Проблема с установкой django на python 3
Пытался развернуть сабж.
Под 2.7 все установилось без ошибок, причем я смог даже разработческий сервер запустить.
При установки под 3.6 ошибки начинаются с попытки обновить pip3.
Не могли бы подсказать, что не так?
~ # opkg install python3-pip
Installing python3-pip (9.0.1) to root...
Downloading http://pkg.entware-keenetic.ru/binaries/keenle/python3-pip_9.0.1_keenle.ipk
Installing python3-setuptools (28.8.0) to root...
Downloading http://pkg.entware-keenetic.ru/binaries/keenle/python3-setuptools_28.8.0_keenle.ipk
Installing python-pip-conf (2.7.14-2) to root...
Downloading http://pkg.entware-keenetic.ru/binaries/keenle/python-pip-conf_2.7.14-2_keenle.ipk
Configuring python-pip-conf.
Configuring python3-setuptools.
Configuring python3-pip.
~ #  pip3 install --upgrade pip setuptools
Collecting pip
  Downloading pip-9.0.1-py2.py3-none-any.whl (1.3MB)
    100% |████████████████████████████████| 1.3MB 14kB/s
Collecting setuptools
  Downloading setuptools-38.4.0-py2.py3-none-any.whl (489kB)
    100% |████████████████████████████████| 491kB 37kB/s
Installing collected packages: pip, setuptools
Successfully installed pip-9.0.1 setuptools-38.4.0
Exception:
Traceback (most recent call last):
  File "/opt/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/opt/lib/python3.6/site-packages/pip/commands/install.py", line 385, in run
    requirement_set.cleanup_files()
  File "/opt/lib/python3.6/site-packages/pip/utils/build.py", line 38, in __exit__
    self.cleanup()
  File "/opt/lib/python3.6/site-packages/pip/utils/build.py", line 42, in cleanup
    rmtree(self.name)
  File "/opt/lib/python3.6/site-packages/pip/_vendor/retrying.py", line 49, in wrapped_f
    return Retrying(*dargs, **dkw).call(f, *args, **kw)
  File "/opt/lib/python3.6/site-packages/pip/_vendor/retrying.py", line 212, in call
    raise attempt.get()
  File "/opt/lib/python3.6/site-packages/pip/_vendor/retrying.py", line 247, in get
    six.reraise(self.value[0], self.value[1], self.value[2])
  File "/opt/lib/python3.6/site-packages/pip/_vendor/six.py", line 686, in reraise
    raise value
  File "/opt/lib/python3.6/site-packages/pip/_vendor/retrying.py", line 200, in call
    attempt = Attempt(fn(*args, **kwargs), attempt_number, False)
  File "/opt/lib/python3.6/site-packages/pip/utils/__init__.py", line 102, in rmtree
    onerror=rmtree_errorhandler)
  File "/shutil.py", line 480, in rmtree
  File "/shutil.py", line 402, in _rmtree_safe_fd
  File "/shutil.py", line 399, in _rmtree_safe_fd
OSError: [Errno 22] Invalid argument: '/opt/tmp/pip-build-mbm_tixd'
