TheBB Posted March 11, 2017 Share Posted March 11, 2017 (edited) Скрытый текст ### версия adb ~ # adb version Android Debug Bridge version 1.0.32 ### вывод списка устройств ~ # adb devices List of devices attached PMPхх016030хххх device ~ # adb devices -l List of devices attached PMPхх016030хххх device usb:2-1.2 product:PMT3108_3G model:PMT3108_3G device:PN80A03G ### тел Samsung (WaveII) ### до разрешения отладки ~ # adb devices List of devices attached хххххххххххххххх unauthorized ~ # adb devices -l List of devices attached хххххххххххххххх unauthorized usb:2-1.2 ### после принятия ~ # adb devices List of devices attached хххххххххххххххх device ~ # adb devices -l List of devices attached хххххххххххххххх device usb:2-1.2 product:omni_wave model:GT_S8530 device:wave работа с adb Скрытый текст ~ # adb shell shell@PN80A03G:/ $ busybox uname -a Linux localhost 3.14.0 #43 SMP PREEMPT Thu Aug 11 20:04:51 CST 2016 i686 GNU/Linux shell@PN80A03G:/ $ cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 93 model name : Genuine Intel(R) CPU @ 728 stepping : 1 microcode : 0x101 cpu MHz : 416.000 cache size : 512 KB physical id : 0 siblings : 4 core id : 2 cpu cores : 4 apicid : 4 initial apicid : 4 fdiv_bug : no f00f_bug : no coma_bug : no fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat clflush mmx fxsr sse sse2 ss ht nx rdtscp lm constant_tsc arch_perfmon xtopology pni pclmulqdq monitor ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt aes lahf_lm 3dnowprefetch tsc_adjust smep erms mm_type_aliasing bogomips : 892.92 clflush size : 64 cache_alignment : 64 address sizes : 32 bits physical, 48 bits virtual power management: ... shell@PN80A03G:/ $ ### тел ~ # adb shell root@wave:/ # busybox BusyBox v1.21.1-jb bionic (2013-07-25 21:23 +0100) multi-call binary. BusyBox is copyrighted by many authors between 1998-2012. Licensed under GPLv2. See source distribution for detailed copyright notices. Merged for bionic by tpruvot@github Usage: busybox [function [arguments]...] or: busybox --list or: function [arguments]... BusyBox is a multi-call binary that combines many common Unix utilities into a single executable. Most people will create a link to busybox for each function they wish to use and BusyBox will act like whatever it was invoked as. Currently defined functions: [, [[, adjtimex, arp, ash, awk, base64, basename, bbconfig, blkid, blockdev, brctl, bunzip2, bzcat, bzip2, cal, cat, catv, chattr, chgrp, chmod, chown, chroot, clear, cmp, comm, cp, cpio, crond, crontab, cut, date, dc, dd, depmod, devmem, df, diff, dirname, dmesg, dnsd, dos2unix, du, echo, ed, egrep, env, expand, expr, false, fbsplash, fdisk, fgrep, find, flash_lock, flash_unlock, flashcp, flock, fold, free, freeramdisk, fstrim, fsync, ftpget, ftpput, fuser, getopt, grep, groups, gunzip, gzip, halt, head, hexdump, id, ifconfig, inetd, insmod, install, ionice, iostat, ip, kill, killall, killall5, less, ln, losetup, ls, lsattr, lsmod, lsof, lsusb, lzcat, lzma, lzop, lzopcat, man, md5sum, mesg, mkdir, mkdosfs, mke2fs, mkfifo, mkfs.ext2, mkfs.vfat, mknod, mkswap, mktemp, modinfo, modprobe, more, mount, mountpoint, mpstat, mv, nanddump, nandwrite, nbd-client, nc, netstat, nice, nohup, nslookup, ntpd, od, patch, pgrep, pidof, ping, pipe_progress, pkill, pmap, poweroff, printenv, printf, ps, pstree, pwd, pwdx, rdev, readlink, realpath, reboot, renice, reset, resize, rev, rm, rmdir, rmmod, route, run-parts, rx, sed, seq, setconsole, setserial, setsid, sh, sha1sum, sha256sum, sha3sum, sha512sum, sleep, sort, split, stat, strings, stty, sum, swapoff, swapon, sync, sysctl, tac, tail, tar, taskset, tee, telnet, telnetd, test, tftp, tftpd, time, timeout, top, touch, tr, traceroute, true, ttysize, tune2fs, umount, uname, uncompress, unexpand, uniq, unix2dos, unlzma, unlzop, unxz, unzip, uptime, usleep, uudecode, uuencode, vi, watch, wc, wget, which, whoami, xargs, xz, xzcat, yes, zcat root@wave:/ # busybox uname -a Linux localhost 3.0.101-g9800976 #2 PREEMPT Mon Jun 8 22:24:14 CEST 2015 armv7l GNU/Linux root@wave:/ # cat /proc/cpuinfo Processor : ARMv7 Processor rev 2 (v7l) BogoMIPS : 99.26 Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x2 CPU part : 0xc08 CPU revision : 2 Hardware : wave2 Revision : 0030 Serial : хххххххххххххххх root@wave:/ # + "шнурок+воздух" ~ # adb devices List of devices attached 192.168.5.3:5555 device PMPхх016030хххх device ++ пакет в репах Edited June 10, 2017 by TheBB ++ 1 Quote Link to comment Share on other sites More sharing options...
kekych Posted March 11, 2017 Share Posted March 11, 2017 А на телефоне, что необходимо сделать, чтобы появилась возможность подключаться "по воздуху"? Режим отладки включен, через кабель спокойно подключается Quote Link to comment Share on other sites More sharing options...
TheBB Posted March 11, 2017 Author Share Posted March 11, 2017 На телефоне должно быть что-то, вроде "ADB over network" ~ # adb connect 192.168.5.8 connected to 192.168.5.8:5555 ~ # adb shell root@wave:/ # ls -al / drwxr-xr-x root root 2017-03-11 19:48 acct -rw-r--r-- root root 388 2017-03-11 19:48 boot.txt drwxrwx--- system cache 2015-06-24 00:18 cache lrwxrwxrwx root root 2017-03-11 19:48 charger -> /sbin/healthd dr-x------ root root 2017-03-11 19:48 config lrwxrwxrwx root root 2017-03-11 19:48 d -> /sys/kernel/debug drwxrwx--x system system 2005-01-03 02:57 data -rw-r--r-- root root 301 2017-03-11 19:48 default.prop drwxr-xr-x root root 2017-03-11 20:00 dev ... Quote Link to comment Share on other sites More sharing options...
kekych Posted March 11, 2017 Share Posted March 11, 2017 (edited) Вот теперь понятно Рассчитывал, что "из под коробки" на телефоне будет работать, но не суть. Edited March 11, 2017 by kekych Quote Link to comment Share on other sites More sharing options...
TheBB Posted March 11, 2017 Author Share Posted March 11, 2017 "Настройки" -> "Для разработчиков" -> "ADB over network" Quote Link to comment Share on other sites More sharing options...
edm Posted June 13, 2017 Share Posted June 13, 2017 (edited) как перепрошить телефон через наш роутер?) в режиме загрузчика(перепрошивки) adb не видит мое устройство в режиме рекавери и в Вкл_телефона adb отпределяет Edited June 13, 2017 by edm Quote Link to comment Share on other sites More sharing options...
zackiel Posted December 12, 2017 Share Posted December 12, 2017 В 13.06.2017 в 17:59, edm сказал: как перепрошить adb sideload прошивка.zip Quote Link to comment Share on other sites More sharing options...
drts Posted January 29, 2021 Share Posted January 29, 2021 Прошу подсказки, как при перезагрузке роутера выполнять adb connect ip_adress_tv для автоматического подключения к устройству. Quote Link to comment Share on other sites More sharing options...
Андрей Волосков Posted December 21, 2023 Share Posted December 21, 2023 (edited) Вот тут заморочился с камерой, у меня подключена на старый планшет через rtsp, при нажатии питания на планшете уже выводит нужную картинку, хочу при помощи ADB сделать, что бы включался, команда есть, осталось придумать как сделать так, что бы при появлении одного устройства в сети с адресом 192.168.3.33 отправлялась эта команда на планшет.... ДА и похоже пакет старый, коннектится, но команды не отправляет, пишет device offline Edited December 21, 2023 by Андрей Волосков Quote Link to comment Share on other sites More sharing options...
