Помогите настроить L2TP/IPSec
У меня не получается настроить L2TP/IPSec соединение. Вот журнал:
Sep 03 10:33:35ndm
Network::Interface::Base: "L2TP0": interface is up.
Sep 03 10:33:35ndm
Network::Interface::Ppp: "L2TP0": disabled connection.
Sep 03 10:33:35ndm
Sep 03 10:33:35ndm
IpSec::Manager: "L2TP0": IP secure connection and keys was deleted.
Sep 03 10:33:35ndm
Network::Interface::PppTunnel: "L2TP0": remote endpoint is resolved to "91.105.238.11".
Sep 03 10:33:35ndm
Network::Interface::PppTunnel: "L2TP0": local endpoint is resolved to "10.2.48.1" (via "GigabitEthernet1").
Sep 03 10:33:35ndm
Network::Interface::PppTunnel: "L2TP0": added host route to 91.105.238.11 via 10.2.48.254 (GigabitEthernet1).
Sep 03 10:33:35ndm
Network::Interface::Base: "L2TP0": static MTU reset to default.
Sep 03 10:33:35ndm
Network::Interface::Base: "L2TP0": network MTU is 1400.
Sep 03 10:33:35ndm
Network::Interface::L2tp: "L2TP0": updating IP secure configuration.
Sep 03 10:33:35ndm
IpSec::Manager: "L2TP0": IP secure connection was added.
Sep 03 10:33:37ndm
IpSec::Manager: create IPsec reconfiguration transaction...
Sep 03 10:33:37ndm
IpSec::Manager: add config for crypto map "L2TP0".
Sep 03 10:33:37ndm
IpSec::Manager: IPsec reconfiguration transaction was created.
Sep 03 10:33:37ndm
IpSec::Configurator: start applying IPsec configuration.
Sep 03 10:33:37ndm
IpSec::Configurator: IPsec configuration applying is done.
Sep 03 10:33:37ndm
IpSec::Configurator: start reloading IKE keys task.
Sep 03 10:33:37ndm
Network::Interface::L2tp: "L2TP0": IPsec layer is down, shutdown L2TP layer.
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ndm
Sep 03 10:33:37ipsec
15[CFG] rereading secrets
15[CFG] loading secrets
15[CFG] loaded IKE secret for cmap:L2TP0
15[CFG] rereading ca certificates from '/tmp/ipsec/ipsec.d/cacerts'
15[CFG] rereading aa certificates from '/tmp/ipsec/ipsec.d/aacerts'
15[CFG] rereading ocsp signer certificates from '/tmp/ipsec/ipsec.d/ocspcerts'
15[CFG] rereading attribute certificates from '/tmp/ipsec/ipsec.d/acerts'
15[CFG] rereading crls from '/tmp/ipsec/ipsec.d/crls'
Sep 03 10:33:37ndm
IpSec::Configurator: reloading IKE keys task done.
Sep 03 10:33:37ndm
IpSec::Configurator: start reloading IPsec config task.
04[CFG] received stroke: delete connection 'L2TP0'
04[CFG] deleted connection 'L2TP0'
00[DMN] signal of type SIGHUP received. Reloading configuration
07[CFG] received stroke: add connection 'L2TP0'
00[CFG] loaded 0 entries for attr plugin configuration
07[CFG] added configuration 'L2TP0'
Sep 03 10:33:38ndm
IpSec::IpSecNetfilter: start reloading netfilter configuration...
Sep 03 10:33:38ndm
IpSec::IpSecNetfilter: netfilter configuration reloading is done.
Sep 03 10:33:38ndm
IpSec::Configurator: reloading IPsec config task done.
Sep 03 10:33:39ndm
IpSec::Configurator: crypto map "L2TP0" shutdown started.
Sep 03 10:33:39ipsec
09[CFG] received stroke: unroute 'L2TP0'
Sep 03 10:33:39ndm
04[CFG] received stroke: terminate 'L2TP0{*}'
12[IKE] closing CHILD_SA L2TP0{2} with SPIs ce1cb0f7_i (228 bytes) cddbf682_o (642 bytes) and TS 10.2.48.1/32[udp] === 91.105.238.11/32[udp/l2tp]
08[CFG] received stroke: terminate 'L2TP0[*]'
Sep 03 10:33:39ndm
IpSec::Configurator: crypto map "L2TP0" shutdown complete.
Sep 03 10:33:39ndm
IpSec::Configurator: crypto map "L2TP0" active IKE SA: 0, active CHILD SA: 0.
Sep 03 10:33:39ndm
Sep 03 10:33:39ndm
kernel: EIP93: release SPI ce1cb0f7
Sep 03 10:33:39ndm
kernel: EIP93: release SPI cddbf682
12[IKE] sending DELETE for ESP CHILD_SA with SPI ce1cb0f7
11[IKE] deleting IKE_SA L2TP0[2] between 10.2.48.1[10.2.48.1]...91.105.238.11[91.105.238.11]
11[IKE] sending DELETE for IKE_SA L2TP0[2]
Sep 03 10:33:39ndm
Sep 03 10:33:39ndm
Sep 03 10:33:39ndm
Sep 03 10:33:39ndm
Sep 03 10:33:39ndm
Sep 03 10:33:40ipsec
05[CFG] rereading secrets
05[CFG] loading secrets
05[CFG] loaded IKE secret for cmap:L2TP0
05[CFG] rereading ca certificates from '/tmp/ipsec/ipsec.d/cacerts'
05[CFG] rereading aa certificates from '/tmp/ipsec/ipsec.d/aacerts'
05[CFG] rereading ocsp signer certificates from '/tmp/ipsec/ipsec.d/ocspcerts'
05[CFG] rereading attribute certificates from '/tmp/ipsec/ipsec.d/acerts'
05[CFG] rereading crls from '/tmp/ipsec/ipsec.d/crls'
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
13[CFG] received stroke: delete connection 'L2TP0'
13[CFG] deleted connection 'L2TP0'
09[CFG] received stroke: add connection 'L2TP0'
09[CFG] added configuration 'L2TP0'
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Network::Interface::Supplicant: "L2TP0": authnentication is unchanged.
Sep 03 10:33:40ndm
Network::Interface::Base: "L2TP0": description saved.
Sep 03 10:33:40ndm
Network::Interface::Ppp: "L2TP0": peer set.
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Network::Interface::Supplicant: "L2TP0": identity is unchanged.
Sep 03 10:33:40ndm
Network::Interface::Supplicant: "L2TP0": password is unchanged.
Sep 03 10:33:40ndm
Network::Interface::IP: "L2TP0": IP address cleared.
Sep 03 10:33:40ndm
Network::Interface::Ppp: "L2TP0": remote address erased.
Sep 03 10:33:40ndm
Network::Interface::IP: "L2TP0": global priority enabled.
Sep 03 10:33:40ndm
Network::Interface::IP: "L2TP0": TCP-MSS adjustment enabled.
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Network::Interface::Secure: "L2TP0": preshared key was set.
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Network::Interface::Base: "L2TP0": schedule cleared.
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Sep 03 10:33:40ndm
Dns::InterfaceSpecific: static name server list cleared on L2TP0.
Sep 03 10:33:40ndm
Dns::Manager: name server 8.8.8.8 is disregarded while Yandex.DNS is active.
Sep 03 10:33:40ndm
Dns::Manager: name server 8.8.8.8, domain (default) deleted.
Sep 03 10:33:40ndm
Dns::InterfaceSpecific: name server 8.8.8.8 added, domain (default), interface L2TP0.
Sep 03 10:33:41ndm
Sep 03 10:33:41ndm
Sep 03 10:33:42ipsec
15[CFG] received stroke: unroute 'L2TP0'
06[CFG] received stroke: terminate 'L2TP0{*}'
06[CFG] no CHILD_SA named 'L2TP0' found
07[CFG] received stroke: terminate 'L2TP0[*]'
07[CFG] no IKE_SA named 'L2TP0' found
Sep 03 10:33:42ndm
Sep 03 10:33:42ndm
Sep 03 10:33:42ndm
Sep 03 10:33:42ndm
Sep 03 10:33:43ndm
Sep 03 10:33:43ndm
Sep 03 10:33:43ndm
Sep 03 10:33:43ipsec
11[CFG] rereading secrets
11[CFG] loading secrets
11[CFG] loaded IKE secret for cmap:L2TP0
11[CFG] rereading ca certificates from '/tmp/ipsec/ipsec.d/cacerts'
11[CFG] rereading aa certificates from '/tmp/ipsec/ipsec.d/aacerts'
11[CFG] rereading ocsp signer certificates from '/tmp/ipsec/ipsec.d/ocspcerts'
Sep 03 10:33:43ndm
11[CFG] rereading attribute certificates from '/tmp/ipsec/ipsec.d/acerts'
11[CFG] rereading crls from '/tmp/ipsec/ipsec.d/crls'
Sep 03 10:33:43ndm
05[CFG] received stroke: delete connection 'L2TP0'
05[CFG] deleted connection 'L2TP0'
15[CFG] received stroke: add connection 'L2TP0'
15[CFG] added configuration 'L2TP0'
Sep 03 10:33:43ndm
Sep 03 10:33:43ndm
Sep 03 10:33:43ndm
Sep 03 10:33:44ndm
Core::ConfigurationSaver: configuration saved.
Sep 03 10:33:45ndm
Sep 03 10:33:45ipsec
12[CFG] received stroke: unroute 'L2TP0'
11[CFG] received stroke: terminate 'L2TP0{*}'
11[CFG] no CHILD_SA named 'L2TP0' found
13[CFG] received stroke: terminate 'L2TP0[*]'
13[CFG] no IKE_SA named 'L2TP0' found
Sep 03 10:33:45ndm
Sep 03 10:33:46ipsec
09[CFG] received stroke: initiate 'L2TP0'
06[IKE] sending DPD vendor ID
06[IKE] sending FRAGMENTATION vendor ID
06[IKE] sending NAT-T (RFC 3947) vendor ID
06[IKE] sending draft-ietf-ipsec-nat-t-ike-02\n vendor ID
06[IKE] initiating Main Mode IKE_SA L2TP0[3] to 91.105.238.11
Sep 03 10:33:46ndm
IpSec::Configurator: crypto map "L2TP0" initialized.
07[IKE] received XAuth vendor ID
07[IKE] received DPD vendor ID
07[IKE] received FRAGMENTATION vendor ID
07[IKE] received NAT-T (RFC 3947) vendor ID
07[CFG] received proposals: IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#
07[CFG] configured proposals: IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536/#, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536/#, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1536/#, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#
07[CFG] selected proposal: IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#
08[IKE] found linked key for crypto map 'L2TP0'
08[IKE] local host is behind NAT, sending keep alives
10[IKE] IKE_SA L2TP0[3] established between 10.2.48.1[10.2.48.1]...91.105.238.11[91.105.238.11]
10[IKE] scheduling reauthentication in 28778s
10[IKE] maximum IKE_SA lifetime 28798s
Sep 03 10:33:46ndm
IpSec::Configurator: crypto map "L2TP0" active IKE SA: 1, active CHILD SA: 0.
11[CFG] received proposals: ESP:AES_CBC=128/HMAC_SHA1_96/#/#/NO_EXT_SEQ
11[CFG] configured proposals: ESP:AES_CBC=128/HMAC_SHA1_96/#/#/NO_EXT_SEQ, ESP:AES_CBC=256/HMAC_SHA1_96/#/#/NO_EXT_SEQ, ESP:3DES_CBC/HMAC_SHA1_96/#/#/NO_EXT_SEQ
11[CFG] selected proposal: ESP:AES_CBC=128/HMAC_SHA1_96/#/#/NO_EXT_SEQ
11[IKE] received 21474836000 lifebytes, configured 21474836480
11[IKE] CHILD_SA L2TP0{3} established with SPIs cd852ac9_i c7a83a1d_o and TS 10.2.48.1/32[udp] === 91.105.238.11/32[udp/l2tp]
Sep 03 10:33:46ndm
IpSec::Configurator: crypto map "L2TP0" is up.
Sep 03 10:33:46ndm
IpSec::Configurator: crypto map "L2TP0" active IKE SA: 1, active CHILD SA: 1.
Sep 03 10:33:46ndm
Network::Interface::L2tp: "L2TP0": IPsec layer is up, do start L2TP layer.
Sep 03 10:33:46ndm
Network::Interface::Ppp: "L2TP0": enabled connection via any interface.
Sep 03 10:33:46ndm
Sep 03 10:33:46ndm
Sep 03 10:33:48l2tp[23179]
Plugin pppol2tp.so loaded.
Sep 03 10:33:49l2tp[23179]
pppd 2.4.4-4 started by root, uid 0
Sep 03 10:33:49ndm
Sep 03 10:33:49pppd_L2TP0
l2tp_control v2.02
remote host: 91.105.238.11
local bind: 10.2.48.1
Sep 03 10:33:49ndm
kernel: EIP93: build outbound ESP connection, (SPI=c7a83a1d)
Sep 03 10:33:49ndm
kernel: EIP93: build inbound ESP connection, (SPI=cd852ac9)
Sep 03 10:33:53pppd_L2TP0
no ack, skip zlb on scccn
no ack, skip zlb on iccn
Sep 03 10:33:54ndm
kernel: Fast VPN ctrl: setup for src 91.105.238.11
Sep 03 10:33:54pppd_L2TP0
using channel 37
Using interface ppp0
Connect: ppp0 <--> l2tp[0]
Sep 03 10:34:24pppd_L2TP0
LCP: timeout sending Config-Requests
Connection terminated.
Sep 03 10:34:34pppd_L2TP0
Modem hangup
Exit.
Sep 03 10:34:34ndm
kernel: Fast VPN ctrl: release for src 91.105.238.11
Sep 03 10:34:34ndm
Service: "L2TP0": unexpectedly stopped.
Что не так? Этот VPN с сайта hidemy.name.  Я ввёл все параметры которые были указанны на сайте. В результате подключится не может.
