Kozlov Posted July 31 Share Posted July 31 (edited) "opkg install make": make is not downloading. root@Group:/opt$ opkg install make Installing make (4.3-1a) to root... Downloading http://bin.entware.net/mipselsf-k3.4/make_4.3-1a_mipsel-3.4.ipk wget: server returned error: HTTP/1.1 404 Not Found Collected errors: * opkg_download: Failed to download http://bin.entware.net/mipselsf-k3.4/make_4.3-1a_mipsel-3.4.ipk, wget returned 1. * opkg_install_pkg: Failed to download make. Perhaps you need to run 'opkg update'? * opkg_install_cmd: Cannot install package make. Here is written about http protocol on tcp port 80. I see, that only https on tcp port 443 is available. Just sometimes port 80 does response. Same situation with command "opkg update" root@Group:/opt/etc/ngx-fancyindex-0.5.2$ opkg update Downloading http://bin.entware.net/mipselsf-k3.4/Packages.gz wget: can't connect to remote host (158.160.45.54): Connection timed out *** Failed to download the package list from http://bin.entware.net/mipselsf-k3.4/Packages.gz Downloading http://bin.entware.net/mipselsf-k3.4/keenetic/Packages.gz Updated list of available packages in /opt/var/opkg-lists/keendev Collected errors: * opkg_download: Failed to download http://bin.entware.net/mipselsf-k3.4/Packages.gz, wget returned 1. wget does not work with https. What Firewall rules should i add to allow updates from your service? source any protocol tcp port 80 destination any port any Edited August 1 by Dare Mage Found the solution Quote Link to comment Share on other sites More sharing options...
