VladimirTs Posted April 14, 2018 Share Posted April 14, 2018 Добрый день! не получается настроить, есть свой сервер в облаке https://azure.microsoft.com/ru-ru/resources/templates/openvpn-access-server-ubuntu/ Windows и ios работаю отлично. В кинетике ошибка. NDMS 2.12 Что не так сделано? Apr 14 12:30:47OpenVPN0 OpenVPN 2.4.4 [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [AEAD] Apr 14 12:30:47OpenVPN0 library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 Apr 14 12:30:47OpenVPN0 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead. Apr 14 12:30:47OpenVPN0 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication Apr 14 12:30:47OpenVPN0 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication Apr 14 12:30:47OpenVPN0 Socket Buffers: R=[155648->200000] S=[155648->200000] Apr 14 12:30:47OpenVPN0 UDP link local: (not bound) Apr 14 12:30:47OpenVPN0 UDP link remote: [AF_INET]11.23.174.121:1194 Apr 14 12:30:47OpenVPN0 NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay Apr 14 12:30:47OpenVPN0 TLS: Initial packet from [AF_INET]11.23.174.121:1194, sid=66224f4f d9a7ca42 Apr 14 12:30:47OpenVPN0 VERIFY SCRIPT OK: depth=1, CN=OpenVPN CA Apr 14 12:30:47OpenVPN0 VERIFY OK: depth=1, CN=OpenVPN CA Apr 14 12:30:47OpenVPN0 VERIFY OK: nsCertType=SERVER Apr 14 12:30:47OpenVPN0 VERIFY SCRIPT OK: depth=0, CN=OpenVPN Server Apr 14 12:30:47OpenVPN0 VERIFY OK: depth=0, CN=OpenVPN Server Apr 14 12:30:49ndm Core::ConfigurationSaver: configuration saved. Apr 14 12:30:50OpenVPN0 Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 2048 bit RSA Apr 14 12:30:50OpenVPN0 [OpenVPN Server] Peer Connection Initiated with [AF_INET]11.23.174.121:1194 Apr 14 12:30:50ndm Network::Interface::OpenVpn: "OpenVPN0": added host route to remote endpoint 11.23.174.121:1194 via 192.168.8.1. Apr 14 12:30:51OpenVPN0 SENT CONTROL [OpenVPN Server]: 'PUSH_REQUEST' (status=1) Apr 14 12:30:51OpenVPN0 PUSH: Received control message: 'PUSH_REPLY,explicit-exit-notify,topology subnet,route-delay 5 30,dhcp-pre-release,dhcp-renew,dhcp-release,route-metric 101,ping 12,ping-restart 50,comp-lzo yes,redirect-gateway def1,redirect-gateway bypass-dhcp,redirect-gateway autolocal,route-gateway 172.27.232.1,dhcp-option DNS 168.63.129.16,register-dns,block-ipv6,ifconfig 172.27.232.56 255.255.248.0' Apr 14 12:30:51OpenVPN0 Option 'explicit-exit-notify' in line 1 is ignored by previous <connection> blocks Apr 14 12:30:51OpenVPN0 Unrecognized option or missing or extra parameter(s) in configuration: (line 4): dhcp-pre-release (2.4.4) Apr 14 12:30:51OpenVPN0 Exiting due to fatal error Apr 14 12:30:51ndm Service: "OpenVPN0": unexpectedly stopped. Quote Link to comment Share on other sites More sharing options...
0 zyxmon Posted April 14, 2018 Share Posted April 14, 2018 На ангельском языке написано, в какой строке конфига ошибка. Удалите ее. Quote Link to comment Share on other sites More sharing options...
0 VladimirTs Posted April 14, 2018 Author Share Posted April 14, 2018 20 minutes ago, zyxmon said: На ангельском языке написано, в какой строке конфига ошибка. Удалите ее. Вот первые 4 строки из тех перед которыми нет # setenv FORWARD_COMPATIBLE 1 client server-poll-timeout 4 nobind Удаление nobind не помогает Quote Link to comment Share on other sites More sharing options...
0 zyxmon Posted April 14, 2018 Share Posted April 14, 2018 33 минуты назад, VladimirTs сказал: Вот первые 4 строки из тех перед которыми нет # Причем тут знак комментария. Quote Link to comment Share on other sites More sharing options...
0 VladimirTs Posted April 14, 2018 Author Share Posted April 14, 2018 1 hour ago, zyxmon said: Причем тут знак комментария. Тогда не понимаю где и что удалить. Там написано 4я строка, ее где искать? В каком файле конфигурации? Quote Link to comment Share on other sites More sharing options...
0 zyxmon Posted April 14, 2018 Share Posted April 14, 2018 12 минуты назад, VladimirTs сказал: Там написано 4я строка, ее где искать? В каком файле конфигурации? В том, который Вы указали-загрузили! Quote Link to comment Share on other sites More sharing options...
0 VladimirTs Posted April 14, 2018 Author Share Posted April 14, 2018 47 minutes ago, zyxmon said: В том, который Вы указали-загрузили! В кинетик был закгружено содержимое конфигурационного файла, который предоставил сервер. Четвертая сторока выглядит так: Первые строки выглядят так: # Automatically generated OpenVPN client config file # Generated on Sat Apr 14 08:32:01 2018 by openvpnas2 # Note: this config file contains inline private keys # and therefore should be kept confidential! # Note: this configuration is user-locked to the username below # OVPN_ACCESS_SERVER_USERNAME=openvpn # Define the profile name of this particular configuration file # OVPN_ACCESS_SERVER_PROFILE=openvpn@111.236.174.121/AUTOLOGIN # OVPN_ACCESS_SERVER_AUTOLOGIN=1 # OVPN_ACCESS_SERVER_CLI_PREF_ALLOW_WEB_IMPORT=True # OVPN_ACCESS_SERVER_CLI_PREF_BASIC_CLIENT=False # OVPN_ACCESS_SERVER_CLI_PREF_ENABLE_CONNECT=True # OVPN_ACCESS_SERVER_CLI_PREF_ENABLE_XD_PROXY=True # OVPN_ACCESS_SERVER_WSHOST=111.236.174.121:443 # OVPN_ACCESS_SERVER_WEB_CA_BUNDLE_START упоминания про dhcp-pre-release (2.4.4) в нем нет Quote Link to comment Share on other sites More sharing options...
0 zyxmon Posted April 14, 2018 Share Posted April 14, 2018 6 минут назад, VladimirTs сказал: упоминания про dhcp-pre-release (2.4.4) Это Вам в push сервер посылает, переконфигурируйте его. Если сервер не Ваш, читайте документацию по openvpn. Попробуйте опцию `pull-filter ignore "dhcp-pre-release"` Quote Link to comment Share on other sites More sharing options...
0 VladimirTs Posted April 14, 2018 Author Share Posted April 14, 2018 1 hour ago, zyxmon said: pull-filter ignore "dhcp-pre-release"` Помогло, спасибо. Еще есть вопрос, как сделать так чтобы через OpenVpn шел траффик только до определенных перечисленных сайтов? Quote Link to comment Share on other sites More sharing options...
0 zyxmon Posted April 14, 2018 Share Posted April 14, 2018 3 минуты назад, VladimirTs сказал: Еще есть вопрос, как сделать так чтобы через OpenVpn шел траффик только до определенных перечисленных сайтов? А что запрещает использовать поиск - 1 Quote Link to comment Share on other sites More sharing options...
0 VladimirTs Posted April 14, 2018 Author Share Posted April 14, 2018 5 hours ago, zyxmon said: А что запрещает использовать поиск - то что в поиске понятно, спасибо. загрузка файла с маршрутами не сработала. а есть пример использования rci для добавления маршрута? Quote Link to comment Share on other sites More sharing options...
0 zyxmon Posted April 15, 2018 Share Posted April 15, 2018 8 часов назад, VladimirTs сказал: спасибо. загрузка файла с маршрутами не сработала. По ссылке и не указано, про загрузку файла. Набивайте ручками или изучайте Policy Routing, если стоит прошивка, это поддерживающая. Я набрал нужные маршруты руками. Quote Link to comment Share on other sites More sharing options...
0 Станислав Степанов Posted April 23, 2018 Share Posted April 23, 2018 В 14.04.2018 в 16:17, zyxmon сказал: Попробуйте опцию `pull-filter ignore "dhcp-pre-release"` Простите за идиотский вопрос. Ситуация один в один как у автора топика. Где пробовать эту опцию pull-filter ignore "dhcp-pre-release"`?? Никак не могу взять в толк. На своей VPS развернул OpenVPN. Хочу к нему подключить роутер и никак(( Quote Link to comment Share on other sites More sharing options...
0 Sovenok Posted April 23, 2018 Share Posted April 23, 2018 40 минут назад, Станислав Степанов сказал: Простите за идиотский вопрос. Ситуация один в один как у автора топика. Где пробовать эту опцию pull-filter ignore "dhcp-pre-release"`?? Никак не могу взять в толк. На своей VPS развернул OpenVPN. Хочу к нему подключить роутер и никак(( просто уточняющий вопрос, т.е. вы установили openvpn, настроили его воспользовавшись каноничным файлом настроек для сервера\клиента из /usr/share/doc/openvpn/examples/sample-config-files ну или https://github.com/OpenVPN/openvpn/blob/master/sample/sample-config-files/server.conf и https://github.com/OpenVPN/openvpn/blob/master/sample/sample-config-files/client.conf и роутер у вас его не принял? или вы всё таки отошли от канонов и делали по какому-то шаманскому ритуалу, гайду описанного кем-то на просторах сети? Quote Link to comment Share on other sites More sharing options...
0 Le ecureuil Posted April 23, 2018 Share Posted April 23, 2018 51 минуту назад, Станислав Степанов сказал: Простите за идиотский вопрос. Ситуация один в один как у автора топика. Где пробовать эту опцию pull-filter ignore "dhcp-pre-release"`?? Никак не могу взять в толк. На своей VPS развернул OpenVPN. Хочу к нему подключить роутер и никак(( Эту опцию добавьте в свой клиентский конфиг на Keenetic, и все должно заработать. Quote Link to comment Share on other sites More sharing options...
0 Станислав Степанов Posted April 23, 2018 Share Posted April 23, 2018 (edited) 26 минут назад, Sovenok сказал: просто уточняющий вопрос, т.е. вы установили openvpn, настроили его воспользовавшись каноничным файлом настроек для сервера\клиента из /usr/share/doc/openvpn/examples/sample-config-files ну или https://github.com/OpenVPN/openvpn/blob/master/sample/sample-config-files/server.conf и https://github.com/OpenVPN/openvpn/blob/master/sample/sample-config-files/client.conf и роутер у вас его не принял? или вы всё таки отошли от канонов и делали по какому-то шаманскому ритуалу, гайду описанного кем-то на просторах сети? Я просто установил на VPS OpenVPN и ничего там не настраивал. Все настройки дефолтные. Их же и выкачал с сервера в виде client.ovpn и подставил в кинетик. С мобильных и ноута всё работает, кстати. Edited April 23, 2018 by Станислав Степанов Quote Link to comment Share on other sites More sharing options...
0 Станислав Степанов Posted April 23, 2018 Share Posted April 23, 2018 18 минут назад, Le ecureuil сказал: Эту опцию добавьте в свой клиентский конфиг на Keenetic, и все должно заработать. Добавляю и получаю Unrecognized option or missing or extra parameter(s) in configuration: (line 120): pull-filter (2.4.4) Quote Link to comment Share on other sites More sharing options...
0 zyxmon Posted April 23, 2018 Share Posted April 23, 2018 7 минут назад, Станислав Степанов сказал: Я просто установил на VPS OpenVPN и ничего там не настраивал. Все настройки дефолтные. Их же и выкачал с сервера в виде client.ovpn и подставил в кинетик. Так настройте. Читайте юзерз гада по установленной версии https://openvpn.net/index.php/open-source/documentation/manuals.html Quote Link to comment Share on other sites More sharing options...
0 Le ecureuil Posted April 24, 2018 Share Posted April 24, 2018 12 часа назад, Станислав Степанов сказал: Добавляю и получаю Unrecognized option or missing or extra parameter(s) in configuration: (line 120): pull-filter (2.4.4) Скиньте уже конфиг целиком в виде файла, возможно неправильно добавили. Quote Link to comment Share on other sites More sharing options...
0 Евгений Бессонов Posted April 24, 2018 Share Posted April 24, 2018 OpenVPN AS развернутый в ажуре. Чтобы соединение поднялось добавил pull-filter ignore "dhcp-pre-release" pull-filter ignore "dhcp-renew" pull-filter ignore "dhcp-release" pull-filter ignore "register-dns" pull-filter ignore "block-ipv6" 1 Quote Link to comment Share on other sites More sharing options...
0 Станислав Степанов Posted April 25, 2018 Share Posted April 25, 2018 21 час назад, Евгений Бессонов сказал: OpenVPN AS развернутый в ажуре. Чтобы соединение поднялось добавил pull-filter ignore "dhcp-pre-release" pull-filter ignore "dhcp-renew" pull-filter ignore "dhcp-release" pull-filter ignore "register-dns" pull-filter ignore "block-ipv6" Да. Это то, что было нужно. Добавил и все заработало. И не пришлось работающий VPN сервер зачем то перенастраивать. Quote Link to comment Share on other sites More sharing options...
0 VladimirTs Posted April 25, 2018 Author Share Posted April 25, 2018 Еще может быть полезен скрипт для добавления маршрутов Quote Link to comment Share on other sites More sharing options...
VladimirTs
Добрый день!
Что не так сделано?
21 answers to this question
