Stagnate9916 Posted February 23, 2024 Posted February 23, 2024 Hello Would it be possible to force using a dedicated VPN connection for the Torrent built-in client ? Also, the version of the current Transmission Daemon is a bit old (this is version 3.00 - aged May 2020, almost 4 years old). Thank you Quote
0 Admin Nimda Posted March 15, 2025 Posted March 15, 2025 (edited) Finally I found solution. My ISP uses Cgnat so I need vpn to use torrent. We can't do whole process with web ui we need little help of commands. It is simple. Follow me. First we need create a "Connection Policy". This proccess can be done on web ui. 1) Go to web ui > Conneciton Policies > Click Add Policy > Give any name (something like ProtonVPN) > Tick only your vpn connection > Save it Now we need to know our policy name. 2) Go to command line and type: show ip policy You will get policies config on your router. Look for your policy description that you created before (ProtonVPN). Here I share some of config part. { "policy": { "Policy0": { "description": "ProtonVPN", "mark": "ffffaaa", "table4": 10, "route4": { "route": [ Here our policy name is Policy0. Ok. Last step. 3) Type that command: torrent policy Policy0 All done. Check your torrent client connection. Now your torrent client use vpn connection that you want. Edited March 15, 2025 by Admin Nimda 1 Quote
Stagnate9916
Hello
Thank you
1 answer to this question
