Имеем связку
Клиент - Giga II ("белый" IP) 2.09.A.6.0-3
"Сервер" - Ultra II ("белый" IP) 2.09.A.7.0-0
Все настроено согласно "предписаний" - https://help.keenetic.net/hc/ru/articles/214471405-Организация-туннеля-IPSec-VPN-между-двумя-интернет-центрами-Keenetic-Ultra-II-и-Giga-III
"связка" никак не вяжется ни при каких "танцах с бубном" .... Фаза1 и Фаза2 настроены "один в один" ,  ключ PSK совпадает и проверялся 100раз , IKE v1 или v2 - безрезультатно  ......
Посоветуте "таблетку" .... ибо все пропало !
в логе на Ultra II ->
Apr 30 09:11:48ipsec08[IKE] received DPD vendor ID
Apr 30 09:11:48ipsec08[IKE] received FRAGMENTATION vendor ID
Apr 30 09:11:48ipsec08[IKE] received NAT-T (RFC 3947) vendor ID
Apr 30 09:11:48ipsec08[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Apr 30 09:11:48ipsec08[IKE] GigaII-IP is initiating a Main Mode IKE_SA
Apr 30 09:11:48ipsec08[CFG] received proposals: IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768/#
Apr 30 09:11:48ipsec08[CFG] configured proposals: IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768/#
Apr 30 09:11:48ipsec08[CFG] selected proposal: IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768/#
Apr 30 09:11:48ipsec08[IKE] sending DPD vendor ID
Apr 30 09:11:48ipsec08[IKE] sending FRAGMENTATION vendor ID
Apr 30 09:11:48ipsec08[IKE] sending NAT-T (RFC 3947) vendor ID
Apr 30 09:11:48ipsec07[IKE] linked key for crypto map '(unnamed)' is not found, still searching
Apr 30 09:11:48ipsec07[IKE] no shared key found for 'UltraII-IP'[UltraII-IP] - '(null)'[GigaII-IP]
Apr 30 09:11:48ipsec07[IKE] no shared key found for UltraII-IP - GigaII-IP
В web-интерфейсе GigaII при попытке редактирования пропадают адреса ->
Дальше - еще больше ))) Создаем на Ultra II - Сервер IPsec Virtual IP
Подключаемся с компа (MacOS)
Apr 30 09:39:17ipsec13[IKE] received NAT-T (RFC 3947) vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID
Apr 30 09:39:17ipsec13[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Apr 30 09:39:17ipsec13[IKE] received XAuth vendor ID
Apr 30 09:39:17ipsec13[IKE] received Cisco Unity vendor ID
Apr 30 09:39:17ipsec13[IKE] received FRAGMENTATION vendor ID
Apr 30 09:39:17ipsec13[IKE] received DPD vendor ID
Apr 30 09:39:17ipsec13[IKE] GigaII-IP is initiating a Main Mode IKE_SA
Apr 30 09:39:17ipsec13[CFG] received proposals: IKE:AES_CBC=256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_2048/#, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048/#, IKE:AES_CBC=256/HMAC_MD5_96/PRF_HMAC_MD5/MODP_2048/#, IKE:AES_CBC=256/HMAC_SHA2_512_256/PRF_HMAC_SHA2_512/MODP_2048/#, IKE:AES_CBC=256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_1536/#, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536/#, IKE:AES_CBC=256/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1536/#, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:AES_CBC=256/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024/#, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:AES_CBC=128/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024/#, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:3DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024/#, IKE:DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024/#
Apr 30 09:39:17ipsec13[CFG] configured proposals: IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#
Apr 30 09:39:17ipsec13[CFG] selected proposal: IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#
Apr 30 09:39:17ipsec13[IKE] sending XAuth vendor ID
Apr 30 09:39:17ipsec13[IKE] sending DPD vendor ID
Apr 30 09:39:17ipsec13[IKE] sending Cisco Unity vendor ID
Apr 30 09:39:17ipsec13[IKE] sending FRAGMENTATION vendor ID
Apr 30 09:39:17ipsec13[IKE] sending NAT-T (RFC 3947) vendor ID
Apr 30 09:39:17ipsec14[IKE] remote host is behind NAT
Apr 30 09:39:17ipsec14[IKE] linked key for crypto map '(unnamed)' is not found, still searching
Apr 30 09:39:17ipsec14[IKE] no shared key found for 'mykeenetic.net'[UltraII-IP] - '(null)'[GigaII-IP]
Apr 30 09:39:17ipsec14[IKE] no shared key found for ULtraII-IP - GigaII-IP
И как теперь удаленно добираться в локальную сеть ? :(
Заранее благодарен за помощь в решении описанных проблем ....
Edited by Dorik1972
30 минут назад, KorDen сказал:
А какой у вас тип идентификаторов используется, email или что?
Я пробовал как IP так и e-mail и FQDN .... собственно это , если следовать "классике" не особо важно ... Главное чтобы совпадало на обоих устройствах ... Да и какое отношение имеет идентификатор к неработающей "связке" MacOS и Сервер IPsec Virtual IP ? Тут скорее всего дело в
Одинаково "грустно" в обоих случаях .... ибо до этого момента - все ОК, судя по логам .....
7 часов назад, Dorik1972 сказал:
Начиная с 2.09.A.6.0-0 virtual ip и обычный туннель вместе не работают на сервере.
54 минуты назад, r13 сказал:
Я в курсе .... тестировалось раздельно ..... это потом уже в качестве эксперимента - virtual ip ...
Но чудо таки свершилось ... после 100500 перегрузок "сервера" и "клиента" , и НИЧЕГО не меняя в настройках соединения, все ожило ..... Продолжаю наблюдать .....
