Three connections are configured on the Kinetic : via Ethernet (provider), via Wireless ISP and a WireGuard connection (used for internet).
On the default policy, the Wireguard connectivity is the default one, followed by the Ethernet and the Wireless ISP.
I have created another connection priority (labelled 'direct') that only contains the Ethernet connection.
I have configured my computer to use the 'direct' profile via a policy Binding. The DHCP lease offered defines the DNS server as the kinetic router itself.
I have very frequent DNS resolution errors as soon as my computer is not using the Default Connection Policy.
Here is an example of rejected DNS resolution. I did not have configured the "filter mode" (internet safety).
Stagnate9916
Using 4.1.0
❯ dig docs.keenetic.com
; <<>> DiG 9.10.6 <<>> docs.keenetic.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 22820
;; flags: qr ra ad; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;docs.keenetic.com. IN A
;; Query time: 2010 msec
;; SERVER: 192.168.10.1#53(192.168.10.1)
;; WHEN: Sat Feb 24 13:07:14 CET 2024
;; MSG SIZE rcvd: 46
Also the 'DNS Configuration' screen has several issues to populate the DHCP-obtained from my ISP Ethernet (bouygues).
What can I do to investigate ?
Thanks
1 answer to this question
