 Peak-2710 ntce-pace2: unable to send event: Resource temporarily unavailable, exiting.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 2 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 3 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 4 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 5 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 6 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 7 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 8 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 9 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 10 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 11 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 12 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 13 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 14 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 15 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 16 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 17 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 18 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 19 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 20 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 21 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 22 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 23 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 24 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 25 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 26 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 27 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 28 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 29 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 30 times.
Mar 18 14:21:53 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 31 times.
Mar 18 14:21:54 Peak-2710 ndm: Ntce::EventSink: system failed [0xcffd010f], events reordering detected: expected 17047, got 17079.
Mar 18 14:22:06 Peak-2710 ntce-pace2: unable to send event: Resource temporarily unavailable, exiting.
Mar 18 14:22:06 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 2 times.
Mar 18 14:22:06 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 3 times.
Mar 18 14:22:06 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 4 times.
Mar 18 14:22:06 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 5 times.
Mar 18 14:22:06 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 6 times.
Mar 18 14:22:06 Peak-2710 ntce-pace2: Core::Syslog: last message repeated 7 times.
Откатился опять на 4.0.13
Edited by AndreBA
  • Need more info 1
У меня такого нет. Было на 12.
Сейчас подняты тоннели OVPN, WG и запущен OPKG  - память забита на 70%, но всё ОК.
8 часов назад, Le ecureuil сказал:
Нужны self-test'ы в момент когда забивается (или чуть раньше).
Это весьма проблематично....
Вот такое уже,через минуту загрузки роутера:
_037.thumb.png.8ab778b668ff0dd0acf73dbe2fc730a0.png_038.thumb.png.17b33d3b588c97ceda913d6f41c19ec1.pngScreenshot_20230320-191147772.thumb.jpg.37aefb07059dd02d8639c3546cfea599.jpg
Из приложения тоже не хочет(даже не показывает, что обновился до 4.0.14.
Удалось сохранить self-test практически сразу после перезагрузки роутера. Прикреплю его (если он чем то поможет) следующим скрытым сообщением.
Posted (edited)
Еще заметил. Если подключаюсь к роутеру по LAN (у меня ноутбук), то работает и расход памяти идет медленно.  Как только подключаюсь по Wi-Fi, то расход памяти увеличивается быстро.
Модуль Wi-Fi Intel AX210:
Может это конечно совпадение.....
Еще один self-test прикреплю следующим скрытым постом.
Edited by AndreBA
@Le ecureuil @hellonow В 4.0 Alpha 15 ситуация не изменилась. Примерно за 6 минут "съедается" вся память:
Откатываюсь на 4.0.13, работает нормально.
Примерно 90% памяти получилось скачать self-test. Прикреплю его следующим скрытым постом.
