Posted (edited)
Hello,
I installed Telephone accesory to install VOIP in my home.
I also purchased a VoIP service that has been tested by Keenetic (Freecall).
This is the data provided by freecall
SIP port: 5060
Registrar: sip.freecall.com
Proxy server: sip.freecall.com
Outbound proxy server: leave empty
Account name: your FreeCall username
Password: your FreeCall password
Display name/number: your FreeCall username or voipnumber
Stunserver (option): stun.freecall.com
Codecs
G.711 (64 kbps)
G.726 (32 kbps)
G.729 (8 kbps)
G.723 (5.3 & 6.3 kbps)
GSMFR (13 kbps)
If you have audio problems:
Use a STUN server (e.g. stun.freecall.com with port 3478)
(if supported by your device)
Use the G.711 codec
Could you tellme how to configure each parameter on Keenetic Hero?
I was trying to do it unsucessfully as a freecall VoIP Provider...
Could you support me to configure it? I was dowloading windows APP for Freecall and it was working fine. But it's not working using my analog telephone. Thanks.
Edited by tasete30
2 answers to this question
Posted (edited)
Thanks @keen_parish27you are right.
I paired my analog phone to this provider.
I was trying to use freecall provider by default instead of "other",  but with your example was very easy to link it.
Thanks again.
Edited by tasete30
