4.00.C.2.0-1 дополнительный сегмент wifi
vasek00
KN2710 4.00.C.2.0-1 непонятно после чего возникают такие вот записи в созданном доп.сегменте только для умного дома
Авг 17 10:11:47 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) had disassociated by STA (reason: STA is leaving or has left BSS).
Авг 17 10:11:47 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) had associated.
Авг 17 10:11:47 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) set key done in WPA2/WPA2PSK.
Авг 17 10:11:47 ndhcps DHCPDISCOVER received from хх:хх:хх:хх:24:99.
Авг 17 10:11:47 ndhcps making OFFER of 192.168.150.2 to хх:хх:хх:хх:24:99.
Авг 17 10:11:47 ndhcps DHCPREQUEST received (STATE_SELECTING) for 192.168.150.2 from хх:хх:хх:хх:24:99.
Авг 17 10:11:48 ndhcps sending ACK of 192.168.150.2 to хх:хх:хх:хх:24:99.
Авг 17 10:12:59 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) had disassociated by STA (reason: STA is leaving or has left BSS).
Авг 17 10:12:59 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) had associated.
Авг 17 10:12:59 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) set key done in WPA2/WPA2PSK.
Авг 17 10:12:59 ndhcps DHCPDISCOVER received from хх:хх:хх:хх:24:99.
Авг 17 10:12:59 ndhcps making OFFER of 192.168.150.2 to хх:хх:хх:хх:24:99.
Авг 17 10:12:59 ndhcps DHCPREQUEST received (STATE_SELECTING) for 192.168.150.2 from хх:хх:хх:хх:24:99.
Авг 17 10:13:00 ndhcps sending ACK of 192.168.150.2 to хх:хх:хх:хх:24:99.
Авг 17 10:15:23 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) had disassociated by STA (reason: STA is leaving or has left BSS).
Авг 17 10:15:23 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) had associated.
Авг 17 10:15:23 ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(хх:хх:хх:хх:24:99) set key done in WPA2/WPA2PSK.
Авг 17 10:15:23 ndhcps DHCPDISCOVER received from хх:хх:хх:хх:24:99.
Авг 17 10:15:23 ndhcps making OFFER of 192.168.150.2 to хх:хх:хх:хх:24:99.
Авг 17 10:15:23 ndhcps DHCPREQUEST received (STATE_SELECTING) for 192.168.150.2 from хх:хх:хх:хх:24:99.
Авг 17 10:15:24 ndhcps sending ACK of 192.168.150.2 to хх:хх:хх:хх:24:99.
и т.д.
это со всеми клиентами wifi данного сегмента, правда в данном сегменте только умный дом. Основной wifi 2.4 и 5 разделены, но на нем включено "Управление BSS-окружением 802.11k/v", дополнительный сегмент только wifi 2.4 и всякие "Управление BSS-окружением 802.11k/v" выключены как и "FT" выключено.
interface WifiMaster0
    country-code RU
    compatibility GN
    channel 3
    channel width 40-above
    power 50
    rekey-interval 86400
    beamforming explicit
    vht
    up
interface WifiMaster0/AccessPoint1
    mac access-list type none
    security-level protected
    authentication wpa-psk ns3 ***
    encryption enable
    encryption wpa2
    ip dhcp client dns-routes
    ip name-servers
    ssid Smart
    up
interface Bridge1
    rename HomeSmart
    description HomeSmart
    include WifiMaster0/AccessPoint1
    mac access-list type permit
    ip address 192.168.150.101 255.255.255.0
    ip name-servers
    iapp key ns3 ***
    up
interface Bridge0
    rename Home
    description HomeLan
    inherit GigabitEthernet0/Vlan1
    include AccessPoint
    include AccessPoint_5G
    security-level private
    ip address 192.168.130.101 255.255.255.0
    ip name-servers
    iapp key ns3 ***
    up
Проблем в работе на них нет.
на <release>4.00.C.1.0-0</release> такого нет, откат на нее потом возврат на <release>4.00.C.2.0-1</release> решает проблему, если не лазить в WEB то на долго, как где то полазить в WEB (подозрения) так может появиться.
Натыкался уже в логе на такое раза 4.
Edited by vasek00
1 answer to this question
Попробую убрать на данном сегменте Bridge1
iapp key
Цитата
3.31.79 interface iapp key
Описание Установить ключ мобильного домена IAPP для успешной синхронизации между точками доступа, где включен FT (команда interface ft enable).
Точки доступа должны принадлежать одной IP-подсети. По умолчанию ключ не назначен.
Edited by vasek00
