  • 4
Suggestion for More Flexible Restart Options After Component Changes
Posted
Hello,
When adding or removing a component on the router, the system automatically restarts immediately after the process. This can cause interruptions, especially during times when an active internet connection is critical.
A more user-friendly solution, similar to modern operating systems like Windows, could be implemented:
  • "Restart Now" or "Restart Later" options: Allow users to manually trigger the restart after completing their tasks.
  • Active hours setting: Schedule automatic restarts during specific time periods (e.g., nighttime).
  • Partial configuration application: Enable configurations that don’t require a restart to take effect immediately.
Such a feature would significantly enhance the user experience and help ensure uninterrupted internet connectivity.
I hope you consider this suggestion and look forward to seeing if it can be implemented in future updates.
Thank you!
  • Upvote 3
3 answers to this question
Posted
Installing or removing a component can only be done through reboot with the reflashing of the new repacked version of the software. So it's impossible to install/remove a component without a reboot.
  • Y'r wrong 1
Posted
I’m not asking for the ability to add or remove components without a reboot. I simply want the system to allow me to choose when to reboot after adding or removing a component, rather than forcing an immediate reboot.
Posted
Are the suggestions we submit taken into consideration, or is it just a waste of time? If they are evaluated, where are the results published? For example, what happened with my specific request?
