hellonow Posted December 6, 2017 Share Posted December 6, 2017 (edited) @ndm @Le ecureuil @Padavan Keenetic Ultra II 2.11.A.9.0-1 - поднимаем интерфейс OpenVPN via ISP (сервер взят с http://www.vpngate.net/), в начале подключения получаем ошибки Dec 6 11:25:37 ndm: Network::RoutingTable: gateway 10.211.1.46 is unreachable via OpenVPN0. [E] Dec 6 11:25:37 ndm: Network::Interface::OpenVpn: "OpenVPN0": failed to add a nameserver route. Dec 6 11:25:37 ndm: Network::Interface::OpenVpn: "OpenVPN0": adding nameserver 8.8.8.8. Dec 6 11:25:37 ndm: Dns::Manager: name server 8.8.8.8 added, domain (default). [E] Dec 6 11:25:37 ndm: Network::RoutingTable: gateway 10.211.1.46 is unreachable via OpenVPN0. [E] Dec 6 11:25:37 ndm: Network::Interface::OpenVpn: "OpenVPN0": failed to add a nameserver route. подключение проходит, все работает, резолв идет, все отлично. Далее, отключаем интерфейс OpenVPN и сразу же вылезает ошибка в логе: [E] Dec 6 11:26:04 transmissiond: Couldn't connect socket 33 to 212.220.15.228, port 11000 (errno 128 - Network is unreachable) [E] Dec 6 11:26:04 transmissiond: Couldn't connect socket 33 to 212.220.15.228, port 11000 (errno 128 - Network is unreachable) и так до бесконечности. при этом ISP подключение не становится активным. self-test ниже Edited December 6, 2017 by enpa Quote Link to comment Share on other sites More sharing options...
