DJFrens Posted January 9, 2025 Posted January 9, 2025 (edited) Hello i'm trying to setup a guest wifi on my sprinter kn-3710 it does work on the main router but not on the second one in extender mode. any idea what i'm doing wrong did follow the online instruction kind regards Edited January 10, 2025 by DJFrens Quote
0 Le ecureuil Posted January 12, 2025 Posted January 12, 2025 Do you have your extender acquired in the MWS or did you configured it manually? Quote
0 DJFrens Posted January 12, 2025 Author Posted January 12, 2025 hello used the aquire option in the interface of the main router, it looks like the clients dont get a ip from the ones in extender mode. Quote
0 markushka Posted January 14, 2025 Posted January 14, 2025 Is the connection via a cable? If so, make sure the Guest LAN is also shared on that port. 1 Quote
0 DJFrens Posted January 14, 2025 Author Posted January 14, 2025 11 hours ago, markushka said: Is the connection via a cable? If so, make sure the Guest LAN is also shared on that port. it does get a ip now on the extender, but no internet connection Quote
0 markushka Posted January 24, 2025 Posted January 24, 2025 If it is connected with a cable, ensure the port is the WAN port on the sprinter, and on your main router, in Guest Segment, ensure under Ports and VLAN Settings, that T is on the port where the extender cable is attached. Show other segments should have a tick for Home Segment on the same port. Under IP Settings, make sure Use NAT is enabled and the Internet Traffic Handling Rules "Connection Policy" has your provider ISP connection selected. If the Guest Wifi works on the main router, personally, I would remove the extender from the mesh, factory reset and rejoin. Then you will know if it is a config on the main router or the extender. Quote
DJFrens
Hello
kind regards
Edited by DJFrens5 answers to this question
