Posted (edited)
A WiFi scale (probably ESP32 based) uses 2.4 GHz to sync.
The problem is: the device connects successfully to the old Keenetic Ultra2, but can't connect to the modern Keenetic Challenger SE (KN-3911) with the same WiFi settings.
ku_rd config fragment:
interface WifiMaster0
    country-code DE
    compatibility BGN
    rekey-interval 86400
    up
interface WifiMaster0/AccessPoint0
    rename AccessPoint
    description "Wi-Fi access point"
    dyndns nobind
    mac access-list type none
    wps
    authentication wpa-psk ns3 xxxxx
    encryption enable
    encryption wpa2
    ip dhcp client dns-routes
    ip name-servers
    ssid Deutschland25
    wmm
    rrm
    up
interface WifiMaster0/AccessPoint1
    rename GuestWiFi
    dyndns nobind
    authentication wpa-psk ns3 xxxxxx
    encryption enable
    encryption wpa2
    ip name-servers
    ssid Umbreon
    rrm
    up
KN-3911 config fragment:
    country-code DE
    compatibility BGN+AX
    channel width 40-below
    tx-burst
    beamforming explicit
    atf inbound
    vht
    downlink-mumimo
    uplink-mumimo
    spatial-reuse
    up
    rename AccessPoint
    wps
    wps no auto-self-pin
    encryption enable
    encryption wpa2
    ssid Deutschland25
    wmm
    rrm
    up
    rename GuestWiFi
    encryption enable
    encryption wpa2
    ssid Umbreon
    rrm
    up
It looks like some new features are incompatible with old legacy wifi clients.
During non-successful attempts there are the next entries-set in the log:
[I] Apr 21 23:18:28 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(d0:49:00:2f:c1:91) had associated.
[I] Apr 21 23:18:28 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(d0:49:00:2f:c1:91) MIC differs in key handshaking (msg 2 of 4-way).
[I] Apr 21 23:18:32 ndm: Core::Syslog: last message repeated 4 times.
[I] Apr 21 23:18:33 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(d0:49:00:2f:c1:91) had deauthenticated by AP (reason: previous auth no longer valid).
Can anyone suggest which setting add/remove to achieve compatibility?
Edited by alfonder
1 answer to this question
Posted
Additionally, here is the log from ku_rd on successful connection of the scale:
[I] Apr 25 00:46:52 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(d0:49:00:2f:c1:91) had associated.
[I] Apr 25 00:46:52 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint1": STA(d0:49:00:2f:c1:91) set key done in WPA2/WPA2PSK.
