Squid 4.x
пример работы (!не настроенного) "кальмара":
"удачный" запуск
~ # cat ../tmp/squid_cache.log
2017/12/15 00:39:15| Created PID file (/opt/var/run/squid.pid)
2017/12/15 00:39:15 kid1| Set Current Directory to /opt/tmp
2017/12/15 00:39:15 kid1| Starting Squid Cache version 4.0.21 for mipsel-openwrt-linux-gnu...
2017/12/15 00:39:15 kid1| Service Name: squid
2017/12/15 00:39:15 kid1| Process ID 7839
2017/12/15 00:39:15 kid1| Process Roles: worker
2017/12/15 00:39:15 kid1| With 1024 file descriptors available
2017/12/15 00:39:15 kid1| Initializing IP Cache...
2017/12/15 00:39:15 kid1| DNS Socket created at [::], FD 7
2017/12/15 00:39:15 kid1| DNS Socket created at 0.0.0.0, FD 8
2017/12/15 00:39:15 kid1| Adding nameserver 127.0.0.1 from /etc/resolv.conf
2017/12/15 00:39:15 kid1| Logfile: opening log daemon:/opt/tmp/squid_access.log
2017/12/15 00:39:15 kid1| Logfile Daemon: opening log /opt/tmp/squid_access.log
2017/12/15 00:39:15 kid1| Local cache digest enabled; rebuild/rewrite every 3600/3600 sec
2017/12/15 00:39:15 kid1| Store logging disabled
2017/12/15 00:39:15 kid1| Swap maxSize 0 + 262144 KB, estimated 20164 objects
2017/12/15 00:39:15 kid1| Target number of buckets: 1008
2017/12/15 00:39:15 kid1| Using 8192 Store buckets
2017/12/15 00:39:15 kid1| Max Mem  size: 262144 KB
2017/12/15 00:39:15 kid1| Max Swap size: 0 KB
2017/12/15 00:39:15 kid1| Using Least Load store dir selection
2017/12/15 00:39:15 kid1| Finished loading MIME types and icons.
2017/12/15 00:39:15 kid1| HTCP Disabled.
2017/12/15 00:39:15 kid1| Squid plugin modules loaded: 0
2017/12/15 00:39:15 kid1| Accepting HTTP Socket connections at local=192.168.2.1:3128 remote=[::] FD 11 flags=9
2017/12/15 00:39:16 kid1| storeLateRelease: released 0 objects
желающие могут "потыкать тушку" согласно меню(-шке) (в пределах разумного ))) )
напр., инфо
E-3x (mipsel) тут
Edited by TheBB
in repo
  • 1 year later...
Здравствуйте, @TheBB
Почему такой странный путь (/work/stable/Entware/staging_dir/target-mips_mips32r2_glibc-2.27/opt) у ключа "--with-openssl", всё это создавать?
Не работают команды:  /opt/etc/init.d/S22squid restart и  /opt/etc/init.d/S22squid stop.
Перезапускаю через kill-start.
Entware, mips, squid - 4.6-1
15 часов назад, Buha сказал:
https://github.com/openwrt/packages/blob/master/net/squid/Makefile#L107 (у меня вся сборка находится на отдельном HDD)
`stop` отрабатывает с задержкой, а `restart` - да, не работает.
~ # /opt/etc/init.d/S22squid start
 Starting squid...              done.
~ # ps | grep squid | grep -v grep
18718 root     16560 S    squid
18720 squid    20904 S    {squid} (squid-1) --kid squid-1
~ # /opt/etc/init.d/S22squid check
 Checking squid...              alive.
~ # /opt/etc/init.d/S22squid stop
 Shutting down squid...              failed.
 Checking squid...              dead.
  • 1 year later...
sorry за некропостинг, но может кому из новичков пригодится
squid.conf
shutdown_lifetime 5 seconds
 Share
