Проблема с работой Ping check. В течении суток, обязательно доходит до того, что я обнаруживаю не подключенный назад USB модем (других источников интернета нет, используется в "дыре" для видео наблюдения).
Что то конкретнее, вот отрывок лога, ниже прикрепил полный лог.
[I] Jul 25 02:17:21 ndm: PingCheck::Profile: interface CdcEthernet0 connection check failed.
[I] Jul 25 02:17:21 ndm: kernel: usb 1-2: USB disconnect, address 12
[I] Jul 25 02:17:21 ndm: kernel: eth0: unregister 'cdc_ether' usb-rt3xxx-2, CDC Ethernet Device
[I] Jul 25 02:17:21 ndm: Network::Interface::Usb: interface "CdcEthernet0" is unplugged.
[I] Jul 25 02:17:21 ndm: Network::Interface::IP: "CdcEthernet0": IP address cleared.
[I] Jul 25 02:17:21 ndm: kernel: IPv4 conntrack: flushed 0 entries with address 192.168.8.100
[I] Jul 25 02:17:21 ndm: Network::InterfaceFlusher: flushed CdcEthernet0 conntrack and route cache.
[I] Jul 25 02:17:21 ndm: Core::Session: client disconnected.
[W] Jul 25 02:17:21 ndm: Dhcp::Client: DHCP server is not responding.
[I] Jul 25 02:17:21 ndhcpc: CdcEthernet0: NDM DHCP client stopped (exit status 0).
[I] Jul 25 02:17:35 ndm: kernel: usb 1-2: new high speed USB device using rt3xxx-ehci and address 13
[I] Jul 25 02:17:35 ndm: kernel: usb 1-2: configuration #1 chosen from 1 choice
[I] Jul 25 02:17:35 ndm: kernel: scsi11 : SCSI emulation for USB Mass Storage devices
[I] Jul 25 02:17:35 ndm: kernel: usb-storage: device found at 13
[I] Jul 25 02:17:35 ndm: kernel: usb-storage: waiting for device to settle before scanning
[W] Jul 25 02:17:40 ndm: kernel: scsi 11:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[W] Jul 25 02:17:41 ndm: kernel: sr0: scsi-1 drive
[I] Jul 25 02:17:41 ndm: kernel: sr 11:0:0:0: Attached scsi CD-ROM sr0
[W] Jul 25 02:17:41 ndm: kernel: sr 11:0:0:0: Attached scsi generic sg0 type 5
[W] Jul 25 02:17:41 ndm: kernel: scsi 11:0:0:1: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[W] Jul 25 02:17:41 ndm: kernel: sd 11:0:0:1: [sda] Attached SCSI removable disk
[W] Jul 25 02:17:41 ndm: kernel: sd 11:0:0:1: Attached scsi generic sg1 type 0
[I] Jul 25 02:17:41 ndm: kernel: usb-storage: device scan complete
[I] Jul 25 02:17:44 ndm: kernel: usb 1-2: USB disconnect, address 13
[I] Jul 25 02:17:44 ndm: kernel: usb 1-2: new high speed USB device using rt3xxx-ehci and address 14
[I] Jul 25 02:17:44 ndm: kernel: usb 1-2: configuration #1 chosen from 1 choice
[I] Jul 25 02:17:45 ndm: kernel: eth0: register 'cdc_ether' at usb-rt3xxx-2, CDC Ethernet Device, 0c:5b:8f:27:9a:64
[I] Jul 25 02:17:45 ndm: kernel: scsi12 : SCSI emulation for USB Mass Storage devices
[I] Jul 25 02:17:45 ndm: kernel: usb-storage: device found at 14
[I] Jul 25 02:17:45 ndm: kernel: usb-storage: waiting for device to settle before scanning
[I] Jul 25 02:17:45 ndm: Network::Interface::Usb: interface "CdcEthernet0" is plugged (port 2).
[E] Jul 25 02:17:48 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Jul 25 02:17:48 ndm: FileSystem::Ext: failed to create a new filesystem.
[I] Jul 25 02:17:49 ndhcpc: CdcEthernet0: NDM DHCP client (version 3.1.7) started.
[W] Jul 25 02:17:50 ndm: kernel: scsi 12:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[W] Jul 25 02:17:50 ndm: kernel: sd 12:0:0:0: [sda] Attached SCSI removable disk
[W] Jul 25 02:17:50 ndm: kernel: sd 12:0:0:0: Attached scsi generic sg0 type 0
[I] Jul 25 02:17:50 ndm: kernel: usb-storage: device scan complete
[I] Jul 25 02:17:53 ndm: Dhcp::Client: configuring interface CdcEthernet0.
[I] Jul 25 02:17:53 ndm: Network::Interface::IP: "CdcEthernet0": IP address is 192.168.8.100/24.
[I] Jul 25 02:17:53 ndm: Dhcp::Client: obtained IP address 192.168.8.100/24.
[I] Jul 25 02:17:53 ndm: Dhcp::Client: interface "CdcEthernet0" is global, priority 800.
[I] Jul 25 02:17:53 ndm: Dhcp::Client: adding a default route via 192.168.8.1.
[I] Jul 25 02:17:53 ndm: Dhcp::Client: adding name server 192.168.8.1.
[I] Jul 25 02:17:53 ndm: Dns::Manager: name server 192.168.8.1 added, domain (default).
[I] Jul 25 02:17:53 ndhcpr: NDM DHCP relay stopped (exit status 0).
[I] Jul 25 02:17:53 ndm: Network::Interface::WebCaller: calling http://192.168.8.1/html/home.html.
[I] Jul 25 02:17:55 ndhcpr: NDM DHCP relay (version 3.1.7) started.
[E] Jul 25 02:17:57 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Jul 25 02:17:57 ndm: FileSystem::Ext: failed to create a new filesystem.
[I] Jul 25 02:17:58 ndm: Network::Interface::WebCaller: response: 200 (OK).
[I] Jul 25 02:17:58 ndm: Network::Interface::WebCaller: calling http://192.168.8.1/api/device/information.
[I] Jul 25 02:18:03 ndm: Network::Interface::WebCaller: response: 200 (OK).
[I] Jul 25 02:18:10 ndm: Network::Interface::WebCaller: calling http://192.168.8.1/api/user/login.
[I] Jul 25 02:18:15 ndm: Network::Interface::WebCaller: response: 200 (OK).
[I] Jul 25 02:18:44 ndm: kernel: usb 1-2: USB disconnect, address 14
[I] Jul 25 02:18:44 ndm: kernel: eth0: unregister 'cdc_ether' usb-rt3xxx-2, CDC Ethernet Device
[I] Jul 25 02:18:44 ndm: Network::Interface::Usb: interface "CdcEthernet0" is unplugged.
[I] Jul 25 02:18:44 ndm: Network::Interface::IP: "CdcEthernet0": IP address cleared.
[W] Jul 25 02:18:44 ndm: Dhcp::Client: DHCP server is not responding.
[I] Jul 25 02:18:44 ndhcpc: CdcEthernet0: NDM DHCP client stopped (exit status 0).
[I] Jul 25 02:18:59 ndm: kernel: usb 1-2: new high speed USB device using rt3xxx-ehci and address 15
[I] Jul 25 02:18:59 ndm: kernel: usb 1-2: configuration #1 chosen from 1 choice
[I] Jul 25 02:18:59 ndm: kernel: scsi13 : SCSI emulation for USB Mass Storage devices
[I] Jul 25 02:18:59 ndm: kernel: usb-storage: device found at 15
[I] Jul 25 02:18:59 ndm: kernel: usb-storage: waiting for device to settle before scanning
[W] Jul 25 02:19:04 ndm: kernel: scsi 13:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[W] Jul 25 02:19:04 ndm: kernel: sr0: scsi-1 drive
[I] Jul 25 02:19:04 ndm: kernel: sr 13:0:0:0: Attached scsi CD-ROM sr0
[W] Jul 25 02:19:04 ndm: kernel: sr 13:0:0:0: Attached scsi generic sg0 type 5
[W] Jul 25 02:19:04 ndm: kernel: scsi 13:0:0:1: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[W] Jul 25 02:19:04 ndm: kernel: sd 13:0:0:1: [sda] Attached SCSI removable disk
[W] Jul 25 02:19:04 ndm: kernel: sd 13:0:0:1: Attached scsi generic sg1 type 0
[I] Jul 25 02:19:04 ndm: kernel: usb-storage: device scan complete
[E] Jul 25 02:19:11 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Jul 25 02:19:11 ndm: FileSystem::Ext: failed to create a new filesystem.
[I] Jul 25 02:19:12 ndm: kernel: usb 1-2: usbfs: USBDEVFS_CONTROL failed cmd ndm rqt 128 rq 6 len 9 ret -145
[I] Jul 25 02:19:13 ndm: kernel: usb 1-2: usbfs: USBDEVFS_CONTROL failed cmd ndm rqt 128 rq 6 len 9 ret -145
[C] Jul 25 02:19:13 ndm: Usb::Device: system failed [0xcffd00a2], operation timed out.
[E] Jul 25 02:19:13 ndm: Usb::Device: invalid configuration descriptor: 0.
[C] Jul 25 02:19:13 ndm: Usb::Device: system failed [0xcffd00fd], output endpoint not found: unable to get configuration header.
[C] Jul 25 02:19:13 ndm: Usb::ModeSwitch: system failed [0xcffd039d].
[I] Jul 25 03:49:10 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.9.21 from 3c:cb:7c:2f:62:c9.
[I] Jul 25 03:49:10 ndhcps: _WEBADMIN: sending ACK of 192.168.9.21 to 3c:cb:7c:2f:62:c9.
[I] Jul 25 07:10:50 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.9.21 from 3c:cb:7c:2f:62:c9.
[I] Jul 25 07:10:51 ndhcps: _WEBADMIN: sending ACK of 192.168.9.21 to 3c:cb:7c:2f:62:c9.
[I] Jul 25 07:43:42 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(3c:cb:7c:2f:62:c9) had associated successfully.
[I] Jul 25 07:43:43 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(3c:cb:7c:2f:62:c9) set key done in WPA2/WPA2PSK.
[I] Jul 25 07:43:48 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_INIT) for 192.168.9.21 from 3c:cb:7c:2f:62:c9.
[I] Jul 25 07:43:48 ndhcps: _WEBADMIN: sending ACK of 192.168.9.21 to 3c:cb:7c:2f:62:c9.
[I] Jul 25 07:51:29 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(3c:cb:7c:2f:62:c9) had deauthenticated.
[I] Jul 25 07:51:36 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(3c:cb:7c:2f:62:c9) had associated successfully.
[I] Jul 25 07:51:37 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(3c:cb:7c:2f:62:c9) set key done in WPA2/WPA2PSK.
[I] Jul 25 07:51:38 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_INIT) for 192.168.9.21 from 3c:cb:7c:2f:62:c9.
[I] Jul 25 07:51:39 ndhcps: _WEBADMIN: sending ACK of 192.168.9.21 to 3c:cb:7c:2f:62:c9.
[I] Jul 25 07:54:41 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(c4:05:28:cd:68:23) had associated successfully.
[I] Jul 25 07:54:42 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(c4:05:28:cd:68:23) set key done in WPA2/WPA2PSK.
[I] Jul 25 07:54:42 ndhcps: _WEBADMIN: DHCPDISCOVER received from c4:05:28:cd:68:23.
[I] Jul 25 07:54:42 ndhcps: _WEBADMIN: making OFFER of 192.168.9.23 to c4:05:28:cd:68:23.
[I] Jul 25 07:54:42 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.9.23 from c4:05:28:cd:68:23.
[I] Jul 25 07:54:43 ndhcps: _WEBADMIN: sending ACK of 192.168.9.23 to c4:05:28:cd:68:23.
[I] Jul 25 08:10:45 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(3c:cb:7c:2f:62:c9) had deauthenticated.
[I] Jul 25 08:12:50 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(c4:05:28:cd:68:23) had disassociated.
[I] Jul 25 09:16:55 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(54:35:30:50:58:bb) had associated successfully.
[I] Jul 25 09:16:56 wmond: WifiMaster0/AccessPoint0: (RT2860) STA(54:35:30:50:58:bb) set key done in WPA2/WPA2PSK.
[I] Jul 25 09:16:56 ndhcps: _WEBADMIN: DHCPDISCOVER received for 192.168.9.20 from 54:35:30:50:58:bb.
[I] Jul 25 09:16:56 ndhcps: _WEBADMIN: making OFFER of 192.168.9.20 to 54:35:30:50:58:bb.
[I] Jul 25 09:16:56 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.9.20 from 54:35:30:50:58:bb.
[I] Jul 25 09:16:56 ndhcps: _WEBADMIN: sending ACK of 192.168.9.20 to 54:35:30:50:58:bb.
[I] Jul 25 09:20:41 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:20:41 ndm: Network::Interface::IP: "PPTP0": global priority is 1000.
[I] Jul 25 09:20:41 ndm: Network::Interface::Base: "PPTP0": description saved.
[I] Jul 25 09:20:41 ndm: Network::Interface::PPP: "PPTP0": enabled connection via any interface.
[I] Jul 25 09:20:41 ndm: Network::Interface::Secure: authnentication is unchanged.
[I] Jul 25 09:20:41 ndm: Dns::InterfaceSpecific: static name server list cleared on PPTP0.
[I] Jul 25 09:20:41 ndm: Network::Interface::Secure: identity is unchanged.
[I] Jul 25 09:20:41 ndm: Dhcp::Client: stopped DHCP client on PPTP0.
[I] Jul 25 09:20:41 ndm: Network::Interface::IP: "PPTP0": IP address cleared.
[I] Jul 25 09:20:43 pptp[18839]: Plugin pptp.so loaded.
[I] Jul 25 09:20:43 pptp[18839]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:20:46 pptp[18839]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:20:46 pptp[18839]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:20:46 pptp[18839]: Exit.
[E] Jul 25 09:20:46 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:20:46 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:20:49 pptp[18849]: Plugin pptp.so loaded.
[I] Jul 25 09:20:49 pptp[18849]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:20:52 pptp[18849]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:20:52 pptp[18849]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:20:52 pptp[18849]: Exit.
[E] Jul 25 09:20:52 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:20:52 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:20:55 pptp[18859]: Plugin pptp.so loaded.
[I] Jul 25 09:20:55 pptp[18859]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:20:58 pptp[18859]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:20:58 pptp[18859]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:20:58 pptp[18859]: Exit.
[E] Jul 25 09:20:58 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:20:58 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:01 pptp[18869]: Plugin pptp.so loaded.
[I] Jul 25 09:21:01 pptp[18869]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:02 pptp[18869]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:02 pptp[18869]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:02 pptp[18869]: Exit.
[E] Jul 25 09:21:02 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:02 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:05 pptp[18880]: Plugin pptp.so loaded.
[I] Jul 25 09:21:05 pptp[18880]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:08 pptp[18880]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:08 pptp[18880]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:08 pptp[18880]: Exit.
[E] Jul 25 09:21:08 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:08 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:11 pptp[18890]: Plugin pptp.so loaded.
[I] Jul 25 09:21:11 pptp[18890]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:14 pptp[18890]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:14 pptp[18890]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:14 pptp[18890]: Exit.
[E] Jul 25 09:21:14 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:14 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:14 ndm: PingCheck::Profile: profile "_WEBADMIN_CdcEthernet0" removed interface "CdcEthernet0".
[I] Jul 25 09:21:14 ndm: PingCheck::Client: removed "CdcEthernet0" from "_WEBADMIN_CdcEthernet0" profile.
[I] Jul 25 09:21:14 ndm: PingCheck::Client: profile "_WEBADMIN_CdcEthernet0" has been deleted.
[I] Jul 25 09:21:14 ndm: Core::ConfigurationSaver: saving configuration...
[I] Jul 25 09:21:17 pptp[18900]: Plugin pptp.so loaded.
[I] Jul 25 09:21:17 pptp[18900]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:19 ndm: Core::ConfigurationSaver: configuration saved.
[I] Jul 25 09:21:21 pptp[18900]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:21 pptp[18900]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:21 pptp[18900]: Exit.
[E] Jul 25 09:21:21 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:21 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:24 pptp[18910]: Plugin pptp.so loaded.
[I] Jul 25 09:21:24 pptp[18910]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:27 pptp[18910]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:27 pptp[18910]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:27 pptp[18910]: Exit.
[E] Jul 25 09:21:27 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:27 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:30 pptp[18920]: Plugin pptp.so loaded.
[I] Jul 25 09:21:30 pptp[18920]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:33 pptp[18920]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:33 pptp[18920]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:33 pptp[18920]: Exit.
[E] Jul 25 09:21:33 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:33 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:36 pptp[18930]: Plugin pptp.so loaded.
[I] Jul 25 09:21:36 pptp[18930]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:37 pptp[18930]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:37 pptp[18930]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:37 pptp[18930]: Exit.
[E] Jul 25 09:21:37 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:37 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:40 pptp[18940]: Plugin pptp.so loaded.
[I] Jul 25 09:21:40 pptp[18940]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:43 pptp[18940]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:43 pptp[18940]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:43 pptp[18940]: Exit.
[E] Jul 25 09:21:43 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:43 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:46 pptp[18950]: Plugin pptp.so loaded.
[I] Jul 25 09:21:46 pptp[18950]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:49 pptp[18950]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:49 pptp[18950]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:49 pptp[18950]: Exit.
[E] Jul 25 09:21:49 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:49 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:52 pptp[18960]: Plugin pptp.so loaded.
[I] Jul 25 09:21:52 pptp[18960]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:55 pptp[18960]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:55 pptp[18960]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:55 pptp[18960]: Exit.
[E] Jul 25 09:21:55 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:55 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:21:58 pptp[18970]: Plugin pptp.so loaded.
[I] Jul 25 09:21:58 pptp[18970]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:21:59 pptp[18970]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:21:59 pptp[18970]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:21:59 pptp[18970]: Exit.
[E] Jul 25 09:21:59 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:21:59 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:22:02 pptp[18980]: Plugin pptp.so loaded.
[I] Jul 25 09:22:02 pptp[18980]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:22:05 pptp[18980]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:22:05 pptp[18980]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:22:05 pptp[18980]: Exit.
[E] Jul 25 09:22:05 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:22:05 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:22:08 pptp[18990]: Plugin pptp.so loaded.
[I] Jul 25 09:22:08 pptp[18990]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:22:11 pptp[18990]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:22:11 pptp[18990]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:22:11 pptp[18990]: Exit.
[E] Jul 25 09:22:11 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:22:11 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:22:14 pptp[19000]: Plugin pptp.so loaded.
[I] Jul 25 09:22:14 pptp[19000]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:22:17 pptp[19000]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:22:17 pptp[19000]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:22:17 pptp[19000]: Exit.
[E] Jul 25 09:22:17 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:22:17 ndm: Network::Interface::Base: "PPTP0": interface is up.
[I] Jul 25 09:22:20 pptp[19010]: Plugin pptp.so loaded.
[I] Jul 25 09:22:20 pptp[19010]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4-4
[I] Jul 25 09:22:20 pptp[19010]: pppd 2.4.4-4 started by root, uid 0
[E] Jul 25 09:22:20 pptp[19010]: PPTP: connect failed (Network is unreachable)
[I] Jul 25 09:22:20 pptp[19010]: Exit.
[E] Jul 25 09:22:20 ndm: Service: "PPTP0": unexpectedly stopped.
[I] Jul 25 09:22:20 ndm: Network::Interface::Base: "PPTP0": interface is up.
Если кто знает как победить, или есть готовый пакет opkg для автоперезагрузки. Буду признателен (читал где то тут на форуме, про перезагрузку по времени, только вот общение с роутером через консоль не осилил в силу наличия лишь одной извилины, но это уже другая история).
xxxsadistxxx
Конфигурация:
Модем - Huawei E8372 (Версия ПО:21.180.07.00.00).
log.txt
3 answers to this question
