S1nGeN0r Posted January 29, 2017 Share Posted January 29, 2017 Попытался установить Debian/Entware-3 в свой Giga II, У меня в логах, Ошибка 158 гуглил не смог найти как решить проблему. Что я делаю не так? Jan 29 20:52:37ndmOpkg::Manager: disk is set to: 67E3-17ED: Jan 29 20:52:37ndmOpkg::Manager: /tmp/mnt/EFI mounted to /tmp/mnt/EFI. Jan 29 20:52:37ndmOpkg::Manager: /tmp/mnt/EFI mounted to /opt/. Jan 29 20:52:37ndmOpkg::Manager: system failed [0xcffd0183], exit code 158. Jan 29 20:52:37ndmOpkg::Manager: init script reset to default: /opt/etc/initrc. Jan 29 20:52:37ndmOpkg::Manager: invalid initrc "/opt/etc/initrc": no such file or directory, trying /opt/etc/init.d/. Jan 29 20:52:37ndmCore::ConfigurationSaver: saving configuration... Jan 29 20:52:41ndmCore::ConfigurationSaver: configuration saved. Quote Link to comment Share on other sites More sharing options...
ndm Posted February 14, 2017 Share Posted February 14, 2017 Список возвращаемых кодов распаковщика: #define NPKG_EXIT_SUCCESS_ EXIT_SUCCESS #define NPKG_EXIT_BASE__ 128 #define NPKG_EXIT_USAGE_ NPKG_EXIT_BASE__ + 1 #define NPKG_EXIT_OSERR_ NPKG_EXIT_BASE__ + 2 #define NPKG_EXIT_MISSING_ARGUMENT_ NPKG_EXIT_USAGE_ #define NPKG_EXIT_UNKNOWN_OPTION_ NPKG_EXIT_USAGE_ #define NPKG_EXIT_UNKNOWN_ARGUMENT_ NPKG_EXIT_USAGE_ #define NPKG_EXIT_NO_OUTPUT_PATH_ NPKG_EXIT_USAGE_ #define NPKG_EXIT_NO_INPUT_PATH_ NPKG_EXIT_USAGE_ #define NPKG_EXIT_SYSLOG_FAILURE_ NPKG_EXIT_OSERR_ #define NPKG_EXIT_PIPE_FAILURE_ NPKG_EXIT_OSERR_ #define NPKG_EXIT_FORK_FAILURE_ NPKG_EXIT_OSERR_ #define NPKG_EXIT_OPEN_FAILURE_ NPKG_EXIT_BASE__ + 3 #define NPKG_EXIT_OPENDIR_FAILURE_ NPKG_EXIT_BASE__ + 4 #define NPKG_EXIT_READDIR_FAILURE_ NPKG_EXIT_BASE__ + 5 #define NPKG_EXIT_STAT_FAILURE_ NPKG_EXIT_BASE__ + 6 #define NPKG_EXIT_CHDIR_FAILURE_ NPKG_EXIT_BASE__ + 7 #define NPKG_EXIT_GZIP_FAILURE_ NPKG_EXIT_BASE__ + 8 #define NPKG_EXIT_WAIT_FAILURE_ NPKG_EXIT_BASE__ + 9 #define NPKG_EXIT_UNLINK_FAILURE_ NPKG_EXIT_BASE__ + 10 #define NPKG_EXIT_GETCWD_FAILURE_ NPKG_EXIT_BASE__ + 11 #define NPKG_EXIT_WPIPE_FAILURE_ NPKG_EXIT_BASE__ + 12 #define NPKG_EXIT_TAR_ALIGN_FAILURE_ NPKG_EXIT_BASE__ + 13 #define NPKG_EXIT_TAR_PARSE_FAILURE_ NPKG_EXIT_BASE__ + 14 #define NPKG_EXIT_TAR_OPEN_FILE_ NPKG_EXIT_BASE__ + 15 #define NPKG_EXIT_TAR_WRITE_FILE_ NPKG_EXIT_BASE__ + 16 #define NPKG_EXIT_TAR_TRUNC_FILE_ NPKG_EXIT_BASE__ + 17 #define NPKG_EXIT_TAR_MAKE_LINK_ NPKG_EXIT_BASE__ + 18 #define NPKG_EXIT_TAR_MAKE_SYMLINK_ NPKG_EXIT_BASE__ + 19 #define NPKG_EXIT_TAR_MAKE_DIR_ NPKG_EXIT_BASE__ + 20 #define NPKG_EXIT_TAR_CSUM_FAILURE_ NPKG_EXIT_BASE__ + 21 #define NPKG_EXIT_TAR_DATA_OOM_ NPKG_EXIT_BASE__ + 22 #define NPKG_EXIT_EXT_MISMATCH_ NPKG_EXIT_BASE__ + 30 @S1nGeN0r у Вас некорректное имя файла в каталоге install. Должно быть одно из: tar_gz_data_handler_t dh = __extension(package_path, "ipk") ? __extract_opkg : __extension(package_path, "opk") ? __extract_opkg : __extension(package_path, "deb") ? __extract_opkg : __extension(package_path, "tgz") ? __extract_data : __extension(package_path, "tar.gz") ? __extract_data : NULL; if (dh == NULL) { return NPKG_EXIT_EXT_MISMATCH_; } 3 Quote Link to comment Share on other sites More sharing options...
S1nGeN0r Posted February 14, 2017 Author Share Posted February 14, 2017 (edited) Изменил расширение архива с tar на tar.gz все работает. Edited February 14, 2017 by S1nGeN0r Quote Link to comment Share on other sites More sharing options...
