renne Posted May 7 Posted May 7 INWX uses https://dyndns.inwx.com/nic/update?myip=<ipaddr>&myipv6=<ip6addr> as update_url. Both, the IPv4 and the IPv6 address have to be updated in a single call to the API. KeeneticOS seems to send the IPv4 address and no IPv6 address. How can we enable IPv6 for DynDNS? Thanx for any hint! Quote
0 r13 Posted May 7 Posted May 7 50 минут назад, renne сказал: INWX uses https://dyndns.inwx.com/nic/update?myip=<ipaddr>&myipv6=<ip6addr> as update_url. Both, the IPv4 and the IPv6 address have to be updated in a single call to the API. KeeneticOS seems to send the IPv4 address and no IPv6 address. How can we enable IPv6 for DynDNS? Thanx for any hint! Your configuration should be like this to update both addresses: dyndns profile _WEBADMIN type custom no send-address url https://dyndns.inwx.com/nic/update?myip=${ip}&myipv6=${ip6} Quote
0 renne Posted May 8 Author Posted May 8 The log says: I [May 8 12:34:30] ndm: DynDns::Profile: "_WEBADMIN": IPv4: updated successfully. W [May 8 12:34:30] ndm: DynDns::Profile: "_WEBADMIN": IPv6 update not run (not run). Why does the IPv6 update not run? Do I have to enable it separately? Quote
0 renne Posted May 8 Author Posted May 8 KeenDNS sets AAAA records if IPv6 mode with cloud access is enabled. But still no AAAA records for DDNS. Quote
0 Le ecureuil Posted May 24 Posted May 24 В 08.05.2024 в 13:39, renne сказал: The log says: I [May 8 12:34:30] ndm: DynDns::Profile: "_WEBADMIN": IPv4: updated successfully. W [May 8 12:34:30] ndm: DynDns::Profile: "_WEBADMIN": IPv6 update not run (not run). Why does the IPv6 update not run? Do I have to enable it separately? It's the different situation. Dyndns try to execute two http requests in parallel: via IPv4 connection, and via IPv6 connection. This logs signalise that your interface has only IPv4 connection, and it's impossible to connect via IPv6. But you can update both addresses via arguments in link: it's just a different method of updating. So please enable the interface debug to which the dyndns profile is linked via: > interface XXX debug and prove which arguments are really passed to the dyndns servers (in logs). Quote
renne
Thanx for any hint!
5 answers to this question
