ownCloud - строим личное облачное хранилище
3 часа назад, ツЛешик сказал:
я инструкцию ищу актуальную на 2021
первая страница, первый пост, внизу:
Цитата
Изменено пользователем TheBB
upd
9 октября сего (2021) года, ещё новее нету.
4 часа назад, TheBB сказал:
Вроде делаю все от тутад по шагам, но как дохожу до mysql ошибки
BusyBox v1.33.1 (2021-08-22 06:41:01 UTC) built-in shell (ash)
~ # /opt/etc/init.d/S70mysqld start
~ # mysqladmin -u root password 'Passw0rd'
mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/opt/var/run/mysqld/        mysqld.sock' (2)'
Check that mysqld is running and that the socket: '/opt/var/run/mysqld/mysqld.so        ck' exists!
~ # mysql_install_db
Could not find plugin directory.
Will continue with "/opt/lib/mariadb/plugin".
WARNING: The host 'Cloud' could not be looked up with /opt/bin/resolveip.
This probably means that your libc libraries are not 100 % compatible
with this binary MariaDB version. The MariaDB daemon, mysqld, should work
normally with the exception that host name resolving will not work.
This means that you should use IP addresses instead of hostnames
when specifying MariaDB privileges !
Installing MariaDB/MySQL system tables in '/opt/var/lib/mysql' ...
2021-11-20 19:12:01 0 [ERROR] mysqld: Can't lock aria control file '/opt/var/lib        /mysql/aria_log_control' for exclusive use, error: 11. Will retry for 30 seconds
2021-11-20 19:12:32 0 [ERROR] mysqld: Got error 'Could not get an exclusive lock; file is probably in use by another process' when trying to use aria control file '/opt/var/lib/mysql/aria_log_control'
2021-11-20 19:12:32 0 [ERROR] Plugin 'Aria' init function returned error.
2021-11-20 19:12:32 0 [ERROR] Plugin 'Aria' registration as a STORAGE ENGINE failed.
2021-11-20 19:12:32 0 [Warning] InnoDB: Linux Native AIO interface is not supported on this platform. Please check your OS documentation and install appropriate binary of InnoDB.
2021-11-20 19:12:32 0 [Warning] InnoDB: Linux Native AIO disabled.
2021-11-20 19:12:32 0 [ERROR] InnoDB: mmap(134217728 bytes) failed; errno 12
2021-11-20 19:12:32 0 [ERROR] InnoDB: Cannot allocate memory for the buffer pool
2021-11-20 19:12:32 0 [ERROR] InnoDB: Database creation was aborted with error Generic error. You may need to delete the ibdata1 file before trying to start up again.
mysql_install_dbdouble free or corruption (out)
211120 19:12:32 [ERROR] mysqld got signal 6 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
To report this bug, see https://mariadb.com/kb/en/reporting-bugs
We will try our best to scrape up some info that will hopefully help
diagnose the problem, but since we have already crashed,
something is definitely wrong and this may fail.
Server version: 10.4.18-MariaDB
key_buffer_size=16777216
read_buffer_size=131072
max_used_connections=0
max_threads=153
thread_count=0
It is possible that mysqld could use up to
key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 351739 K  bytes of memory
Hope that's ok; if not, decrease some variables in the equation.
Thread pointer: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
stack_bottom = 0x0 thread_stack 0x30000
^Cmysql_install_db^C^Cmysql_install_dbmysql_install_db
6 минут назад, ツЛешик сказал:
Так вам же явно пишет,что не может найти путь....вы где-то с путями ошиблись....
40 минут назад, ツЛешик сказал:
сделал по шагам (только "mariadb"):
~ # opkg install mariadb-server mariadb-client-extra
Installing mariadb-server (10.4.18-1a) to root...
Downloading http://bin.entware.net/aarch64-k3.10/mariadb-server_10.4.18-1a_aarch64-3.10.ipk
Installing mariadb-common (1.0-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/mariadb-common_1.0-2_aarch64-3.10.ipk
Installing libaio (0.3.112-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libaio_0.3.112-2_aarch64-3.10.ipk
Installing resolveip (2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/resolveip_2_aarch64-3.10.ipk
Installing mariadb-server-base (10.4.18-1a) to root...
Downloading http://bin.entware.net/aarch64-k3.10/mariadb-server-base_10.4.18-1a_aarch64-3.10.ipk
Installing mariadb-client-extra (10.4.18-1a) to root...
Downloading http://bin.entware.net/aarch64-k3.10/mariadb-client-extra_10.4.18-1a_aarch64-3.10.ipk
Installing libedit (20210522-3.1-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libedit_20210522-3.1-1_aarch64-3.10.ipk
Installing mariadb-client-base (10.4.18-1a) to root...
Downloading http://bin.entware.net/aarch64-k3.10/mariadb-client-base_10.4.18-1a_aarch64-3.10.ipk
Installing mariadb-client (10.4.18-1a) to root...
Downloading http://bin.entware.net/aarch64-k3.10/mariadb-client_10.4.18-1a_aarch64-3.10.ipk
Configuring mariadb-common.
Configuring libedit.
Configuring mariadb-client-base.
Configuring mariadb-client.
Configuring resolveip.
Configuring libaio.
Configuring mariadb-server-base.
Configuring mariadb-server.
Configuring mariadb-client-extra.
2021-11-20 19:48:45 0 [Warning] InnoDB: Linux Native AIO interface is not supported on this platform. Please check your OS documentation and install appropriate binary of InnoDB.
2021-11-20 19:48:45 0 [Warning] InnoDB: Linux Native AIO disabled.
OK
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
Two all-privilege accounts were created.
One is root@localhost, it has no password, but you need to
be system 'root' user to connect. Use, for example, sudo mysql
The second is root@localhost, it has no password either, but
you need to be the system 'root' user to connect.
After connecting you can set the password, if you would need to be
able to connect as any of these users with a password and without sudo
See the MariaDB Knowledgebase at http://mariadb.com/kb or the
MySQL manual for more instructions.
You can start the MariaDB daemon with:
cd '/opt' ; /opt/bin/mysqld_safe --datadir='/opt/var/lib/mysql'
You can test the MariaDB daemon with mysql-test-run.pl
cd '/opt/mysql-test' ; perl mysql-test-run.pl
Please report any problems at http://mariadb.org/jira
The latest information about MariaDB is available at http://mariadb.org/.
You can find additional information about the MySQL part at:
http://dev.mysql.com
Consider joining MariaDB's strong and vibrant community:
https://mariadb.org/get-involved/
~ # /opt/etc/init.d/S70mysqld status
mysqld is already running
~ # ls -al /opt/var/run/mysqld/
drwxr-xr-x    2 root     root          4096 Nov 20 19:51 .
drwxr-xr-x    5 root     root          4096 Nov 20 19:48 ..
-rw-rw----    1 root     root             5 Nov 20 19:51 mysqld.pid
srwxrwxrwx    1 root     root             0 Nov 20 19:51 mysqld.sock
~ # mysql -u root -p
Enter password:
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 9
Server version: 10.4.18-MariaDB Source distribution
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> create database owncloud;
Query OK, 1 row affected (0.000 sec)
MariaDB [(none)]> \q
Bye
~ # /opt/etc/init.d/S70mysqld restart
drwxr-xr-x    2 root     root          4096 Nov 20 19:53 .
-rw-rw----    1 root     root             5 Nov 20 19:53 mysqld.pid
srwxrwxrwx    1 root     root             0 Nov 20 19:53 mysqld.sock
45 минут назад, TheBB сказал:
А пробелма
Ну вроде у нас логи совпадают только у меня
есть
И далее уже полшла ошибка
Я делаю все как вы описали в первом сообщений, у вас работает, у меня не поднмиается база
Чудес не бывает, есть значит какой-то нюанс, который вы не упомянули
16 минут назад, ツЛешик сказал:
Пока так
echo "192.168.1.1 Cloud" >> /etc/hosts
ping -c3 $HOSTNAME
Сделал как вы сказали хост прописал, предупреждение исчезло, но ошибка осталась
на это шаге mysql_install_db
Какой памаяти ему не хватате?
2021-11-21 21:59:50 0 [ERROR] mysqld: Out of memory (Needed 130760704 bytes)
2021-11-21 21:59:50 0 [Warning] InnoDB: Linux Native AIO interface is not supported on this platform. Please check your OS documentation and install appropriate binary of InnoDB.
2021-11-21 21:59:50 0 [Warning] InnoDB: Linux Native AIO disabled.
2021-11-21 21:59:50 0 [ERROR] InnoDB: mmap(134217728 bytes) failed; errno 12
2021-11-21 21:59:50 0 [ERROR] InnoDB: Cannot allocate memory for the buffer pool
2021-11-21 21:59:50 0 [ERROR] InnoDB: Database creation was aborted with error Generic error. You may need to delete the ibdata1 file before trying to start up again.
211121 21:59:50 [ERROR] mysqld got signal 6 ;
max_threads=153
thread_count=0
Thread pointer: 0x0
terribly wrong...
PS вопрос такой можно ли подключиться по SSH к дсику OPKG и очистить его? Полнолстью, через веб интерфейс и SMB  не получается
После заполнения админа и пароля и доступа к БД
Ловлю следуюущую ошибку
http://192.168.1.1:82/nextcloud/index.php
An error occurred.
Sorry, the page you are looking for is currently unavailable.
Please try again later.
If you are the system administrator of this resource then you should check the error log for details.
Faithfully yours, nginx.
	"reqId": "YpHQiDthBlrmObIFXRhy",
	"level": 3,
	"time": "2021-11-21T20:36:08+00:00",
	"remoteAddr": "192.168.1.10",
	"user": "--",
	"app": "PHP",
	"method": "POST",
	"url": "/nextcloud/index.php",
	"message": "Allowed memory size of 33554432 bytes exhausted (tried to allocate 4096 bytes) at /opt/share/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php#118",
	"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.114 Safari/537.36",
	"version": "22.2.3.0"
  • 2 weeks later...
  • 1 month later...
  • 1 month later...
В 20.11.2021 в 14:19, TheBB сказал:
Это нормально, что при установке db maria ругается?
Спасибо
И можно ли прикрутить к марии веб интерфейс? phpmyadmin не нашел на форуме инфо об этом
mysql_install_db
WARNING: The host 'Keenetic_Giga' could not be looked up with /opt/bin/resolveip.
2022-02-18 19:18:57 0 [Warning] InnoDB: Linux Native AIO disabled.
2022-02-18 19:19:09 0 [Warning] You need to use --log-bin to make --expire-logs-days or --binlog-expire-logs-seconds work.
OK
See the MariaDB Knowledgebase at https://mariadb.com/kb or the
Please report any problems at https://mariadb.org/jira
The latest information about MariaDB is available at https://mariadb.org/.
https://dev.mysql.com
error: 'Can't connect to local server through socket '/opt/var/run/mysqld/mysqld.sock' (2)'
Check that mariadbd is running and that the socket: '/opt/var/run/mysqld/mysqld.sock' exists!
и интерфейс не такой красивый как у вас получается
Edited by aleeko
Еще ошибки
  • 4 weeks later...
Господа, подскажите, пожалуйста:
1. Видеоплеер дает возможность выбирать разрешение?
2. По офисам (*.doc(x), *.xls(x)) возможно что-то делать?
Спасибо!
P.S. А есть альтернативы актуальные? Что-то ман для NextCloud не особо гуглится...
Edited by The_Immortal
  • 1 month later...
Подскажите пожалуйста.
Сейчас работает nginx с моим сервером и слушает порт 81 (обращаюсь 192.168.1.1:81). Где и что прописать в конфиге, чтобы и текущий сервер работал, и owncloud заработал, но при обращении на другой порт. Например 192.168.1.1:82.
Пытался править конфиг, добавить второй раздел server, перенести данные с конфига в шапке. Но наверное что-то не так сделал. Перестало вообще все работать. В том числе через консоль стало невозможно перезагрузить nginx.
Подскажете, как собрать в кучу 2 конфига? Или может кто сможет собрать 2 конфига в один?
Доброго времени суток.
Делаю все по инструкции из 1 поста, столкнулся с проблемой, не устанавливается php7-pecl-mcrypt
/ # opkg install php7-pecl-mcrypt
Unknown package 'php7-pecl-mcrypt'.
Collected errors:
 * opkg_install_cmd: Cannot install package php7-pecl-mcrypt
Его заменили? Подскажите, что использовать и что это потянет за собой?
В 01.06.2016 в 02:31, TheBB сказал:
(опционально) установить curl, nano, mc, tar
opkg install curl nano mc tar
Подскажите что не так делаю. СПС
В 28.04.2022 в 21:46, untraceab1e сказал:
php7* owrt`шники удалили полностью, в keendev он остался из-за ext-ui (или переписывать всё на php8, или кильнуть ext-ui)
Переходите на php8.
41 минуту назад, Vitalii82 сказал:
`cat /opt/etc/entware_release && cat /opt/etc/opkg.conf`
1 час назад, TheBB сказал:
Я прошу прощения "я не волшебник я только учусь" Спс за помощь.
 Share
