  • 4
Static Routing Requests
Posted (edited)
Hello,
I set up a second connection which is Cloudflare Warp and I want to route some traffic to that connection. I am playing with this tool since 2 days and what is difficult to me can be improved.
1-There should be bulk modification for routes. I have imported batch file of Twitter which has maybe 50 IP. I want to add "Twitter" label to each record. I can not do it. (Or is it possible to add this via batch file, not sure).
2-We should be able to do this with URL like we do it in modern firewalls (Fortigate for example) instead of IP. Because it is impossible for me to find all IPs address of Twitter, Discord, telegram etc.. and they can change/update their IP also.
3-It would be great if we have enable-disable slide button for each routing rule. so that we dont have to delete that routing if we dont want to use it temporarily.
Thanks.
Edited by Radyohead
  • Upvote 4
2 answers to this question
Posted
Being able to define static routes using domains and domain wildcards would be fantastic.
Example configuration like in the screenshot.
