Рвет соединение с интернетом
Alex.K
Обновил прошивку на
Модель Keenetic III
Сервисный код 269-316-519-038-616
Версия NDMS v2.08(AAUU.4)C2
К роутеру подключен модем мегафон. До обновы работало все нормально.
Начал пропадать интернет на 1 мин вот лог
Oct 02 09:28:59ndmFileSystem::Ext: failed to open "/dev/sda" device to mount.
Oct 02 09:28:59ndmFileSystem::Repository: failed to create a new filesystem.
Oct 02 09:29:02ndmNetwork::Interface::WebCaller: response: 200 (OK).
Oct 02 09:29:02ndmNetwork::Interface::WebCaller: calling http://192.168.0.1/goform/goform_set_cmd_process?goformId=SET_CONNECTION_MODE&ConnectionMode=auto_dial.
Oct 02 09:29:02ndmkernel: usb0: no IPv6 routers present
Oct 02 09:29:07ndmNetwork::Interface::WebCaller: response: 200 (OK).
Oct 02 09:29:07ndmNetwork::Interface::WebCaller: calling http://192.168.0.1/goform/goform_set_cmd_process?goformId=SET_AUTO_RECONNECT_OPTION&auto_reconnect=yes.
Oct 02 09:29:12ndmNetwork::Interface::WebCaller: response: 200 (OK).
Oct 02 09:29:12ndmNetwork::Interface::WebCaller: calling http://192.168.0.1/goform/goform_get_cmd_process?multi_data=1&isTest=false&cmd=model_name%2Chardware_version%2Cwa_inner_version%2Csim_imsi%2Chplmn%2Cnetwork_provider.
Oct 02 09:29:17ndmNetwork::Interface::WebCaller: response: 200 (OK).
Oct 02 09:29:28ndmUPnP::Manager: redirect rule added: udp CdcEthernet0:50865 -> 192.168.1.40:50865.
Oct 02 09:29:28ndmUPnP::Manager: forward rule added: udp CdcEthernet0 -> 192.168.1.40:50865.
Oct 02 09:30:28ndhcps_WEBADMIN: DHCPREQUEST received (STATE_RENEWING) for 192.168.1.40 from тут мак адрес.
Oct 02 09:30:29ndhcps_WEBADMIN: sending ACK of 192.168.1.40 to тут мак адрес.
Oct 02 09:31:16ndhcps_WEBADMIN: DHCPREQUEST received (STATE_RENEWING) for 192.168.1.43 from тут мак адрес.
Oct 02 09:31:17ndhcps_WEBADMIN: sending ACK of 192.168.1.43 to тут мак адрес.
Oct 02 09:33:08ndmUPnP::Manager: redirect and forward rules deleted: udp 50865.
Oct 02 09:33:26ndmUPnP::Manager: redirect rule added: udp CdcEthernet0:50865 -> 192.168.1.40:50865.
Oct 02 09:33:26ndmUPnP::Manager: forward rule added: udp CdcEthernet0 -> 192.168.1.40:50865.
Oct 02 09:34:29ndmUPnP::Manager: redirect and forward rules deleted: udp 50865.
Oct 02 09:34:38wmondWifiMaster0/AccessPoint0: (MT76x2) STA(тут мак адрес) had associated successfully.
Oct 02 09:34:38wmondWifiMaster0/AccessPoint0: (MT76x2) STA(тут мак адрес) set key done in WPA2/WPA2PSK.
Oct 02 09:34:38ndhcps_WEBADMIN: DHCPDISCOVER received  from тут мак адрес.
Oct 02 09:34:38ndhcps_WEBADMIN: making OFFER of 192.168.1.45 to тут мак адрес.
Oct 02 09:34:38ndhcps_WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.1.45 from тут мак адрес.
Oct 02 09:34:38ndhcps_WEBADMIN: sending ACK of 192.168.1.45 to тут мак адрес.
Oct 02 09:35:04ndmUPnP::Manager: redirect rule added: udp CdcEthernet0:50865 -> 192.168.1.40:50865.
Oct 02 09:35:04ndmUPnP::Manager: forward rule added: udp CdcEthernet0 -> 192.168.1.40:50865.
Oct 02 09:36:07ndmUPnP::Manager: redirect and forward rules deleted: udp 50865.
Oct 02 09:37:04ndmUPnP::Manager: redirect rule added: udp CdcEthernet0:50865 -> 192.168.1.40:50865.
Oct 02 09:37:04ndmUPnP::Manager: forward rule added: udp CdcEthernet0 -> 192.168.1.40:50865.
Oct 02 09:38:07ndmUPnP::Manager: redirect and forward rules deleted: udp 50865.
Oct 02 09:39:03ndhcps_WEBADMIN: DHCPREQUEST received (STATE_RENEWING) for 192.168.1.39 from тут мак адрес.
Oct 02 09:39:03ndhcps_WEBADMIN: sending ACK of 192.168.1.39 to тут мак адрес.
Oct 02 09:39:24ndmUPnP::Manager: redirect rule added: udp CdcEthernet0:50865 -> 192.168.1.40:50865.
Oct 02 09:39:24ndmUPnP::Manager: forward rule added: udp CdcEthernet0 -> 192.168.1.40:50865.
Oct 02 09:40:27ndmUPnP::Manager: redirect and forward rules deleted: udp 50865.
Oct 02 09:40:39ndhcps_WEBADMIN: DHCPREQUEST received (STATE_RENEWING) for 192.168.1.100 from тут мак адрес.
Oct 02 09:40:40ndhcps_WEBADMIN: sending ACK of 192.168.1.100 to тут мак адрес.
Oct 02 09:41:51ndmUPnP::Manager: redirect rule added: udp CdcEthernet0:50865 -> 192.168.1.40:50865.
Oct 02 09:41:51ndmUPnP::Manager: forward rule added: udp CdcEthernet0 -> 192.168.1.40:50865.
Oct 02 09:42:54ndmUPnP::Manager: redirect and forward rules deleted: udp 50865.
Oct 02 09:44:57ndmUPnP::Manager: redirect rule added: udp CdcEthernet0:50865 -> 192.168.1.40:50865.
Oct 02 09:44:57ndmUPnP::Manager: forward rule added: udp CdcEthernet0 -> 192.168.1.40:50865.
[/guote]
11 answers to this question
В 02.10.2018 в 11:50, Alex.K сказал:
Сейчас увидел такое в журнале
Oct 02 11:48:59ndm
Core::Ndss: cannot connect to the server.
Это значит, что доступа в Интернет нет.
А вообще попробуйте на legacy. 2.08 слишком стара.
25 минут назад, Le ecureuil сказал:
Устнановлена последняя прошивка для моей модели
Только что, Alex.K сказал:
Спасибо но моего там нет Keenetic III Rev A
А здесь?
Цитата
Версия 2.09 (журнал изменений), 2.10 (журнал изменений), 2.11 (журнал изменений) — неофициальная:
  • Keenetic Lite II
  • Keenetic Lite III
  • Keenetic Omni
  • Keenetic Omni II
  • Keenetic II
  • Keenetic III
  • Keenetic Giga II
  • Keenetic Ultra
  • Keenetic LTE
  • Keenetic DSL
  • Keenetic VOX
И здесь:
Цитата
Для Keenetic III прошивки есть, draft, legacy.
1 минуту назад, Alex.K сказал:
in_rb_delta_2.11.B.1.0-0.bin                       26-Feb-2018 06:54             9175100
Буква B  это Rev B ? С A Свежую не нашел
B - это версия прошивки и к ревизии роутера не имеет отношения.
Edited by AndreBA
Только что, AndreBA сказал:
Значит я могу ее поставить на свой кинетик?
Вам предложили перейти на "legacy". В CLI введите команды:
> components list legacy
> components commit
А если хотите "delta" то да.
В любом случае сохраните для себя действующую прошивку и кофиг-файл, для отката(вдруг что то не понравится).
5 минут назад, AndreBA сказал:
> components commit
Обновил, проверим) Спасибо!
