Port forwarding with IP instead of MAC when using Keenetic Buddy extender
Posted
Hello, In Keenetic modem configuration, port forwarding requires selecting a Registered client, which is based on MAC address. When using a Keenetic Buddy Wi‑Fi extender, all devices behind its ethernet port appear with the same MAC address, so my virtual machines cannot be registered individually.
I would like to:
  1. Register clients by IP address instead of MAC.
  2. Configure port forwarding rules directly to an IP address, not tied to a registered MAC client.
Is this possible in Keenetic firmware, or is there any workaround for VM environments behind a Buddy extender where MAC addresses are duplicated?
Thanks.
1 answer to this question
Posted
Hi Ceyhun,
in port forwarding is possible to select also unregistered clients. In this way you can select IP address directly, without needs to register all the clients. Attached an example.
Regards
