  • 1
Connection Issues between PS5 Pro and Titan 1812 via Wifi 7 and MLO
Posted
I am a PS5 Pro owner, and despite the console supporting wifi 7 and MLO, I am experiencing significant connection issues when trying to connect to my Titan 1812 router. Here are the specific problems:
AX/BE 5ghz band issues: The device fails to connect to the 5 ghz band (AX or BE). it consistently defaults to 2.4 ghz. I have tried adjusting the band steering to favor 5 ghz and even forced the device to only use 5 ghzz, but in those cases, it refuses to connect entirely.
Low speeds on 2.4 ghz BE: It does connect via 2.4 ghz BE, but the speeds are capped around 50-60 Mbps, even though the Titan is positioned very close to the PS5.
MLO failure: After establishing a 2.4 ghz connection, whenever I enable MLO in the PS5 settings, the connection drops completely.
I suspect this is an issue related to the Titan router, as I have tested this with another Playstation device and encountered the same results. Are there any other PS5 Pro and Titan 1812 users experiencing similar issues?
Thanks.
  • Upvote 2
0 answers to this question
