I'm using keenetic stuff in a mesh configuration. kn-2710 is controller, seven extenders kn-3510 as mesh nodes. All mesh nodes connected using poe cables through 24 ports d-link gds-1100. Everything is fine untill I add new segment so clients who is trying to connect to wifi network through new segment has no response from dhcp. In my oppinion, there is no way to connect to another segment using wifi through mesh node belonged to one segment and connected by wire network. Am i right? What's the way to have several segments and working wired mesh?
I've tried segments isolation in all ways, vlan marking and mixing wires from several segments of kn-2710 through d-link switch with no result.
George Petrov
Hello,
Thank you
George
1 answer to this question
