Глюкавый USB3.0 box?
Александр Рыжов
Диск работает при подключении, однако не монтируется после перезагрузки роутера. В логе вижу следующее:
[i] Jan 1 00:00:19 ndm: kernel: Initializing USB Mass Storage driver...
[i] Jan 1 00:00:19 ndm: kernel: usbcore: registered new interface driver usb-storage
[i] Jan 1 00:00:19 ndm: kernel: USB Mass Storage support registered.
[i] Jan 1 00:00:20 ndm: kernel: usb 1-2: new full speed USB device number 2 using xhc_mtk
[i] Jan 1 00:00:20 ndm: kernel: usb 1-1: new high speed USB device number 3 using xhc_mtk
[i] Jan 1 00:00:20 ndm: kernel: scsi0 : usb-storage 1-1:1.0
[i] Jan 1 00:00:23 ndm: kernel: scsi 0:0:0:0: Direct-Access Skymedi SK7301 HDD PQ: 0 ANSI: 4
[i] Jan 1 00:00:23 ndm: kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
[i] Jan 1 00:00:23 ndm: kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[i] Jan 1 00:00:23 ndm: kernel: sd 0:0:0:0: [sda] Write Protect is off
[i] Jan 1 00:00:23 ndm: kernel: sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[i] Jan 1 00:00:23 ndm: kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
[i] Jan 1 00:00:23 ndm: kernel: sda: sda1 sda2 sda3
[i] Jan 1 00:00:23 ndm: kernel: sd 0:0:0:0: [sda] Attached SCSI disk
[i] Jan 1 00:00:35 ndm: kernel: usbcore: deregistering interface driver hub
[i] Jan 1 00:00:35 ndm: kernel: usb 1-1: USB disconnect, device number 3
[i] Jan 1 00:00:35 ndm: kernel: usb 1-2: USB disconnect, device number 2
[i] Jan 1 00:00:35 ndm: kernel: usblp0: removed
[i] Jan 1 00:00:35 ndm: kernel: hub 1-0:1.0: USB hub found
[i] Jan 1 00:00:35 ndm: kernel: hub 1-0:1.0: 2 ports detected
[i] Jan 1 00:00:35 ndm: kernel: hub 2-0:1.0: USB hub found
[i] Jan 1 00:00:35 ndm: kernel: hub 2-0:1.0: 1 port detected
[i] Jan 1 00:00:35 ndm: kernel: usbcore: registered new interface driver hub
[E] Oct 25 20:23:32 ndm: kernel: hub 1-0:1.0: unable to enumerate USB device on port 1
[i] Oct 25 20:23:32 ndm: kernel: usb 1-2: new full speed USB device number 5 using xhc_mtk
[i] Oct 25 20:23:34 ndm: kernel: usb 2-1: new SuperSpeed USB device number 4 using xhc_mtk
[i] Oct 25 20:23:34 ndm: kernel: scsi2 : usb-storage 2-1:1.0
[i] Oct 25 20:23:37 ndm: kernel: scsi 2:0:0:0: Direct-Access Skymedi SK7301 HDD PQ: 0 ANSI: 4
[i] Oct 25 20:23:37 ndm: kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
[i] Oct 25 20:23:37 ndm: kernel: sd 2:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[i] Oct 25 20:23:37 ndm: kernel: sd 2:0:0:0: [sda] Write Protect is off
[i] Oct 25 20:23:37 ndm: kernel: sd 2:0:0:0: [sda] Mode Sense: 23 00 00 00
[i] Oct 25 20:23:37 ndm: kernel: sd 2:0:0:0: [sda] Assuming drive cache: write through
[i] Oct 25 20:23:38 ndm: kernel: sda: sda1 sda2 sda3
[i] Oct 25 20:23:38 ndm: kernel: sd 2:0:0:0: [sda] Assuming drive cache: write through
[i] Oct 25 20:23:38 ndm: kernel: sd 2:0:0:0: [sda] Attached SCSI disk
[i] Oct 25 20:23:48 ndm: Core::Init: system ready.
[i] Oct 25 20:23:52 ndm: FileSystem::Ext: ext3 "1eb6acd7-e509-4427-8522-f498d8f0a39e:" filesystem initialized.
[i] Oct 25 20:23:52 ndm: kernel: EXT3-fs: barriers not enabled
[i] Oct 25 20:23:52 ndm: kernel: kjournald starting. Commit interval 5 seconds
[i] Oct 25 20:23:52 ndm: kernel: EXT3-fs (sda1): using internal journal
[i] Oct 25 20:23:52 ndm: kernel: EXT3-fs (sda1): recovery complete
[i] Oct 25 20:23:52 ndm: kernel: EXT3-fs (sda1): mounted filesystem with writeback data mode
[i] Oct 25 20:23:53 ndm: FileSystem::Ext: ext3 "a0fa194d-7b46-458a-a4c7-0e993f39e6c9:" filesystem initialized.
[i] Oct 25 20:23:53 ndm: kernel: EXT3-fs: barriers not enabled
[i] Oct 25 20:23:53 ndm: kernel: kjournald starting. Commit interval 5 seconds
[i] Oct 25 20:23:53 ndm: kernel: EXT3-fs (sda3): using internal journal
[i] Oct 25 20:23:53 ndm: kernel: EXT3-fs (sda3): recovery complete
[i] Oct 25 20:23:53 ndm: kernel: EXT3-fs (sda3): mounted filesystem with writeback data mode
[i] Oct 25 20:34:55 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:34:56 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:34:56 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:34:57 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:34:57 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:34:57 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:34:58 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:34:58 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:34:58 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:34:59 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:34:59 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:34:59 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:00 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:00 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:00 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:01 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:01 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:01 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:02 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:02 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:02 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:03 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:03 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:03 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:04 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:04 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:04 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:05 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:05 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:05 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:06 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:06 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:06 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:08 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:08 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:08 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:09 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:09 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:09 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:10 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:10 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:10 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:11 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:11 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:11 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:12 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:12 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:12 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:13 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:13 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:13 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:14 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:14 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:14 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:15 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:15 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:15 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:16 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:16 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:16 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:17 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:18 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:18 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:19 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:19 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:19 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:20 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:20 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:20 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:21 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:21 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:21 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:22 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:22 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:22 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:23 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:23 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:23 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:24 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 4 using xhc_mtk
[W] Oct 25 20:35:24 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb00
[W] Oct 25 20:35:24 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8d45eb2c
[i] Oct 25 20:35:24 ndm: kernel: sd 2:0:0:0: [sda] Unhandled error code
[i] Oct 25 20:35:24 ndm: kernel: sd 2:0:0:0: [sda] Result: hostbyte=0x07 driverbyte=0x00
[i] Oct 25 20:35:24 ndm: kernel: sd 2:0:0:0: [sda] CDB:
[i] Oct 25 20:35:24 ndm: kernel: usb 2-1: USB disconnect, device number 4
[W] Oct 25 20:35:24 ndm: kernel: cdb[0]=0x2a: 2a 00 14 de a8 40 00 00 e0 00
[E] Oct 25 20:35:24 ndm: kernel: end_request: I/O error, dev sda, sector 350136384
[E] Oct 25 20:35:24 ndm: kernel: Buffer I/O error on device sda3, logical block 43503880
[W] Oct 25 20:35:24 ndm: kernel: lost page write due to I/O error on sda3
[E] Oct 25 20:35:24 ndm: kernel: Buffer I/O error on device sda3, logical block 43503881
[E] Oct 25 20:35:24 ndm: kernel: Buffer I/O error on device sda3, logical block 43503882
[E] Oct 25 20:35:24 ndm: kernel: Buffer I/O error on device sda3, logical block 43503883
[E] Oct 25 20:35:24 ndm: kernel: Buffer I/O error on device sda3, logical block 43503884
[E] Oct 25 20:35:25 ndm: kernel: Buffer I/O error on device sda3, logical block 43503885
[W] Oct 25 20:35:25 ndm: kernel: lost page write due to I/O error on sda3
[E] Oct 25 20:35:25 ndm: kernel: Buffer I/O error on device sda3, logical block 43503886
[E] Oct 25 20:35:25 ndm: kernel: Buffer I/O error on device sda3, logical block 43503887
[E] Oct 25 20:35:25 ndm: kernel: Buffer I/O error on device sda3, logical block 43503888
[E] Oct 25 20:35:25 ndm: kernel: Buffer I/O error on device sda3, logical block 43503889
[E] Oct 25 20:35:25 ndm: kernel: Aborting journal on device sda3.
[i] Oct 25 20:35:25 ndm: kernel: sd 2:0:0:0: [sda] Unhandled error code
[i] Oct 25 20:35:25 ndm: kernel: sd 2:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
[i] Oct 25 20:35:25 ndm: kernel: sd 2:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 14 de aa 68 00 00 f0 00
[E] Oct 25 20:35:25 ndm: kernel: end_request: I/O error, dev sda, sector 350136936
[C] Oct 25 20:35:25 ndm: kernel: journal commit I/O error
[W] Oct 25 20:35:25 ndm: kernel: __journal_remove_journal_head: freeing b_committed_data
[i] Oct 25 20:35:25 ndm: FileSystem::Repository: unregistering "a0fa194d-7b46-458a-a4c7-0e993f39e6c9:" filesystem...
[C] Oct 25 20:35:25 ndm: kernel: EXT3-fs error (device sda3): ext3_find_entry: reading directory #10870785 offset 0
[W] Oct 25 20:35:25 ndm: kernel: ------------[ cut here ]------------
[W] Oct 25 20:35:25 ndm: kernel: WARNING: at fs/buffer.c:1152 mark_buffer_dirty+0x184/0x1ac()
[W] Oct 25 20:35:25 ndm: kernel: Modules linked in:
[C] Oct 25 20:35:25 ndm: kernel: EXT3-fs (sda3): error: ext3_journal_start_sb: Detected aborted journal
[C] Oct 25 20:35:25 ndm: kernel: EXT3-fs (sda3): error: remounting filesystem read-only
[E] Oct 25 20:35:25 ndm: kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
[W] Oct 25 20:35:26 ndm: kernel: Call Trace:
[W] Oct 25 20:35:26 ndm: kernel: [<8001d7c8>] dump_stack+0x8/0x34
[W] Oct 25 20:35:26 ndm: kernel: [<800384e4>] warn_slowpath_common+0x78/0xa4
[W] Oct 25 20:35:26 ndm: kernel: [<80038594>] warn_slowpath_null+0x18/0x24
[W] Oct 25 20:35:26 ndm: kernel: [<800edc10>] mark_buffer_dirty+0x184/0x1ac
[W] Oct 25 20:35:26 ndm: kernel: [] ext3_orphan_del+0xec4/0x115c [ext3]
[W] Oct 25 20:35:26 ndm: kernel: ---[ end trace 71bde1aab953f0d6 ]---
[E] Oct 25 20:35:26 ndm: kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
[i] Oct 25 20:35:26 ndm: kernel: usb 2-1: new SuperSpeed USB device number 7 using xhc_mtk
[i] Oct 25 20:35:26 ndm: kernel: scsi3 : usb-storage 2-1:1.0
[C] Oct 25 20:35:26 ndm: kernel: EXT3-fs error (device sda3): ext3_find_entry: reading directory #10870792 offset 0
[C] Oct 25 20:35:26 ndm: kernel: EXT3-fs error (device sda3): ext3_find_entry: reading directory #10870785 offset 0
[i] Oct 25 20:35:26 ndm: Core::Session: client disconnected.
[C] Oct 25 20:35:26 ndm: kernel: EXT3-fs error (device sda1): ext3_find_entry: reading directory #2 offset 0
[C] Oct 25 20:35:26 ndm: kernel: EXT3-fs (sda3): error: ext3_put_super: Couldn't clean up the journal
[i] Oct 25 20:35:26 ndm: FileSystem::Repository: unregistering "1eb6acd7-e509-4427-8522-f498d8f0a39e:" filesystem...
[C] Oct 25 20:35:27 ndm: Core::Syslog: last message repeated 3 times.
[i] Oct 25 20:35:27 ndm: kernel: scsi 3:0:0:0: Direct-Access Skymedi SK7301 HDD PQ: 0 ANSI: 4
[i] Oct 25 20:35:27 ndm: kernel: sd 3:0:0:0: Attached scsi generic sg0 type 0
[i] Oct 25 20:35:27 ndm: kernel: sd 3:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[i] Oct 25 20:35:27 ndm: kernel: sd 3:0:0:0: [sda] Write Protect is off
[i] Oct 25 20:35:27 ndm: kernel: sd 3:0:0:0: [sda] Mode Sense: 23 00 00 00
[i] Oct 25 20:35:27 ndm: kernel: sd 3:0:0:0: [sda] Assuming drive cache: write through
[i] Oct 25 20:35:58 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 7 using xhc_mtk
[W] Oct 25 20:35:58 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8a81d280
[W] Oct 25 20:35:59 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8a81d2ac
[W] Oct 25 20:36:14 ndm: kernel: xhc_mtk xhc_mtk: Timeout while waiting for address device command
[W] Oct 25 20:36:19 ndm: kernel: xhc_mtk xhc_mtk: Timeout while waiting for address device command
[E] Oct 25 20:36:19 ndm: kernel: usb 2-1: device not accepting address 7, error -62
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: Device offlined - not ready after error recovery
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] Unhandled error code
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] Result: hostbyte=0x05 driverbyte=0x00
[i] Oct 25 20:36:19 ndm: kernel: usb 2-1: USB disconnect, device number 7
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[E] Oct 25 20:36:19 ndm: kernel: end_request: I/O error, dev sda, sector 0
[W] Oct 25 20:36:19 ndm: kernel: quiet_error: 48 callbacks suppressed
[E] Oct 25 20:36:19 ndm: kernel: Buffer I/O error on device sda, logical block 0
[i] Oct 25 20:36:19 ndm: kernel: sda: unable to read partition table
[W] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] READ CAPACITY failed
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
[W] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] Sense not available.
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] Write Protect is on
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] Mode Sense: 70 9d 99 02
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] Assuming drive cache: write through
[i] Oct 25 20:36:19 ndm: kernel: sd 3:0:0:0: [sda] Attached SCSI disk
[E] Oct 25 20:36:19 ndm: Io::File: unable to read data: input/output error.
[E] Oct 25 20:36:19 ndm: Core::Syslog: last message repeated 4 times.
[W] Oct 25 20:36:19 ndm: FileSystem::Ext: "/dev/sda" has an unknown partition type, ignored.
[W] Oct 25 20:36:19 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8a81d280
[W] Oct 25 20:36:19 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8a81d2ac
[i] Oct 25 20:36:20 ndm: kernel: usb 2-1: new SuperSpeed USB device number 8 using xhc_mtk
[i] Oct 25 20:36:20 ndm: kernel: scsi4 : usb-storage 2-1:1.0
[i] Oct 25 20:36:21 ndm: kernel: usb 2-1: USB disconnect, device number 8
[i] Oct 25 20:36:21 ndm: kernel: usb 2-1: new SuperSpeed USB device number 9 using xhc_mtk
[i] Oct 25 20:36:21 ndm: kernel: scsi5 : usb-storage 2-1:1.0
[i] Oct 25 20:36:44 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 9 using xhc_mtk
[W] Oct 25 20:36:44 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c500
[W] Oct 25 20:36:44 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c52c
[i] Oct 25 20:36:54 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 9 using xhc_mtk
[W] Oct 25 20:36:54 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c500
[W] Oct 25 20:36:54 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c52c
[i] Oct 25 20:37:10 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 9 using xhc_mtk
[W] Oct 25 20:37:10 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c500
[W] Oct 25 20:37:10 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c52c
[i] Oct 25 20:37:20 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 9 using xhc_mtk
[W] Oct 25 20:37:20 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c500
[W] Oct 25 20:37:20 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c52c
[i] Oct 25 20:37:20 ndm: kernel: scsi 5:0:0:0: Device offlined - not ready after error recovery
[E] Oct 25 20:37:20 ndm: kernel: scsi 5:0:0:0: rejecting I/O to offline device
[i] Oct 25 20:37:20 ndm: kernel: scsi scan: INQUIRY result too short (5), using 36
[i] Oct 25 20:37:20 ndm: kernel: scsi 5:0:0:0: Direct-Access PQ: 0 ANSI: 0
[i] Oct 25 20:37:20 ndm: kernel: sd 5:0:0:0: Attached scsi generic sg0 type 0
[i] Oct 25 20:37:51 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 9 using xhc_mtk
[W] Oct 25 20:37:51 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c500
[W] Oct 25 20:37:51 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c52c
[i] Oct 25 20:38:01 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 9 using xhc_mtk
[W] Oct 25 20:38:01 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c500
[W] Oct 25 20:38:01 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c52c
[i] Oct 25 20:38:17 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 9 using xhc_mtk
[W] Oct 25 20:38:17 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c500
[W] Oct 25 20:38:17 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c52c
[i] Oct 25 20:38:27 ndm: kernel: usb 2-1: reset SuperSpeed USB device number 9 using xhc_mtk
[W] Oct 25 20:38:27 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c500
[W] Oct 25 20:38:27 ndm: kernel: xhc_mtk xhc_mtk: xHCI xhci_drop_endpoint called with disabled ep 8930c52c
[i] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: Device offlined - not ready after error recovery
[E] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: rejecting I/O to offline device
[W] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: [sda] Sector size 0 reported, assuming 512.
[i] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: [sda] 1 512-byte logical blocks: (512 B/512 B)
[W] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: [sda] 0-byte physical blocks
[i] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: [sda] Write Protect is off
[i] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: [sda] Mode Sense: 00 00 00 00
[i] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: [sda] Assuming drive cache: write through
[i] Oct 25 20:38:27 ndm: kernel: sd 5:0:0:0: [sda] Attached SCSI disk
[E] Oct 25 20:38:34 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Oct 25 20:38:34 ndm: FileSystem::Ext: failed to create a new filesystem.
В чём может быть дело?
3 answers to this question
Чипсет Skymedi SK7301, винт WD5000LPVX, внешнего питания нет. Проблема исчезает при переключении в WebUI порта в режим USB2.0.
На странице https://www.smartmontools.org/wiki/Supp ... SB-Devices по поводу моста есть примечание:
Very fragile, many commands don't finish correctly and/or give errors. smartctl -a, -son work, -oon, -Son, -t don't (and -a runs for a long time), so perhaps it should be "unsupported" instead.
WD Elements 2TB USB 3.0. работает в режиме USB3.0 без проблем.
