finally I can play with my pc and I've just noted that Upnp it doesn't want run.
olso noted :
Network::Interface::Switch: "GigabitEthernet0/2": switch link down at port 3.
Ott 18 17:22:50 ndm
Network::Interface::Base: "GigabitEthernet0/2": "ethernet" changed "link" layer state "running" to "pending".
Ott 18 17:22:50 ndm
Network::Interface::Base: "GigabitEthernet0/Vlan1": "ethernet" changed "link" layer state "running" to "pending".
Ott 18 17:29:43 ndm
Network::Interface::Switch: "GigabitEthernet0/2": switch link up at port 3 (1000FD/AN).
Ott 18 17:29:43 ndm
Network::Interface::Base: "GigabitEthernet0/2": "ethernet" changed "link" layer state "pending" to "running".
Ott 18 17:29:43 ndm
Network::Interface::Base: "GigabitEthernet0/Vlan1": "ethernet" changed "link" layer state "pending" to "running".
Crav888
Hi there,
olso noted :
Network::Interface::Switch: "GigabitEthernet0/2": switch link down at port 3. Ott 18 17:22:50 ndm Network::Interface::Base: "GigabitEthernet0/2": "ethernet" changed "link" layer state "running" to "pending". Ott 18 17:22:50 ndm Network::Interface::Base: "GigabitEthernet0/Vlan1": "ethernet" changed "link" layer state "running" to "pending". Ott 18 17:29:43 ndm Network::Interface::Switch: "GigabitEthernet0/2": switch link up at port 3 (1000FD/AN). Ott 18 17:29:43 ndm Network::Interface::Base: "GigabitEthernet0/2": "ethernet" changed "link" layer state "pending" to "running". Ott 18 17:29:43 ndm Network::Interface::Base: "GigabitEthernet0/Vlan1": "ethernet" changed "link" layer state "pending" to "running".I don't know if it's related
thank to all!
best regard
1 answer to this question
