When I change the Wi-Fi channel from My Networks > Wi-Fi > Advanced Settings, the change is not immediately applied — the active channel remains the same. However, the new channel value is saved to both the startup-config and running-config files.
After a reboot, the device starts with the last saved channel (as per the config), but the change does not take effect instantly when applied from the interface.
It seems the configuration is written correctly but not pushed to the interface runtime unless the system is rebooted.
ru.celebi
There is an issue in version 5.0.A5.
0 answers to this question
