42A17 ошибка на Buddy 6 "WifiDriverIo: system failed [0xcffd0a10], wireless request 0x8be2: invalid argument."
vasek00
На Buddy 6 на 42А17 c контроллером 1811 ошибка на Buddy 6 - "WifiDriverIo - invalid argument"
[E] Jul 10 14:05:58 ndhcpc: Bridge1: unable to bind to raw socket.
[I] Jul 10 14:05:58 ndm: Netfilter::Ip6::Table: "filter": GigabitEthernet0/Vlan3 removed 1 rule.
[I] Jul 10 14:05:58 ndm: Network::Interface::EthernetIp: "WifiMaster0/AccessPoint1": peer isolation disabled.
[C] Jul 10 14:05:58 ndm: Network::Interface::Mtk::WifiDriverIo: system failed [0xcffd0a10], wireless request 0x8be2: invalid argument.
[I] Jul 10 14:05:58 ndm: Netfilter::Table: "mangle": Bridge1 removed 1 rule.
[I] Jul 10 14:05:58 ndm: Netfilter::Ip6::Table: "filter": Bridge1 removed 1 rule.
[C] Jul 10 14:05:58 ndm: Dhcp::Client: system failed [0xcffd06ac], unaccounted state 'undefined' for interface.
[E] Jul 10 14:05:58 ndhcpc: Bridge1: socket error occurred.
[I] Jul 10 14:05:58 ndhcpc: Bridge1: sending RELEASE for 192.168.15.51 to 192.168.15.101. ****** Сегмент Smart
[I] Jul 10 14:05:58 ndhcpc: Bridge1: NDM DHCP client stopped (exit status 0).
[I] Jul 10 14:05:58 ndm: Network::Interface::Base: "Bridge0": "dhcp-client" changed "ipv4" layer state "running" to "pending".
[I] Jul 10 14:05:58 ndhcpc: Bridge0: sending RELEASE for 192.168.13.250 to 192.168.13.11. ****** Основной сегмент
[W] Jul 10 14:05:58 ndm: Dhcp::Client: DHCP server is not responding.
[I] Jul 10 14:05:58 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.1.3/24.
[I] Jul 10 14:05:58 ndhcpc: Bridge0: NDM DHCP client stopped (exit status 0).
[I] Jul 10 14:05:58 ndm: Network::Interface::Mtk::AccessPoint: "WifiMaster0/AccessPoint0": peer isolation disabled.
[I] Jul 10 14:05:58 ndm: Network::Interface::Mtk::AccessPoint: "WifiMaster1/AccessPoint0": peer isolation disabled.
[I] Jul 10 14:06:04 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster1/WifiStation0": performing site survey (flat scan).
[C] Jul 10 14:06:04 ndm: Network::Interface::Mtk::WifiDriverIo: system failed [0xcffd0a10], wireless request 0x8be2: invalid argument.
[C] Jul 10 14:06:04 ndm: Core::Syslog: last message repeated 2 times.
[I] Jul 10 14:06:04 ndm: Network::Interface::Base: "WifiMaster1/WifiStation0": "ethernet" changed "link" layer state "running" to "pending".
[I] Jul 10 14:06:04 ndm: Network::Interface::Mtk::AccessPoint: "WifiMaster0/AccessPoint1": peer isolation disabled.
[I] Jul 10 14:06:05 mtkiappd: stopped.
[W] Jul 10 14:06:05 ndm: Core::Server: client disconnected.
[I] Jul 10 14:06:05 kernel: br0: port 3(apcli1.1) entered blocking state
[I] Jul 10 14:06:05 kernel: br0: port 3(apcli1.1) entered listening state
interface WifiMaster0
    country-code RU
    compatibility BGN+AX
    channel 3
    channel width 40-below
    power 50
    rekey-interval 86400
    beamforming explicit
    atf inbound
    vht
    downlink-mumimo
    uplink-mumimo
    downlink-ofdma
    uplink-ofdma
    spatial-reuse
    up
interface WifiMaster0/AccessPoint0
    rename AccessPoint
    description "Wi-Fi access point"
    mac access-list type none
    authentication wpa-psk ns3 ***
    encryption enable
    encryption wpa2
    encryption wpa3
    ip dhcp client dns-routes
    ssid KN
    wmm
    rrm
    down ************* не используется на контроллере и выключен так же тут
interface WifiMaster1
    country-code MY
    compatibility N+AC+AX
    channel 52
    channel width 160
    power 50
    atf inbound
    downlink-mumimo
    uplink-mumimo
    downlink-ofdma
    uplink-ofdma
    spatial-reuse
    whnat
    up
interface WifiMaster1/AccessPoint0
    rename AccessPoint_5G
    description "5GHz Wi-Fi access point"
    encryption enable
    encryption wpa2
    encryption wpa3
    ssid KN-5
    wmm
    rrm
    ft mdid KN
    ft enable
    rssi-threshold -75
    up
interface GigabitEthernet0/Vlan3
    up
interface Bridge1  ***** есть отедльный роутер для 2.4 в котором данный сегмент основной
    description HomeSmart
    include Smart **** Wifi 2.4 и больше нечего
    include GigabitEthernet0/Vlan3 ***** чисто vlan ни каких LAN портов
Все работает кажется.
0 answers to this question
