TheBB Posted February 20, 2020 Share Posted February 20, 2020 2 часа назад, Сергей Грищенко сказал: возможно у вас есть идеи куда копать и где исправлять? telnet 192.168.xxx.xxx Trying 192.168.xxx.xxx... Connected to 192.168.xxx.xxx. Escape character is '^]'. Login: admin Password: **************** THIS SOFTWARE IS A SUBJECT OF KEENETIC LIMITED END-USER LICENCE AGREEMENT. BY USING IT YOU AGREE ON TERMS AND CONDITIONS HEREOF. FOR MORE INFORMATION PLEASE CHECK https://keenetic.com/legal (config)> exec /opt/bin/sh BusyBox v1.31.1 () built-in shell (ash) / # echo $PATH /bin:/sbin:/usr/bin:/usr/sbin / # / # . /opt/etc/profile / # / # echo $PATH /opt/sbin:/opt/bin:/opt/usr/sbin:/opt/usr/bin:/usr/sbin:/usr/bin:/sbin:/bin / # дальше починяйте то, что сломалось. start, restart, pid, и т.д. Quote Link to comment Share on other sites More sharing options...
Сергей Грищенко Posted February 20, 2020 Share Posted February 20, 2020 (edited) 1 hour ago, TheBB said: дальше починяйте то, что сломалось. start, restart, pid, и т.д. Вошел, правда дальше моих знаний не хватает в понятии причины Last login: Thu Feb 20 10:34:40 on ttys000 admin@MacBook-Pro-admin-3 ~ % telnet 192.168.1.1 Trying 192.168.1.1... Connected to 192.168.1.1. Escape character is '^]'. KeeneticOS version 3.03.C.10.0-0, copyright (c) 2010-2019 Keenetic Ltd. Login: admin Password: ************* THIS SOFTWARE IS A SUBJECT OF KEENETIC LIMITED END-USER LICENCE AGREEMENT. BY USING IT YOU AGREE ON TERMS AND CONDITIONS HEREOF. FOR MORE INFORMATION PLEASE CHECK https://keenetic.com/legal (config)> exec /opt/bin/sh BusyBox v1.31.0 () built-in shell (ash) / # echo $PATH /opt/bin:/opt/sbin:/opt/usr/bin:/opt/usr/sbin:/bin:/sbin:/usr/bin:/usr/sbin / # . /opt/etc/profile / # echo $PATH /opt/sbin:/opt/bin:/opt/usr/sbin:/opt/usr/bin:/usr/sbin:/usr/bin:/sbin:/bin / # / # ls -l drwxr-xr-x 2 root root 205 Feb 19 20:01 bin drwxrwxrwt 8 root root 2360 Feb 20 05:54 dev drwxr-xr-x 6 root root 526 Feb 19 20:01 etc drwxr-xr-x 2 root root 122 Feb 19 20:01 flash drwxr-xr-x 4 root root 1597 Feb 10 16:18 lib drwxr-xr-x 13 root root 4096 Feb 19 19:16 opt dr-xr-xr-x 180 root root 0 Jan 1 1970 proc drwxr-xr-x 2 root root 3 Feb 10 16:12 root drwxr-xr-x 2 root root 144 Feb 19 20:01 sbin drwxr-xr-x 3 root root 0 Jan 1 1970 storage dr-xr-xr-x 11 root root 0 Jan 1 1970 sys drwxrwxrwt 13 root root 560 Feb 20 06:17 tmp drwxr-xr-x 8 root root 113 Feb 10 16:18 usr lrwxrwxrwx 1 root root 4 Feb 19 20:01 var -> /tmp Edited February 20, 2020 by Сергей Грищенко Quote Link to comment Share on other sites More sharing options...
TheBB Posted February 20, 2020 Share Posted February 20, 2020 проверяйте сервис, проверяйте pid (config)> exec /opt/bin/sh BusyBox v1.31.1 () built-in shell (ash) / # ls -al /opt/var/run/ /opt/bin/sh: ls: not found / # / # . /opt/etc/profile / # / # ls -al /opt/var/run/ итого 16 drwxr-xr-x 3 root root 4096 фев 20 11:58 . drwxr-xr-x 7 root root 4096 янв 31 16:27 .. -rw-r--r-- 1 root root 6 фев 20 11:58 dropbear.pid drwxr-xr-x 2 root root 4096 янв 31 16:27 mysqld / # / # ps | grep -v grep | grep drop 650 root 1620 S /usr/sbin/dropbear 32158 root 2720 S /opt/sbin/dropbear -p 222 -P /opt/var/run/dropbear.pid / # если сервиса нет в процессах, а pid-файл остался - удаляйте pid и стартуйте сервис... вариантов поломки, как и вариантов решения - много. Quote Link to comment Share on other sites More sharing options...
Сергей Грищенко Posted February 20, 2020 Share Posted February 20, 2020 4 minutes ago, TheBB said: проверяйте сервис, проверяйте pid если сервиса нет в процессах, а pid-файл остался - удаляйте pid и стартуйте сервис... вариантов поломки, как и вариантов решения - много. Login: admin Password: ************* THIS SOFTWARE IS A SUBJECT OF KEENETIC LIMITED END-USER LICENCE AGREEMENT. BY USING IT YOU AGREE ON TERMS AND CONDITIONS HEREOF. FOR MORE INFORMATION PLEASE CHECK https://keenetic.com/legal (config)> exec /opt/bin/sh BusyBox v1.31.0 () built-in shell (ash) / # ls -al /opt/var/run/ drwxr-xr-x 2 root root 4096 Feb 20 06:17 . drwxrwxrwx 8 root root 4096 Feb 19 19:15 .. -rw-r--r-- 1 root root 5 Feb 20 06:16 cron.pid -rw-r--r-- 1 nobody nobody 5 Feb 20 06:17 dnsmasq.pid -rw-r--r-- 1 root root 0 Feb 19 19:15 dropbear.pid -rw-r--r-- 1 root root 5 Feb 20 06:17 tor.pid / # . /opt/etc/profile / # ls -al /opt/var/run/ drwxr-xr-x 2 root root 4096 Feb 20 06:17 . drwxrwxrwx 8 root root 4096 Feb 19 19:15 .. -rw-r--r-- 1 root root 5 Feb 20 06:16 cron.pid -rw-r--r-- 1 nobody nobody 5 Feb 20 06:17 dnsmasq.pid -rw-r--r-- 1 root root 0 Feb 19 19:15 dropbear.pid -rw-r--r-- 1 root root 5 Feb 20 06:17 tor.pid / # ps | grep -v grep | grep drop 585 root 1616 S /usr/sbin/dropbear / # запустил вруную и смог войти. / # /opt/sbin/dropbear -p 222 -P /opt/var/run/dropbear.pid / # ps | grep -v grep | grep drop 585 root 1616 S /usr/sbin/dropbear 15610 root 2724 S /opt/sbin/dropbear -p 222 -P /opt/var/run/dropbear.pid Но почему он не стартует после рестарта и как починить это? Quote Link to comment Share on other sites More sharing options...
TheBB Posted February 20, 2020 Share Posted February 20, 2020 11 минуту назад, Сергей Грищенко сказал: Но почему он не стартует после рестарта и как починить это? Остаётся "хвост" - "dropbear.pid". Сбой ФС, некорректное размонтирование, питание (отключение, скачки напряжения, ...), ... . /opt/etc/profile ^служит для обновления рабочего окружения (в моём случае - "PATH") / # echo $PATH /bin:/sbin:/usr/bin:/usr/sbin / # / # ls -al /opt/var/run/ /opt/bin/sh: ls: not found / # Quote Link to comment Share on other sites More sharing options...
Сергей Грищенко Posted February 20, 2020 Share Posted February 20, 2020 22 minutes ago, TheBB said: Остаётся "хвост" - "dropbear.pid". Сбой ФС, некорректное размонтирование, питание (отключение, скачки напряжения, ...), ... . /opt/etc/profile ^служит для обновления рабочего окружения (в моём случае - "PATH") / # echo $PATH /bin:/sbin:/usr/bin:/usr/sbin / # / # ls -al /opt/var/run/ /opt/bin/sh: ls: not found / # Спасибо вам за помощь! Проблему смог решить следующим способом: запустил вручную /opt/sbin/dropbear -p 222 -P /opt/var/run/dropbear.pid и дал права cmod 777 на все файлы в папке ls -al /opt/var/run/ Quote Link to comment Share on other sites More sharing options...
zyxmon Posted February 22, 2020 Author Share Posted February 22, 2020 Самое правильное решение с pid файлом (если тут такой случай) помещать pid на tmpfs. После перезагрузки его не будет. Для кинетиков это в стартовом скрипте отредактировать примерно так PIDFILE="/opt/var/run/dropbear.pid" ---> PIDFILE="/tmp/run/entw_dropbear.pid" Quote Link to comment Share on other sites More sharing options...
The_Immortal Posted April 1, 2020 Share Posted April 1, 2020 (edited) Приветствую! Руководствовался установкой Entware отсюда (до 7 п.). В итоге в логах следующее: Апр 1 17:59:37 ndm Opkg::Manager: /tmp/mnt/d07dbe99-6ade-54bf-a25d-df9390ec4a49 mounted to /opt/. Апр 1 17:59:37 ndm Opkg::Manager: system failed [0xcffd01ca], exit code 158. Апр 1 17:59:37 ndm Opkg::Manager: configured init script: "/opt/etc/init.d/rc.unslung". Апр 1 17:59:37 ndm Opkg::Manager: invalid initrc "/opt/etc/init.d/rc.unslung": no such file or directory, trying /opt/etc/init.d/. Апр 1 17:59:37 ndm Core::ConfigurationSaver: saving configuration... Апр 1 17:59:40 ndm Core::ConfigurationSaver: configuration saved. И после тишина... Никакой установки не происходит. Флешка (на Ext4) при этом подключена, видна, доступ к ней имеется через веб-морду Кинетика. Подскажите, пожалуйста, как быть? Спасибо! Edited April 1, 2020 by The_Immortal Quote Link to comment Share on other sites More sharing options...
The_Immortal Posted April 1, 2020 Share Posted April 1, 2020 (edited) Полный лог: Апр 1 17:59:22 kernel EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) Апр 1 17:59:22 ndm FileSystem::Repository: "d07dbe99-6ade-54bf-a25d-df9390ec4a49:" mounted. Апр 1 17:59:37 ndm Opkg::Manager: disk is set to: ENTWARE:/. Апр 1 17:59:37 kernel EXT4-fs (sda1): re-mounted. Opts: (null) Апр 1 17:59:37 ndm Opkg::Manager: /tmp/mnt/d07dbe99-6ade-54bf-a25d-df9390ec4a49 mounted to /tmp/mnt/d07dbe99-6ade-54bf-a25d-df9390ec4a49. Апр 1 17:59:37 ndm Opkg::Manager: /tmp/mnt/d07dbe99-6ade-54bf-a25d-df9390ec4a49 mounted to /opt/. Апр 1 17:59:37 ndm Opkg::Manager: system failed [0xcffd01ca], exit code 158. Апр 1 17:59:37 ndm Opkg::Manager: configured init script: "/opt/etc/init.d/rc.unslung". Апр 1 17:59:37 ndm Opkg::Manager: invalid initrc "/opt/etc/init.d/rc.unslung": no such file or directory, trying /opt/etc/init.d/. Апр 1 17:59:37 ndm Core::ConfigurationSaver: saving configuration... Апр 1 17:59:40 ndm Core::ConfigurationSaver: configuration saved. Полагаю, что проблема в Opkg::Manager: system failed [0xcffd01ca], exit code 158. - но что конкретно это может означать? Edited April 1, 2020 by The_Immortal Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 1, 2020 Share Posted April 1, 2020 35 минут назад, The_Immortal сказал: Полагаю, что проблема в Opkg::Manager: system failed [0xcffd01ca], exit code 158. - но что конкретно это может означать? при-установке-ошибка-exit-code-158 1 Quote Link to comment Share on other sites More sharing options...
The_Immortal Posted April 1, 2020 Share Posted April 1, 2020 (edited) Благодарю! Я на кой-то распаковал предварительно tar.gz до taz. Однако всё равно не сдается... На этапе "[2/5] Загрузка и установка основных пакетов.." почти через каждый пакет было Апр 1 19:46:03 ndm Opkg::Manager: /opt/etc/init.d/doinstall: timed out. приходилось флешку переподключать. Теперь доходит до: Апр 1 19:54:35 installer Info: Устанавливается пакет "entware-release"... Апр 1 19:54:54 installer Critical error: Во время установки пакета "entware-release" произошла ошибка. Апр 1 19:54:54 installer Выход из установки. Апр 1 19:54:54 ndm Opkg::Manager: /opt/etc/init.d/doinstall: exit code 1. Edited April 1, 2020 by The_Immortal Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 1, 2020 Share Posted April 1, 2020 проверяйте сеть/сетевые настройки. Quote Link to comment Share on other sites More sharing options...
The_Immortal Posted April 1, 2020 Share Posted April 1, 2020 (edited) У меня никаких проблем с сетью нету. Апр 1 22:19:15 installer [2/5] Загрузка и установка основных пакетов... Апр 1 22:19:18 installer Info: Устанавливается пакет "libgcc"... Апр 1 22:19:19 installer Info: Пакет "libgcc" установлен. Апр 1 22:19:21 installer Info: Устанавливается пакет "libc"... Апр 1 22:19:22 installer Info: Пакет "libc" установлен. Апр 1 22:19:24 ndm Opkg::Manager: /opt/etc/init.d/doinstall: /opt/etc/init.d/doinstall: line 109: dots.sh: not found. Апр 1 22:19:24 installer Info: Устанавливается пакет "libpthread"... Апр 1 22:19:25 installer Info: Пакет "libpthread" установлен. Апр 1 22:19:27 installer Info: Устанавливается пакет "librt"... Апр 1 22:19:29 installer Info: Пакет "librt" установлен. Апр 1 22:19:31 installer Info: Устанавливается пакет "entware-release"... Апр 1 22:19:48 installer Critical error: Во время установки пакета "entware-release" произошла ошибка. Апр 1 22:19:48 installer Выход из установки. Апр 1 22:19:48 ndm Opkg::Manager: /opt/etc/init.d/doinstall: exit code 1. Че-то даже и не знаю, что делать. Проверил флешку через H2testw - никаких бэдов. Edited April 1, 2020 by The_Immortal Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 1, 2020 Share Posted April 1, 2020 14 минуты назад, The_Immortal сказал: Че-то даже и не знаю, что делать. Проверил флешку через H2testw - никаких бэдов. Всё снести (форматировать не надо), создать каталог "install" и скопировать в него архив установщика, в "морде лица" на вкладке "OPKG" выбрать диск и жмякнуть "Сохранить"... судя по логу, были неоднократные попытки "потыкать установку" - не прокатило ))) 1 Quote Link to comment Share on other sites More sharing options...
Depeshev Posted April 5, 2020 Share Posted April 5, 2020 Добрый день. В процессе выполнения команды apt-get update и apt-get upgrade моргнул свет и больше в entware зайти не могу. Отсюда вопрос - при установке на этот же диск entware, создав папку install и закинув в нее ....tar.gz, не удалятся ли все данные с диска? У меня на диске папки с архивами, фото и видео. Понимаю, что он перепишет файлы настроек, но больше тревожат мои файлы на этом же диске. Был ли у кого такой опыт? Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 5, 2020 Share Posted April 5, 2020 2 часа назад, Depeshev сказал: Был ли у кого такой опыт? полно 2 часа назад, Depeshev сказал: Понимаю, что он перепишет файлы настроек, но больше тревожат мои файлы на этом же диске сделать копию важных файлов не вариант? 2 часа назад, Depeshev сказал: Отсюда вопрос - при установке на этот же диск entware, создав папку install и закинув в нее ....tar.gz, не удалятся ли все данные с диска? если не будете форматировать, все останется, будут перезаписаны только файлы из установщика по зависимостям. Главное - не паниковать и делать всё аккуратно. Может сначала попытаться восстановить саму систему? Quote Link to comment Share on other sites More sharing options...
Depeshev Posted April 5, 2020 Share Posted April 5, 2020 Система не запускается, видать часть файлов обновилась , часть не успела, а другая осталась без изменений. Сделать архив думал - это обязательно сделаю, т.к. их ценность слишком велика. Спасибо за ответ. Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 5, 2020 Share Posted April 5, 2020 Т.к. на носителе имеются ценные данные, дальнейший разбор теряет смысл. На деле, может статься, не так всё "печально". Слетел(и) симлинк(и), остал(-ся,-ись) PID-файл(ы) на диске и "мешают" старту сервисов (т.к. последние (сервисы/демоны) считают, что уже запущены), продолжать можно долго, но... см. начало Quote Link to comment Share on other sites More sharing options...
vlzsilver Posted April 25, 2020 Share Posted April 25, 2020 (edited) на 2-х роутерах получаю: пр 25 21:32:55 installer [1/5] Начало установки системы пакетов "Entware"... Апр 25 21:32:55 ndm Core::Server: started Session /var/run/ndm.core.socket. Апр 25 21:32:56 ndm Core::Session: client disconnected. Апр 25 21:32:56 ndm Core::Server: started Session /var/run/ndm.core.socket. Апр 25 21:32:57 ndm Core::Session: client disconnected. Апр 25 21:32:57 installer Info: Раздел NTFS! атрибуты "user:group" могут не поддерживаться. Апр 25 21:32:57 installer При возникновении проблем, используйте накопитель с файловой системой ext2/ext3/ext4. Апр 25 21:32:57 installer Info: "ping google.com"... Апр 25 21:32:57 ndm Opkg::Manager: /opt/etc/init.d/doinstall: installer: Info: "ping google.com"... Апр 25 21:32:59 ndm Core::ConfigurationSaver: configuration saved. Апр 25 21:32:59 installer Info: "ping google.com" ..... OK Апр 25 21:32:59 ndm Opkg::Manager: /opt/etc/init.d/doinstall: installer: Info: "ping google.com" ..... OK. Апр 25 21:33:00 ndm Opkg::Manager: /opt/etc/init.d/doinstall: installer: Info: "ping bin.entware.net"... Апр 25 21:33:00 installer Info: "ping bin.entware.net"... Апр 25 21:33:03 ndm Opkg::Manager: /opt/etc/init.d/doinstall: installer: Info: "ping bin.entware.net" ..... OK. Апр 25 21:33:03 installer Info: "ping bin.entware.net" ..... OK Апр 25 21:33:04 installer Info: Создание каталогов... Апр 25 21:33:04 installer [2/5] Загрузка и установка основных пакетов... Апр 25 21:33:17 installer Info: Устанавливается пакет "libgcc"... Апр 25 21:34:05 ndm Opkg::Manager: /opt/etc/init.d/doinstall: timed out. Апр 25 21:34:05 ndm Process: killing all processes in "Opkg shell" group... Ставил OPKG не однократно, когда диск был с бэдами, ставил в феврале, когда меня роутер, сейчас такая ерунда и на флешке и на USB-HDD. Флешка и диск форматируется и работает на компе норм. Флешка в NTFS, Диск в Ext3 Лог установки на USB-HDD в EXT3 с Keenetic Viva (KN-1910) Апр 25 21:42:15 installer [1/5] Начало установки системы пакетов "Entware"... Апр 25 21:42:15 ndm Core::Server: started Session /var/run/ndm.core.socket. Апр 25 21:42:16 ndm Core::Session: client disconnected. Апр 25 21:42:16 ndm Core::Server: started Session /var/run/ndm.core.socket. Апр 25 21:42:16 ndm Core::Session: client disconnected. Апр 25 21:42:16 installer Info: Раздел пригоден для установки. Апр 25 21:42:16 installer Info: "ping google.com"... Апр 25 21:42:16 ndm Opkg::Manager: /opt/etc/init.d/doinstall: installer: Info: "ping google.com"... Апр 25 21:42:18 installer Info: "ping google.com" ..... OK Апр 25 21:42:18 ndm Opkg::Manager: /opt/etc/init.d/doinstall: installer: Info: "ping google.com" ..... OK. Апр 25 21:42:18 ndm Core::ConfigurationSaver: configuration saved. Апр 25 21:42:19 installer Info: "ping bin.entware.net"... Апр 25 21:42:19 ndm Opkg::Manager: /opt/etc/init.d/doinstall: installer: Info: "ping bin.entware.net"... Апр 25 21:42:22 installer Info: "ping bin.entware.net" ..... OK Апр 25 21:42:22 ndm Opkg::Manager: /opt/etc/init.d/doinstall: installer: Info: "ping bin.entware.net" ..... OK. Апр 25 21:42:23 installer Info: Создание каталогов... Апр 25 21:42:24 installer [2/5] Загрузка и установка основных пакетов... Апр 25 21:42:42 installer Info: Устанавливается пакет "libgcc"... Апр 25 21:43:01 installer Info: Пакет "libgcc" установлен. Апр 25 21:43:03 installer Info: Устанавливается пакет "libc"... Апр 25 21:43:51 ndm Opkg::Manager: /opt/etc/init.d/doinstall: timed out. Апр 25 21:43:51 ndm Process: killing all processes in "Opkg shell" group... Edited April 25, 2020 by vlzsilver Quote Link to comment Share on other sites More sharing options...
vlzsilver Posted April 25, 2020 Share Posted April 25, 2020 похоже, да, что то с провайдером..... либо с маршрутом от этого провайдера до репозитория. Сделал копию репозитория, изменил конф установщика на своей вэб сервер и всё установилось Quote Link to comment Share on other sites More sharing options...
Максим Пономаренко Posted April 28, 2020 Share Posted April 28, 2020 В 25.04.2020 в 23:50, vlzsilver сказал: похоже, да, что то с провайдером..... либо с маршрутом от этого провайдера до репозитория. Сделал копию репозитория, изменил конф установщика на своей вэб сервер и всё установилось Аналогичная балалайка. Выпадает тайм-аут. (Чаще в момент установки бусибокса) Поделись, пожалуйста, репозиторий откуда это добро качается. Попытаюсь провернуть твою затею. Quote Link to comment Share on other sites More sharing options...
vlzsilver Posted April 28, 2020 Share Posted April 28, 2020 (edited) 11 час назад, Максим Пономаренко сказал: Аналогичная балалайка. Выпадает тайм-аут. (Чаще в момент установки бусибокса) Поделись, пожалуйста, репозиторий откуда это добро качается. Попытаюсь провернуть твою затею. в инсталлере есть opkg.conf. В нем прописан адрес сайта. я его выкачал весь и положил к себе на веб сервер. после. изменил в этом же файле на адрес своего сервера и все установилась без проблем. Там нужных файлов на ~900 метров Edited April 28, 2020 by vlzsilver Quote Link to comment Share on other sites More sharing options...
zyxmon Posted April 28, 2020 Author Share Posted April 28, 2020 46 минут назад, vlzsilver сказал: я его выкачал весь А разрешение у нас на это почему не спросили? Раньше при массовом скачивании пакетов пользователь автоматически банился на сутки! Есть же offline установщик без скачивания! Quote Link to comment Share on other sites More sharing options...
Max Ponomarenko Posted April 28, 2020 Share Posted April 28, 2020 2 часа назад, zyxmon сказал: А разрешение у нас на это почему не спросили? Раньше при массовом скачивании пакетов пользователь автоматически банился на сутки! Есть же offline установщик без скачивания! А где бы его скачать? Уже какой раз выпадает тайм аут, пробовал и через VPN и так. Ни в какую ... Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 28, 2020 Share Posted April 28, 2020 1 час назад, Max Ponomarenko сказал: А где бы его скачать? надо собирать заново. 1 час назад, Max Ponomarenko сказал: Уже какой раз выпадает тайм аут, пробовал и через VPN и так. Ни в какую ... в интернетах "шторм 9 балов": то не ресолвит, то по IP не пускает, то всё вместе и стоит колом. Quote Link to comment Share on other sites More sharing options...
vlzsilver Posted April 28, 2020 Share Posted April 28, 2020 (edited) 4 часа назад, zyxmon сказал: А разрешение у нас на это почему не спросили? Раньше при массовом скачивании пакетов пользователь автоматически банился на сутки! Есть же offline установщик без скачивания! извиняюсь за разрешение, но только в личных целях было и в виде эксперимента, т.к. было не совсем понятно что за проблемы происходят одновременно на 2-х роутерах, с разными накопителями и файловыми системами, ладно Keenetic II старый, но Viva (KN-1910)... Беру продукцию только для возможности использования этого функционала Оффлайн установщик..... первый раз слышу. так бы воспользовался им..... можно ткнуть ссылкой? Edited April 28, 2020 by vlzsilver Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 29, 2020 Share Posted April 29, 2020 В 28.04.2020 в 18:14, zyxmon сказал: Есть же offline установщик без скачивания! В 28.04.2020 в 21:32, TheBB сказал: надо собирать заново. 23 часа назад, vlzsilver сказал: Оффлайн установщик..... первый раз слышу. так бы воспользовался им..... можно ткнуть ссылкой? mips-installer-offline.tar.gz mipsel-installer-offline.tar.gz 3 Quote Link to comment Share on other sites More sharing options...
Максим Пономаренко Posted April 30, 2020 Share Posted April 30, 2020 16 часов назад, TheBB сказал: mips-installer-offline.tar.gz mipsel-installer-offline.tar.gz Благодарю. На Extra (KN-1710) установка прошла быстро и успешно. Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 30, 2020 Share Posted April 30, 2020 3 часа назад, Максим Пономаренко сказал: На Extra (KN-1710) установка прошла быстро и успешно. Ничего удивительного ))) По сути своей, оффлайн-инсталлер - архив предустановленной системы. Из ресурсоёмких операций - генерация ключей "dropbear", остальное: установка порта (ssh - dropbear), часового пояса, строки инициализации, запуск самого "dropbear" - мелочь. ))) Quote Link to comment Share on other sites More sharing options...
Lstt Posted May 15, 2020 Share Posted May 15, 2020 Абсолютно одинаковая картина - все равно не устанавливается..( Quote Link to comment Share on other sites More sharing options...
