ownCloud - строим личное облачное хранилище
  • 2 weeks later...
basic minimal
ownCloud+lihgttpd+sqlite3
 пакеты
opkg install bzip2 curl lighttpd-mod-access lighttpd-mod-fastcgi php7-cgi php7-mod-ctype \
php7-mod-curl php7-mod-dom php7-mod-fileinfo php7-mod-gd php7-mod-iconv php7-mod-intl \
php7-mod-json php7-mod-mbstring php7-mod-pdo-sqlite php7-mod-session php7-mod-simplexml \
php7-mod-sqlite3 php7-mod-xml php7-mod-xmlreader php7-mod-xmlwriter php7-mod-zip
архив
curl https://download.owncloud.org/community/owncloud-10.6.0.tar.bz2 | \
bzip2 -cd | tar -xvC /opt/share/www/
конфиг сервера
cat > /opt/etc/lighttpd/conf.d/owncloud.conf <<EOF
server.port = 81
fastcgi.server = (
  ".php" =>
    ( "localhost" =>
      ( "socket" => "/tmp/php-fcgi.sock",
        "bin-path" => "/opt/bin/php-fcgi",
        "max-procs" => 1,
        "bin-environment" =>
          ( "PHP_FCGI_CHILDREN" => "2",
            "PHP_FCGI_MAX_REQUESTS" => "1000"
\$HTTP["url"] =~ "^/owncloud/data/" {
  url.access-deny = ("")
\$HTTP["url"] =~ "^/owncloud($|/)" {
  dir-listing.activate = "disable"
EOF
из конфига php.ini (найти и заменить)
upload_max_filesize = 100M
post_max_size = 100M
memory_limit = 32M
старт
/opt/etc/init.d/S80lighttpd start
nextcloud+lighttpd+sqlite3
 пакеты (см. пакеты для "owncloud") +
opkg install php7-mod-filter php7-mod-openssl libopenssl-conf
архив
curl https://download.nextcloud.com/server/releases/nextcloud-20.0.4.tar.bz2 | \
конфиг сервера
cat > /opt/etc/lighttpd/conf.d/nextcloud.conf <<EOF
server.port = 81
fastcgi.server = (
  ".php" =>
    ( "localhost" =>
        "max-procs" => 1,
\$HTTP["url"] =~ "^/nextcloud/data/" {
\$HTTP["url"] =~ "^/nextcloud($|/)" {
EOF
php.ini (см. для "owncloud")
старт
Edited by TheBB
fix $HTTP
  • Thanks 2
On 12/25/2020 at 1:11 PM, TheBB said:
basic minimal
  Reveal hidden contents
 пакеты
архив
конфиг сервера
server.port = 81
fastcgi.server = (
  ".php" =>
    ( "localhost" =>
        "max-procs" => 1,
EOF
memory_limit = 32M
старт
архив
конфиг сервера
server.port = 81
fastcgi.server = (
  ".php" =>
    ( "localhost" =>
        "max-procs" => 1,
EOF
старт
Сделал всё по инструкции.
При запуске появляется такое:
~ # /opt/etc/init.d/S80lighttpd start
 Starting lighttpd...              done.
~ # /opt/etc/init.d/S80lighttpd check
 Checking lighttpd...              dead.
При проверке текст такой:
~ # lighttpd -t -f /opt/etc/lighttpd/lighttpd.conf
2020-12-29 01:36:17: (../src/configfile.c.1316) source: /opt/etc/lighttpd/conf.d/nextcloud.conf line: 17 pos: 6 parser failed somehow near here: [
2020-12-29 01:36:17: (../src/configfile.c.1316) source: /opt/etc/lighttpd/lighttpd.conf line: 30 pos: 1 parser failed somehow near here: (EOL)
Помогите разобраться, спасибо.
6 часов назад, S_Michael сказал:
Выбирете что-то одно, или owncloud, или nextcloud.
  • 2 weeks later...
Только что проверил, все работает, только в шапку "Install necessary packages" необходимо добавить ещё один модуль opkg install php7-mod-filter
В 29.12.2020 в 01:46, S_Michael сказал:
Устанавливал только nextcloud. Ошибка аналогичная. Установка "чистая", только система. Модель Viva (KN-1910). Версия ОС 3.5.6
Порядок установки:
1. Пакеты (см. пакеты для "owncloud")
2. Дополнение - opkg install php7-mod-filter php7-mod-openssl libopenssl-conf
3. Архив nextcloud.
4. Конфиг сервера.
5. Редактирование php.ini
6. Запуск.
Собственно, помогите разобраться. Спасибо.
Edited by sin_s
Сам себе и отвечаю.Проблему решил.
При создании файла конфигурации в следующем фрагменте
потерялись - $HTTP
Видимо у S_Michael а была таже самая проблема.
Nextcloud запустился и работает. но медленно.
Edited by sin_s
  • Thanks 2
  • 2 weeks later...
Подскажите, пожалуйста, как прикрутить вместо sqllite mariadb?
или чем хуже sqllite?
Что значит это предупреждение?
Quote
SQLite следует использовать только для минимальных и разрабатываемых экземпляров. Для производства мы рекомендуем другую базу данных.
просто почему-то машка не хочет работать на моем asus rt-n14u.
Хотя, наверное для дома и пары юзеров этого должно ведь хватить?! Другой вопрос, как это все прикрутить к nginx? Просто он уже настроен и получены сертификаты и автоматизировано их продлевание.
Edited by evgeny1503
  • 4 weeks later...
On 5/31/2020 at 1:51 PM, m__a__l said:
Отвечу сам себе, может еще ком пригодится.
Для проброса во внешний мир через KeenDNS необходимо добавить в конфиг www/owncloud/config/config.php:
  'trusted_proxies'   => ['10.1.30.41'],
  'overwritehost'     => 'ХХХ.ХХХ.keenetic.ХХХ',
  'overwriteprotocol' => 'https',
  'overwritewebroot'  => '/owncloud',
  'overwritecondaddr' => '^10\.1\.30\.41$',
В моем случае сервер стоит на экстендере, а с мастера идет проброс домена 4-го уровня
Спасибо!
Тоже была проблема, что с облака редиректило на локальный адрес.
Очень выручили.
17 часов назад, Alexey R сказал:
Спасибо!
Очень выручили.
Кроме как посмотреть, категорически не советую мучать себя и роутер.
Я тоже этой ерундой с entware занимался, но потом сделал вывод, что я очень часто и очень много юзаю разных сервисов, которые продолжают плодиться, поэтому собрал NAS на материнке https://market.yandex.ru/product--materinskaia-plata-asrock-j4105-itx/1966804830/reviews?track=tabs
вопрос железа не принципиален, главное совместимость с хренью (xpen ology - пишется слитно)
там используется ПО мирового бренда со всеми вытекающими, даже пользователю без тех знаний можно заставить железку бегать за пивом))
поднять любой веб сервер(за исключением (но не факт) мягтоелых) не проблема, запустить виртуалки, докеры и т.п., не проблема, всё делается в пол тычки, интерфейс идеален для пользака.
Для себя сделал вывод, что в следующий раз раскошелюсь и куплю оригинальную коробку т.к. производитель похоже специально не банит ломаные версии, люди тупо начинают доверять и берут оригиналы потом.
  • 3 weeks later...
Спасибо за инструкцию, установить удалось на KN-1010 даже несмотря на то, что ранее с OPKG знаком не был.
Но работает очень медленно, что многими здесь отмечалось. Можно ли установить на роутер облако с совсем простым функциями, но что бы работало с более - менее нормальной скоростью?
  • 5 months later...
Запустил, настроил на kn-1010, спасибо TheBB за инструкцию.
Подскажите, пожалуйста, куда копать: превью картинок не грузятся, и они не открываются
В журнале куча вот таких ошибок
[index] Error: Exception: finfo::finfo(): Failed to load magic database at '(null)'. at <<closure>>
0. /opt/share/www/nextcloud/lib/private/legacy/OC_Image.php line 87
    finfo->finfo(16)
 1. /opt/share/www/nextcloud/lib/private/Preview/Image.php line 48
    OC_Image->__construct()
 2. /opt/share/www/nextcloud/lib/private/Preview/GeneratorHelper.php line 63
    OC\Preview\Image->getThumbnail(OC\Files\Node\File {}, 4096, 4096)
 3. /opt/share/www/nextcloud/lib/private/Preview/Generator.php line 244
    OC\Preview\GeneratorHelper->getThumbnail(OC\Preview\JPEG {}, OC\Files\Node\File {}, 4096, 4096)
 4. /opt/share/www/nextcloud/lib/private/Preview/Generator.php line 140
    OC\Preview\Generator->getMaxPreview(OC\Files\SimpleFS\SimpleFolder {}, OC\Files\Node\File {}, "image/jpeg", "")
 5. /opt/share/www/nextcloud/lib/private/Preview/Generator.php line 109
    OC\Preview\Generator->generatePreviews(OC\Files\Node\File {}, [{width: 1536,he ... }], "image/jpeg")
 6. /opt/share/www/nextcloud/lib/private/PreviewManager.php line 190
    OC\Preview\Generator->getPreview(OC\Files\Node\File {}, 1536, 864, false, "fill", null)
 7. /opt/share/www/nextcloud/core/Controller/PreviewController.php line 170
    OC\PreviewManager->getPreview(OC\Files\Node\File {}, 1536, 864, false, "fill")
 8. /opt/share/www/nextcloud/core/Controller/PreviewController.php line 143
    OC\Core\Controller\PreviewController->fetchPreview(OC\Files\Node\File {}, 1536, 864, true, true, "fill")
 9. /opt/share/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 169
    OC\Core\Controller\PreviewController->getPreviewByFileId(222, 1536, 864, true, true, "fill")
10. /opt/share/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 100
    OC\AppFramework\Http\Dispatcher->executeController(OC\Core\Controller\PreviewController {}, "getPreviewByFileId")
11. /opt/share/www/nextcloud/lib/private/AppFramework/App.php line 152
    OC\AppFramework\Http\Dispatcher->dispatch(OC\Core\Controller\PreviewController {}, "getPreviewByFileId")
12. /opt/share/www/nextcloud/lib/private/Route/Router.php line 308
    OC\AppFramework\App::main("OC\\Core\\Controller\\PreviewController", "getPreviewByFileId", OC\AppFramework\ ... {}, {action: null,_r ... "})
13. /opt/share/www/nextcloud/lib/base.php line 1008
    OC\Route\Router->match("/core/preview")
14. /opt/share/www/nextcloud/index.php line 37
    OC::handleRequest()
GET /nextcloud/index.php/core/preview?fileId=222&x=1536&y=864&a=true
from 127.0.0.1 by admin at 2021-08-16T08:19:08+00:00
В 16.08.2021 в 11:38, Dmitry _ сказал:
  Показать содержимое
    finfo->finfo(16)
    OC::handleRequest()
Удалил модуль php7-mod-fileinfo, и с картинками стало всё нормально. Nextcloud, конечно, теперь ругается на отсутствие модуля
  • 1 month later...
В 01.06.2016 в 02:31, TheBB сказал:
Что это такое и для чего, можно прочитать, напр., на офф сайте owncloud или wiki. Если кратко, то - персональное (личное) облачное хранилище (облако).
Размер облака ограничен "жадностью" владельца и/или объёмом диска (флешки не рассматриваются ввиду малого объёма)...
Желательно наличие swap`a (файла подкачки).
(nginx+php+mysql)
Обновить список пакетов
opkg update
(опционально) установить nano - можно вставлять текст из буфера; mc - понятно; tar - "старший брат" для распаковки
opkg install nano mc tar
Установить следующие пакеты
opkg install nginx php7-fastcgi php7-mod-ctype php7-mod-curl php7-mod-dom \
php7-mod-exif php7-mod-fileinfo php7-mod-gd php7-mod-gettext php7-mod-hash \
php7-mod-iconv php7-mod-json php7-mod-mbstring php7-mod-mcrypt php7-mod-mysql \
php7-mod-pdo php7-mod-pdo-mysql php7-mod-session php7-mod-simplexml \
php7-mod-sockets php7-mod-xml php7-mod-xmlreader php7-mod-xmlwriter php7-mod-zip \
mariadb-server mariadb-client-extra
Создать скрипт запуска S79php-fcgi и сделать его исполняемым
#!/bin/sh
export PHP_FCGI_CHILDREN=''
ENABLED=yes
PROCS=php-fcgi
ARGS="-b /opt/var/run/php-fcgi.sock &"
PREARGS=""
DESC=$PROCS
PATH=/opt/bin:/opt/sbin:/opt/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
chmod +x /opt/etc/init.d/S79php-fcgi
Отредактировать файлы: php.ini, fastcgi_params и nginx.conf
  Показать содержимое
zend.ze1_compatibility_mode = Off
; Language Options
engine = On
;short_open_tag = Off
precision    =  12
y2k_compliance = On
output_buffering = Off
;output_handler =
zlib.output_compression = Off
;zlib.output_compression_level = -1
;zlib.output_handler =
implicit_flush = Off
unserialize_callback_func =
serialize_precision = 100
;open_basedir =
disable_functions =
disable_classes =
; Colors for Syntax Highlighting mode.  Anything that's acceptable in
; <span style="color: ???????"> would work.
;highlight.string  = #DD0000
;highlight.comment = #FF9900
;highlight.keyword = #007700
;highlight.bg      = #FFFFFF
;highlight.default = #0000BB
;highlight.html    = #000000
;ignore_user_abort = On
;realpath_cache_size = 16k
;realpath_cache_ttl = 120
; Miscellaneous
expose_php = On
; Resource Limits
max_execution_time = 30    ; Maximum execution time of each script, in seconds.
max_input_time = 60    ; Maximum amount of time each script may spend parsing request data.
;max_input_nesting_level = 64
memory_limit = 32M    ; Maximum amount of memory a script may consume.
; Error handling and logging
; Error Level Constants:
; E_ALL             - All errors and warnings (includes E_STRICT as of PHP 6.0.0)
; E_ERROR           - fatal run-time errors
; E_RECOVERABLE_ERROR  - almost fatal run-time errors
; E_WARNING         - run-time warnings (non-fatal errors)
; E_PARSE           - compile-time parse errors
; E_NOTICE          - run-time notices (these are warnings which often result
;                     from a bug in your code, but it's possible that it was
;                     intentional (e.g., using an uninitialized variable and
;                     relying on the fact it's automatically initialized to an
;                     empty string)
; E_STRICT            - run-time notices, enable to have PHP suggest changes
;                     to your code which will ensure the best interoperability
;                     and forward compatibility of your code
; E_CORE_ERROR      - fatal errors that occur during PHP's initial startup
; E_CORE_WARNING    - warnings (non-fatal errors) that occur during PHP's
;                     initial startup
; E_COMPILE_ERROR   - fatal compile-time errors
; E_COMPILE_WARNING - compile-time warnings (non-fatal errors)
; E_USER_ERROR      - user-generated error message
; E_USER_WARNING    - user-generated warning message
; E_USER_NOTICE     - user-generated notice message
; E_DEPRECATED      - warn about code that will not work in future versions
;                     of PHP
; E_USER_DEPRECATED - user-generated deprecation warnings
; Common Values:
;   E_ALL & ~E_NOTICE  (Show all errors, except for notices and coding standards warnings.)
;   E_ALL & ~E_NOTICE | E_STRICT  (Show all errors, except for notices)
;   E_COMPILE_ERROR|E_RECOVERABLE_ERROR|E_ERROR|E_CORE_ERROR  (Show only errors)
;   E_ALL | E_STRICT  (Show all errors, warnings and notices including coding standards.)
; Default Value: E_ALL & ~E_NOTICE
error_reporting  =  E_ALL & ~E_NOTICE & ~E_STRICT
display_errors = On
display_startup_errors = Off
log_errors = On
log_errors_max_len = 1024
ignore_repeated_errors = Off
ignore_repeated_source = Off
report_memleaks = On
;report_zend_debug = 0
track_errors = Off
;html_errors = Off
;docref_root = "/phpmanual/"
;docref_ext = .html
;error_prepend_string = "<font color=#ff0000>"
;error_append_string = "</font>"
; Log errors to specified file.
error_log = /opt/var/log/php_errors.log
; Log errors to syslog.
;error_log = syslog
; Data Handling
;arg_separator.output = "&amp;"
;arg_separator.input = ";&"
variables_order = "EGPCS"
request_order = "GP"
register_globals = Off
register_long_arrays = Off
register_argc_argv = On
auto_globals_jit = On
post_max_size = 512M;максимальный размер файла доступный для загрузки в облакo
;magic_quotes_gpc = Off
magic_quotes_runtime = Off
magic_quotes_sybase = Off
auto_prepend_file =
auto_append_file =
default_mimetype = "text/html"
;default_charset = "iso-8859-1"
;always_populate_raw_post_data = -1
; Paths and Directories
; UNIX: "/path1:/path2"
;include_path = ".:/php/includes"
doc_root = "/opt/share/www"
user_dir =
extension_dir = "/opt/lib/php"
enable_dl = On
;cgi.force_redirect = 1
;cgi.nph = 1
;cgi.redirect_status_env = ;
cgi.fix_pathinfo = 1
;fastcgi.impersonate = 1;
;fastcgi.logging = 0
;cgi.rfc2616_headers = 0
; File Uploads
file_uploads = On
upload_tmp_dir = "/opt/tmp"
upload_max_filesize = 512M;максимальный размер файла доступный для загрузки в облако
max_file_uploads = 20
; Fopen wrappers
allow_url_fopen = On
allow_url_include = Off
;from="john@doe.com"
;user_agent="PHP"
default_socket_timeout = 60
;auto_detect_line_endings = Off
; Dynamic Extensions
;extension=ctype.so
;extension=curl.so
;extension=dom.so
;extension=exif.so
;extension=ftp.so
;extension=gd.so
;extension=gmp.so
;extension=hash.so
;extension=iconv.so
;extension=json.so
;extension=ldap.so
;extension=mbstring.so
;extension=mcrypt.so
;extension=mysql.so
;extension=openssl.so
;extension=pcre.so
;extension=pdo.so
;extension=pdo-mysql.so
;extension=pdo-pgsql.so
;extension=pdo_sqlite.so
;extension=pgsql.so
;extension=session.so
;extension=soap.so
;extension=sockets.so
;extension=sqlite.so
;extension=sqlite3.so
;extension=tokenizer.so
;extension=xml.so
;extension=xmlreader.so
;extension=xmlwriter.so
; Module Settings
[APC]
apc.enabled = 1
apc.shm_segments = 1    ;The number of shared memory segments to allocate for the compiler cache.
apc.shm_size = 4M    ;The size of each shared memory segment.
[Date]
date.timezone = Europe/Moscow ;Вставить своё расположение
;date.default_latitude = 31.7667
;date.default_longitude = 35.2333
;date.sunrise_zenith = 90.583333
;date.sunset_zenith = 90.583333
[filter]
;filter.default = unsafe_raw
;filter.default_flags =
[iconv]
;iconv.input_encoding = ISO-8859-1
;iconv.internal_encoding = ISO-8859-1
;iconv.output_encoding = ISO-8859-1
[sqlite]
;sqlite.assoc_case = 0
[sqlite3]
;sqlite3.extension_dir =
[Pdo_mysql]
pdo_mysql.cache_size = 2000
pdo_mysql.default_socket = /opt/var/run/mysqld.sock
[MySQL]
mysql.allow_local_infile = On
mysql.allow_persistent = On
mysql.max_persistent = -1
mysql.max_links = -1
mysql.default_port =
mysql.default_host =
mysql.default_user =
mysql.default_password =
mysql.connect_timeout = 60
mysql.trace_mode = Off
[PostgresSQL]
pgsql.allow_persistent = On
pgsql.auto_reset_persistent = Off
pgsql.max_persistent = -1
pgsql.max_links = -1
pgsql.ignore_notice = 0
pgsql.log_notice = 0
[Session]
session.save_handler = files
session.save_path = "/opt/tmp"
session.use_cookies = 1
;session.cookie_secure =
session.use_only_cookies = 1
session.name = PHPSESSID
session.auto_start = 0
session.cookie_lifetime = 0
session.cookie_path = /
session.cookie_domain =
session.cookie_httponly =
session.serialize_handler = php
session.gc_probability = 1
session.gc_divisor     = 100
session.gc_maxlifetime = 1440
session.bug_compat_42 = On
session.bug_compat_warn = On
session.referer_check =
session.entropy_length = 0
;session.entropy_file = /dev/urandom
;session.entropy_length = 16
session.cache_limiter = nocache
session.cache_expire = 180
session.use_trans_sid = 0
session.hash_function = 0
session.hash_bits_per_character = 4
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=,fieldset="
[mbstring]
;mbstring.language = Japanese
;mbstring.internal_encoding = EUC-JP
;mbstring.http_input = auto
;mbstring.http_output = SJIS
;mbstring.encoding_translation = Off
;mbstring.detect_order = auto
;mbstring.substitute_character = none;
;mbstring.func_overload = 0
;mbstring.strict_detection = Off
;mbstring.http_output_conv_mimetype=
;mbstring.script_encoding=
[gd]
;gd.jpeg_ignore_warning = 0
[exif]
;exif.encode_unicode = ISO-8859-15
;exif.decode_unicode_motorola = UCS-2BE
;exif.decode_unicode_intel    = UCS-2LE
;exif.encode_jis =
;exif.decode_jis_motorola = JIS
;exif.decode_jis_intel    = JIS
[soap]
soap.wsdl_cache_enabled=1
soap.wsdl_cache_dir="/opt/tmp"
soap.wsdl_cache_ttl=86400
soap.wsdl_cache_limit = 5
[sysvshm]
;sysvshm.init_mem = 10000
[ldap]
ldap.max_links = -1
[mcrypt]
;mcrypt.algorithms_dir=
;mcrypt.modes_dir=
[opcache]
;opcache.memory_consumption=8        ; 8M is the allowed minimum
;opcache.interned_strings_buffer=1
opcache.max_accelerated_files=200    ; 200 is the allowed minimum
;opcache.revalidate_freq=60
;opcache.fast_shutdown=1
opcache.enable_cli=1
opcache.enable=1
;opcache.log_verbosity_level=4
  Показать содержимое
fastcgi_param  QUERY_STRING       $query_string;
fastcgi_param  REQUEST_METHOD     $request_method;
fastcgi_param  CONTENT_TYPE       $content_type;
fastcgi_param  CONTENT_LENGTH     $content_length;
fastcgi_param  SCRIPT_FILENAME    $document_root$fastcgi_script_name;
fastcgi_param  PATH_INFO          $fastcgi_path_info;
fastcgi_param  SCRIPT_NAME        $fastcgi_script_name;
fastcgi_param  REQUEST_URI        $request_uri;
fastcgi_param  DOCUMENT_URI       $document_uri;
fastcgi_param  DOCUMENT_ROOT      $document_root;
fastcgi_param  SERVER_PROTOCOL    $server_protocol;
fastcgi_param  REQUEST_SCHEME     $scheme;
fastcgi_param  HTTPS              $https if_not_empty;
fastcgi_param  GATEWAY_INTERFACE  CGI/1.1;
fastcgi_param  SERVER_SOFTWARE    nginx/$nginx_version;
fastcgi_param  REMOTE_ADDR        $remote_addr;
fastcgi_param  REMOTE_PORT        $remote_port;
fastcgi_param  SERVER_ADDR        $server_addr;
fastcgi_param  SERVER_PORT        $server_port;
fastcgi_param  SERVER_NAME        $server_name;
# PHP only, required if PHP was built with --enable-force-cgi-redirect
fastcgi_param  REDIRECT_STATUS    200;
  Показать содержимое
user  nobody;
worker_processes  1;
#error_log  /opt/var/log/nginx/error.log;
#error_log  /opt/var/log/nginx/error.log  notice;
#error_log  /opt/var/log/nginx/error.log  info;
#pid        /opt/var/run/nginx.pid;
events {
    worker_connections  64;
http {
    include       mime.types;
    default_type  application/octet-stream;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    #access_log  /opt/var/log/nginx/access.log;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
    #gzip  on;
    server {
        listen       88;
        server_name  localhost;
        #charset koi8-r;
        #access_log  /opt/var/log/nginx/host.access.log;
    location / {
            root   /opt/share/www;
            index  index.php index.html index.htm;
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
        root   /opt/share/nginx/html;
             location = /robots.txt { allow all; access_log off; log_not_found off; }
             location = /favicon.ico { access_log off; log_not_found off; }
             location ^~ /owncloud {
                 try_files $uri $uri/ /owncloud/index.php$is_args$args;
                 client_max_body_size 512M; # максимальный размер файла для загрузки
                 location ~ ^/owncloud/(?:\.|data|config|db_structure\.xml|README) {
                deny all;
            location ~ [^/]\.php(/|$) {
            fastcgi_split_path_info   ^(.+?\.php)(/.*)$;
            if (!-f $document_root$fastcgi_script_name) {
        return 404;
                fastcgi_pass unix:/opt/var/run/php-fcgi.sock;
                fastcgi_index  index.php;
                include fastcgi_params;
                fastcgi_param MOD_X_ACCEL_REDIRECT_ENABLED on;
            location ~* \.(?:jpg|gif|ico|png|css|js|svg)$ {
                expires 30d; add_header Cache-Control public;
Скачать архив owncloud и распаковать в корень сервера (напр., так)
mkdir /opt/share/www
cd /opt/share/www
wget http://download.owncloud.org/community/owncloud-8.1.8.tar.bz2
Connecting to download.owncloud.org (188.40.68.177:80)
owncloud-8.1.8.tar.b 100% |**********(вырезано)*********| 24032k  0:00:00 ETA
tar -jxf owncloud-8.1.8.tar.bz2
Создать базу данных
mysql_install_db --datadir=/opt/var --basedir=/opt --force
Запустить mariadb-server
/opt/etc/init.d/S70mariadbd start
Задать пароль доступа
mysqladmin -u root password 'Passw0rd'
Войти и создать БД для ownCloud
mysql -u root -p
create database oc;
\q
Перезапустить mariadb-server
/opt/etc/init.d/S70mariadbd restart
Запустить php и nginx
/opt/etc/init.d/S79php-fcgi start
/opt/etc/init.d/S80nginx start
Перейти по адресу http://192.168.1.1:88/owncloud и произвести первичную настройку
 где user - имя админа облака, pass - его пароль; /opt/share/www/owncloud/data - каиалог для данных; root - имя прользователя для БД; Passw0rd - его пароль; oc - имя БД (использовались в качестве примера - указывайте свои). Если все прошло удачно, то можно увидеть
если не получилось, проверяйте где допустили ошибку.
Варианты применения: слушать музыку
смотреть мувики
работать с документами
открыть доступ соседке, а ночью просматривать ее селфи поделиться с друзьями/знакомыми, прикрутить сертификат и "выпустить" в интернеты, использовать с другим сервером и БД например  и т.д. и т.п.
"Самопальный" сертификат для подключения по https
Обновить и установить пакеты
opkg update
opkg install openssl-util
Создаём корневой ключ server.key (алгоритм шифрования aes256, длиной 4096 bit).
Cистема дважды попросит ввести парольную фразу, придумываем её, вводим и запоминаем.
openssl genrsa -aes256 -out server.key 4096
  Показать содержимое
Generating RSA private key, 4096 bit long modulus
e is 65537 (0x10001)
Enter pass phrase for server.key:
Verifying - Enter pass phrase for server.key:
Создаём корневой сертификат:
openssl req -new -key server.key -out server.csr -days 3560
  Показать содержимое
You are about to be asked to enter information that will be incorporated
into your certificate request.
What you are about to enter is what is called a Distinguished Name or a DN.
There are quite a few fields but you can leave some blank
For some fields there will be a default value,
If you enter '.', the field will be left blank.
Country Name (2 letter code) [AU]:RU
State or Province Name (full name) [Some-State]:my_territory
Locality Name (eg, city) []:my_village
Organization Name (eg, company) [Internet Widgits Pty Ltd]:Horns&Hooves
Organizational Unit Name (eg, section) []:chamber№6
Common Name (e.g. server FQDN or YOUR name) []:IP_or_DDNS
Email Address []:my@mail.ru
Please enter the following 'extra' attributes
to be sent with your certificate request
A challenge password []:passwd
An optional company name []:
Копируем ключ
cp server.key server.key.org
Удаляем пароль из ключа
openssl rsa -in server.key.org -out server.key
Генерируем сертификат
openssl x509 -req -days 3650 -in server.csr -sha384 -signkey server.key -out server.crt
  Показать содержимое
Signature ok
subject=/C=RU/ST=my_territory/L=my_village/O=Horns&Hooves/OU=chamber\xC3\xA2\xC2\x84\xC2\x966/CN=IP_or_DDNS/emailAddress=my@mail.ru
Getting Private key
Правим nginx.conf
  ssl_certificate      /opt/etc/nginx/server.crt;
  ssl_certificate_key  /opt/etc/nginx/server.key;
server {
            listen 443 ssl;
После внесения изменений в конфиг, nginx надо перезапустить, а в адресной строке для подключения к owncloud надо набрать https://ip.ad..re.ss:88/owncloud
hdd
Если нужно чтоб папка data находилась на другом диске то, носителю должна быть задана метка, он должен быть подключен и смонтирован. Проверяем командой mount, в примере ниже это флешка sdb1 с меткой data смонтированая в /tmp/mnt/
~ # mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
tmpfs on /dev type tmpfs (rw,nosuid,noexec,relatime)
none on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
/dev/mtdblock/7 on /storage type jffs2 (rw,nosuid,relatime)
none on /proc/bus/usb type usbfs (rw,nosuid,noexec,relatime)
/dev/sda1 on /tmp/mnt/omni2 type ext2 (rw,relatime)
/dev/sdb1 on /tmp/mnt/data type ext2 (rw,nosuid,noexec,noatime)
/dev/sda1 on /opt type ext2 (rw,relatime)
nfsd on /proc/fs/nfsd type nfsd (rw,relatime)
Создаем на нужном носителе папку data
mkdir /tmp/mnt/data/data
При выборе места хранения данных указываем нужный путь, в примере это /tmp/mnt/data/data
Для переноса папки data на другой диск проверяем монтирование и копируем ее (папку) в нужное место, из примера выше, так
mv /opt/share/www/owncloud/data /tmp/mnt/data/
нужно открыть и отредактировать файл /opt/share/www/owncloud/config/config.php
в файле найти строку 'datadirectory' => '/opt/share/www/owncloud/data', и изменить в ней путь до нового места хранения (из примера выше, заменить на 'datadirectory' => '/tmp/mnt/data/data')
А вы не могли бы тоже самое повторить только для 7или 8мого пхп и еще в энтваре теперь нету пхп78-мод-майскьюэл
очен6ь буду благодарен )
Edited by LizerGun
7 часов назад, LizerGun сказал:
comment=113758 или comment=61250 или... в теме было.
В 18.06.2019 в 22:11, firefly сказал:
Подскажите пожалуйста как победить ошибку nginx
помогает только /opt/etc/init.d # ./S79php-fcgi restart
В 05.10.2021 в 23:03, TheBB сказал:
да ни....ра не работает уже все перепробовал!!!!!!!! вы под старую 5тую версию про пхп конфишги выложили там уже весь синтаксис 3 раза сменился !!!!!!!!! не работает пхп !!!!!!!!! а ссылка что внизу ваще лайт хттп а не НГИНКС!
Edited by LizerGun
  • 1 month later...
Сколько место надо выделить на диске для хранилища OPKG палнирую только облако развернуть
https://help.keenetic.com/hc/ru/articles/360000948719-OPKG
И еще вопрос, в чем разница ownCloud NextCloud? что лечг будет ставить? Пока смотрю в сторону Next он вроде опен соурс
Edited by ツЛешик
Подскажите куда копать, запнулся тут
~ # mysql_install_db
Could not find plugin directory.
Will continue with "/opt/lib/mariadb/plugin".
WARNING: The host 'Cloud' could not be looked up with /opt/bin/resolveip.
This probably means that your libc libraries are not 100 % compatible
with this binary MariaDB version. The MariaDB daemon, mysqld, should work
normally with the exception that host name resolving will not work.
This means that you should use IP addresses instead of hostnames
when specifying MariaDB privileges !
mysql.user table already exists!
Run mysql_upgrade, not mysql_install_db
~ # mysqladmin -u root password '$Mega#Pixar$'
mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/opt/var/run/mysqld/mysqld.sock' (2)'
Check that mysqld is running and that the socket: '/opt/var/run/mysqld/mysqld.sock' exists!
4 часа назад, ツЛешик сказал:
А есть актуальная иснтрукция для установки?
установка пакетов mariadb
opkg install mariadb-server-extra
opkg install mariadb-client-extra
установка базы данных
mysql_install_db
запускаем сервис
/opt/etc/init.d/S70mysqld start
запускаем скрипт и отвечаем на вопросы
/opt/bin/mysql_secure_installation
входим в базу данных
mysql -u root -p ваш_пароль
создаём базу даных
create database название_базы;
выходим из базы данных
\q
нужен раздел swap на диске.
7 часов назад, Meccep45 сказал:
  Показать содержимое
mysql_install_db
запускаем сервис
создаём базу даных
\q
есть раздел, как  это связано с вопросом "А есть актуальная иснтрукция для установки?"
я инструкцию ищу актуальную на 2021
данной теме просто уже 5 лет и не понятно, что старое, что нет
вроде пробовал из 1 сообщения делать
