I'm setting up Buddy 5 KN-3311 from scratch in the "standard wi fi extender" mode. I run the setup wizard and enter all fields all fields including main WiFi SSID, authentication WPA2-PSK and a correct password. The wizard gets stuck, and traffic inspection shows it cycles between /auth and /rci both with HTTP 200. Payload of the /rci response is below.
I tried various ad-hoc ways, e.g. using WPS on both main router and the Buddy, I updated Buddy's firmware using the recovery utility to the default KeenOS 4.0 and also to 5.0.1 - nothing changes.
Siarhei Kukharenka
Dear support forum,
Would you be able to advise what's wrong?
Response of /rci
1 answer to this question
