Перебор паролей из вне.
varez
Скажите пожалуйста как их заблокировать? через межсетевой экран не блокируется....сам интернет начал тупить после этого.
Jan 08 07:16:41ndm
kernel: net_ratelimit: 496 callbacks suppressed
Jan 08 07:16:41ndm
kernel: nf_conntrack: table full (16384), dropping packet
Jan 08 07:16:41ndm
Core::Syslog: last message repeated 9 times.
Jan 08 07:16:41keenetic_giga nginx
(conn: *447924) connect() failed (146: Unknown error) while connecting to upstream, client: 117.30.141.141
Jan 08 07:16:42keenetic_giga nginx
(conn: *448161) upstream sent no valid HTTP/1.0 header while reading response header from upstream, client: 120.24.5.245
(conn: *448248) xnongermx.my.to could not be resolved (3: Host not found), client: 51.254.78.112
(conn: *448282) demo.inout-search-ultimate.com could not be resolved (3: Host not found), client: 183.114.247.183
Jan 08 07:16:43ndm
Core::ConfigurationSaver: configuration saved.
Jan 08 07:16:44keenetic_giga nginx
unexpected response for www.robotchina.com.cn
(conn: *439587) upstream timed out (145: Unknown error) while connecting to upstream, client: 121.234.244.197
Jan 08 07:16:45keenetic_giga nginx
(conn: *441432) recv() failed (131: Unknown error) while reading response header from upstream, client: 120.92.50.251
Jan 08 07:16:46ndm
kernel: net_ratelimit: 767 callbacks suppressed
Jan 08 07:16:46ndm
Jan 08 07:16:46ndm
Jan 08 07:16:46keenetic_giga nginx
(conn: *441313) connect() failed (146: Unknown error) while connecting to upstream, client: 182.146.245.224
Jan 08 07:16:48keenetic_giga nginx
Jan 08 07:16:49keenetic_giga nginx
(conn: *448876) upstream prematurely closed connection while reading response header from upstream, client: 198.204.244.211
Jan 08 07:16:51ndm
kernel: net_ratelimit: 758 callbacks suppressed
Jan 08 07:16:51ndm
Jan 08 07:16:51ndm
Jan 08 07:16:51keenetic_giga nginx
(conn: *448828) tango-deg.com could not be resolved (3: Host not found), client: 129.144.12.24
Jan 08 07:16:53keenetic_giga nginx
Jan 08 07:16:55keenetic_giga nginx
(conn: *450100) upstream prematurely closed connection while reading response header from upstream, client: 198.204.244.211
Jan 08 07:16:56ndm
kernel: net_ratelimit: 802 callbacks suppressed
Jan 08 07:16:56ndm
Jan 08 07:16:56ndm
Jan 08 07:16:56keenetic_giga nginx
(conn: *450239) www.janapendapatan2u.com could not be resolved (3: Host not found), client: 134.119.213.82
Jan 08 07:16:58keenetic_giga nginx
(conn: *450515) upstream prematurely closed connection while reading response header from upstream, client: 198.204.244.211
Jan 08 07:16:59keenetic_giga nginx
(conn: *450202) connect() failed (146: Unknown error) while connecting to upstream, client: 111.199.223.138
Jan 08 07:17:01ndm
kernel: net_ratelimit: 771 callbacks suppressed
Jan 08 07:17:01ndm
Jan 08 07:17:01ndm
Jan 08 07:17:03keenetic_giga nginx
(conn: *450229) www.correosdemexico.gob.mx could not be resolved (3: Host not found), client: 192.155.85.189
Jan 08 07:17:04keenetic_giga nginx
Jan 08 07:17:06keenetic_giga nginx
(conn: *450143) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:06ndm
kernel: net_ratelimit: 849 callbacks suppressed
Jan 08 07:17:06ndm
Jan 08 07:17:06ndm
(conn: *451582) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:07keenetic_giga nginx
(conn: *451241) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:08keenetic_giga nginx
(conn: *450911) upstream prematurely closed connection while reading response header from upstream, client: 198.204.244.211
unexpected response for www.correosdemexico.gob.mx
Jan 08 07:17:09keenetic_giga nginx
(conn: *451403) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:10ndm
Io::UdpSocket: unable to send data: operation not permitted.
Jan 08 07:17:11ndm
kernel: net_ratelimit: 691 callbacks suppressed
Jan 08 07:17:11ndm
Jan 08 07:17:11ndm
Jan 08 07:17:11keenetic_giga nginx
(conn: *452280) www.todobisexuales.com could not be resolved (3: Host not found), client: 94.242.252.56
Jan 08 07:17:12keenetic_giga nginx
(conn: *452205) upstream prematurely closed connection while reading response header from upstream, client: 198.204.244.211
Jan 08 07:17:12ndm
Jan 08 07:17:13ndm
Service: "CIFS": unexpectedly stopped.
Jan 08 07:17:14keenetic_giga nginx
(conn: *452617) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:15keenetic_giga nginx
(conn: *443199) upstream timed out (145: Unknown error) while reading response header from upstream, client: 113.195.176.135
Jan 08 07:17:16ndm
kernel: net_ratelimit: 681 callbacks suppressed
Jan 08 07:17:16ndm
Jan 08 07:17:16ndm
Jan 08 07:17:16ndm
Jan 08 07:17:16keenetic_giga nginx
(conn: *452911) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:17keenetic_giga nginx
Jan 08 07:17:19keenetic_giga nginx
Jan 08 07:17:20keenetic_giga nginx
(conn: *452525) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:21ndm
kernel: net_ratelimit: 744 callbacks suppressed
Jan 08 07:17:21ndm
Jan 08 07:17:21ndm
Core::Syslog: last message repeated 3 times.
Jan 08 07:17:21ndm
Jan 08 07:17:21ndm
Jan 08 07:17:21ndm
Core::Syslog: last message repeated 5 times.
Jan 08 07:17:21ndm
Jan 08 07:17:21keenetic_giga nginx
(conn: *453595) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:22miniupnpd
sendto(udp_notify=7, 192.168.1.1): Operation not permitted
Core::Syslog: last message repeated 10 times.
Jan 08 07:17:22keenetic_giga nginx
Jan 08 07:17:22ndm
Jan 08 07:17:24ndm
Jan 08 07:17:25ndm
Core::Syslog: last message repeated 2 times.
Jan 08 07:17:26keenetic_giga nginx
(conn: *454149) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:26ndm
kernel: net_ratelimit: 748 callbacks suppressed
Jan 08 07:17:26ndm
Jan 08 07:17:26ndm
Jan 08 07:17:27keenetic_giga nginx
(conn: *446179) upstream timed out (145: Unknown error) while connecting to upstream, client: 121.234.244.197
Jan 08 07:17:27ndm
Jan 08 07:17:28ndm
Jan 08 07:17:30keenetic_giga nginx
(conn: *454326) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:31ndm
kernel: net_ratelimit: 637 callbacks suppressed
Jan 08 07:17:31ndm
Jan 08 07:17:31ndm
Jan 08 07:17:31keenetic_giga nginx
Jan 08 07:17:32keenetic_giga nginx
(conn: *455006) connect() failed (146: Unknown error) while connecting to upstream, client: 36.110.120.158
Jan 08 07:17:33keenetic_giga nginx
Jan 08 07:17:35keenetic_giga nginx
(conn: *455454) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:36keenetic_giga nginx
Jan 08 07:17:36ndm
kernel: net_ratelimit: 572 callbacks suppressed
Jan 08 07:17:36ndm
Jan 08 07:17:36ndm
Jan 08 07:17:38keenetic_giga nginx
(conn: *455489) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
(conn: *455951) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:39ndm
Jan 08 07:17:39keenetic_giga nginx
Jan 08 07:17:41ndm
Jan 08 07:17:41ndm
kernel: net_ratelimit: 605 callbacks suppressed
Jan 08 07:17:41ndm
Jan 08 07:17:41ndm
Jan 08 07:17:44keenetic_giga nginx
(conn: *456258) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
(conn: *448575) upstream timed out (145: Unknown error) while connecting to upstream, client: 118.123.119.98
(conn: *456693) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:45keenetic_giga nginx
(conn: *456784) www.jhunjhunudarshan.in could not be resolved (3: Host not found), client: 212.129.1.23
Jan 08 07:17:46keenetic_giga nginx
(conn: *413595) upstream timed out (145: Unknown error) while connecting to upstream, client: 60.10.115.54
(conn: *456977) www.candygalaxy.com could not be resolved (3: Host not found), client: 212.7.220.14
Jan 08 07:17:46ndm
kernel: net_ratelimit: 584 callbacks suppressed
Jan 08 07:17:46ndm
Jan 08 07:17:46ndm
Jan 08 07:17:46ndm
Jan 08 07:17:47keenetic_giga nginx
(conn: *457193) connect() failed (146: Unknown error) while connecting to upstream, client: 198.11.176.36
Jan 08 07:17:48keenetic_giga nginx
(conn: *456532) recv() failed (131: Unknown error) while reading response header from upstream, client: 60.205.140.209
Jan 08 07:17:49keenetic_giga nginx
(conn: *457354) connect() failed (146: Unknown error) while connecting to upstream, client: 182.200.80.43
Jan 08 07:17:51ndm
kernel: net_ratelimit: 614 callbacks suppressed
Jan 08 07:17:51ndm
Jan 08 07:17:51ndm
Jan 08 07:17:51keenetic_giga nginx
(conn: *457845) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:53keenetic_giga nginx
(conn: *457727) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
(conn: *458032) connect() failed (146: Unknown error) while connecting to upstream, client: 148.251.44.250
Jan 08 07:17:54keenetic_giga nginx
(conn: *457830) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:54ndm
Jan 08 07:17:55ndm
Cifs::ServerNQ: service started.
Jan 08 07:17:56keenetic_giga nginx
(conn: *457256) www.correosdemexico.gob.mx could not be resolved (3: Host not found), client: 120.76.154.160
Jan 08 07:17:58keenetic_giga nginx
(conn: *458507) connect() failed (146: Unknown error) while connecting to upstream, client: 50.16.113.20
(conn: *458431) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:59keenetic_giga nginx
(conn: *454433) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:17:59ndm
kernel: net_ratelimit: 358 callbacks suppressed
Jan 08 07:17:59ndm
Jan 08 07:17:59ndm
Jan 08 07:17:59ndm
Jan 08 07:18:00keenetic_giga nginx
(conn: *450737) upstream timed out (145: Unknown error) while connecting to upstream, client: 104.168.136.253
Jan 08 07:18:00ndm
(conn: *459068) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
Jan 08 07:18:01keenetic_giga nginx
(conn: *456252) upstream prematurely closed connection while reading response header from upstream, client: 60.205.140.78
(conn: *459199) image.s1979.com could not be resolved (3: Host not found), client: 42.156.137.22
Jan 08 07:18:02ndm
Jan 08 07:18:03keenetic_giga nginx
(conn: *459536) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
Jan 08 07:18:04ndm
Jan 08 07:18:04ndm
kernel: net_ratelimit: 760 callbacks suppressed
Jan 08 07:18:04ndm
Jan 08 07:18:04ndm
Jan 08 07:18:04keenetic_giga nginx
Jan 08 07:18:05keenetic_giga nginx
unexpected response for web.2144.cn
Jan 08 07:18:05ndm
Jan 08 07:18:06keenetic_giga nginx
(conn: *460019) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
(conn: *458857) connect() failed (146: Unknown error) while connecting to upstream, client: 47.88.16.31
Jan 08 07:18:07ndm
Jan 08 07:18:07keenetic_giga nginx
(conn: *459875) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:18:08ndm
Jan 08 07:18:09ndm
kernel: net_ratelimit: 655 callbacks suppressed
Jan 08 07:18:09ndm
Jan 08 07:18:09ndm
Jan 08 07:18:10keenetic_giga nginx
(conn: *460484) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
Jan 08 07:18:11nimproxy
sendmsg() failed (operation not permitted).
failed to send igmp packet to interface br0.
Jan 08 07:18:13keenetic_giga nginx
(conn: *461048) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
Jan 08 07:18:14ndm
kernel: net_ratelimit: 670 callbacks suppressed
Jan 08 07:18:14ndm
Jan 08 07:18:14ndm
Jan 08 07:18:15keenetic_giga nginx
(conn: *460047) www.kat.ph could not be resolved (3: Host not found), client: 134.119.212.145
Jan 08 07:18:16keenetic_giga nginx
(conn: *461256) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:18:16ndm
(conn: *461480) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
(conn: *461316) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:18:17ndm
Jan 08 07:18:18keenetic_giga nginx
(conn: *461580) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:18:19ndm
Jan 08 07:18:20keenetic_giga nginx
unexpected response for www.kat.ph
unexpected response for www.gatikwe.com
(conn: *461825) x-torrents.org could not be resolved (3: Host not found), client: 212.7.220.14
Jan 08 07:18:21ndm
kernel: net_ratelimit: 364 callbacks suppressed
Jan 08 07:18:21ndm
Jan 08 07:18:21ndm
Jan 08 07:18:23ndm
Jan 08 07:18:23keenetic_giga nginx
(conn: *462290) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
Jan 08 07:18:26ndm
kernel: net_ratelimit: 604 callbacks suppressed
Jan 08 07:18:26ndm
Jan 08 07:18:26ndm
Jan 08 07:18:26ndm
Jan 08 07:18:29keenetic_giga nginx
Jan 08 07:18:31keenetic_giga nginx
(conn: *463472) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:18:31ndm
kernel: net_ratelimit: 618 callbacks suppressed
Jan 08 07:18:31ndm
Jan 08 07:18:31ndm
(conn: *463262) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
Jan 08 07:18:34keenetic_giga nginx
(conn: *463976) upstream prematurely closed connection while reading response header from upstream, client: 120.25.75.23
(conn: *463071) recv() failed (131: Unknown error) while reading response header from upstream, client: 60.205.140.209
Jan 08 07:18:35keenetic_giga nginx
(conn: *464286) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
Jan 08 07:18:36ndm
kernel: net_ratelimit: 619 callbacks suppressed
Jan 08 07:18:36ndm
Jan 08 07:18:36ndm
Jan 08 07:18:38keenetic_giga nginx
(conn: *464436) upstream sent no valid HTTP/1.0 header while reading response header from upstream, client: 60.205.208.133
(conn: *464682) upstream prematurely closed connection while reading response header from upstream, client: 192.151.147.46
Jan 08 07:18:40keenetic_giga nginx
Jan 08 07:18:41keenetic_giga nginx
(conn: *465087) bbs.king-td.com could not be resolved (3: Host not found), client: 212.7.220.14
Jan 08 07:18:41ndm
kernel: net_ratelimit: 611 callbacks suppressed
Jan 08 07:18:41ndm
Jan 08 07:18:41ndm
(conn: *465139) recv() failed (131: Unknown error) while reading response header from upstream, client: 94.242.252.56
Jan 08 07:18:41ndm
Jan 08 07:18:41ndm
Core::Syslog: last message repeated 6 times.
Edited by varez
5 answers to this question
16 минут назад, Fandor сказал:
@Le ecureuil
По проблеме keenetic_MODEL nginxэто уже 6-я тема на форуме. Может имеет смысл вынести эту проблему в шапку форума с описанием всех возможных решений?
У всех проблемы разные, кроме того общего факта, что это логи веб-сервера в прошивке. С каждой проблемой нужно разбираться отдельно.
  • Thanks 2
