Конфигурирование L2TP/IPsec
Есть роутер Giga 3 с прошивкой  v2.08(AAUW.3)A. Хочу подключить его к сервису hideme. Вроде все данные  которые выдал сервис я ввёл. Однако не хочет подключатся.  Данные вводились на вкладке интернет-PPPoE/VPN. Вот что в журнале:
IpSec::Configurator: reconnecting IPsec crypto map "L2TPoverIPsec0".
Sep 18 10:56:52ndm
IpSec::Configurator: start shutting down IPsec crypto map "L2TPoverIPsec0" task.
Sep 18 10:56:52ipsec
14[CFG] received stroke: unroute 'L2TPoverIPsec0'
Sep 18 10:56:53ipsec
08[CFG] received stroke: terminate 'L2TPoverIPsec0{*}'
08[CFG] no CHILD_SA named 'L2TPoverIPsec0' found
05[CFG] received stroke: terminate 'L2TPoverIPsec0[*]'
09[IKE] deleting IKE_SA L2TPoverIPsec0[76] between 192.168.0.125[192.168.0.125]...91.221.66.60[91.221.66.60]
09[IKE] sending DELETE for IKE_SA L2TPoverIPsec0[76]
Sep 18 10:56:54ndm
IpSec::Configurator: shutting down IPsec crypto map "L2TPoverIPsec0" task done.
Sep 18 10:56:54ndm
IpSec::Configurator: start initiating IPsec crypto map "L2TPoverIPsec0" task.
Sep 18 10:56:54ipsec
13[CFG] received stroke: initiate 'L2TPoverIPsec0'
12[IKE] sending DPD vendor ID
12[IKE] sending NAT-T (RFC 3947) vendor ID
12[IKE] sending draft-ietf-ipsec-nat-t-ike-02\n vendor ID
12[IKE] initiating Main Mode IKE_SA L2TPoverIPsec0[77] to 91.221.66.60
16[IKE] received XAuth vendor ID
16[IKE] received DPD vendor ID
16[IKE] received NAT-T (RFC 3947) vendor ID
16[CFG] received proposals: IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#
16[CFG] configured proposals: IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#, IKE:AES_CBC=256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048/#, IKE:AES_CBC=128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#
16[CFG] selected proposal: IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024/#
06[IKE] linked key for crypto map 'L2TPoverIPsec0' is not found, still searching
06[IKE] local host is behind NAT, sending keep alives
11[IKE] IKE_SA L2TPoverIPsec0[77] established between 192.168.0.125[192.168.0.125]...91.221.66.60[91.221.66.60]
11[IKE] scheduling reauthentication in 28780s
11[IKE] maximum IKE_SA lifetime 28800s
Sep 18 10:56:54ndm
IpSec::Configurator: initiating IPsec crypto map "L2TPoverIPsec0" task done.
Sep 18 10:56:55ipsec
10[IKE] received NO_PROPOSAL_CHOSEN error notify
Sep 18 10:56:55ndm
IpSec::Configurator: remote peer of crypto map "L2TPoverIPsec0" returned proposal mismatch for IPsec phase 2.
Sep 18 10:56:55ndm
IpSec::Configurator: fallback peer is not defined for IPsec crypto map "L2TPoverIPsec0", retry.
Sep 18 10:56:55ndm
Network::Interface::L2TPSecure: "L2TPoverIPsec0": IP secure layer is down, shutdown L2TP layer.
Sep 18 10:56:55ndm
Network::Interface::PPP: "L2TPoverIPsec0": disabled connection.
Sep 18 10:56:55ndm
IpSec::Configurator: schedule reconnect for IPsec crypto map "L2TPov
Что не так?
Клиент L2TP over IPsec в кинетиках поддерживает только AES-128 CBC, и, насколько я помню, настроить это до сих пор невозможно. Вероятно, сервер ожидает иной способ шифрования, либо иной алгоритм аутентификации. Если на стороне сервера можно настраивать параметры, то установите алгоритм аутентификации SHA1 и шифрование AES-128 CBC.
Edited by vadimbn
Функция активно переделывается в настоящий момент, ждите пока сделаем новую реализацию.
Заодно можете скидывать примеры сервисов, совместимость с которыми вам была бы нужна и на которых стоит тестировать - попробуем реализовать, если выйдет.
@Le ecureuil L2TP/IPsec будет только клиент или и сервер?
В новой ios 10 возможность завернуть все данные в тоннель есть только для данного типа подключения. Для ipsec и ike v2 эта настройка отсутсвует.
Пока планируем только Cisco IPsec. В нем трафик тоже весь по идее должен заворачиваться в туннель. Можете оценить в соседних темах. Про сервер L2TP/IPsec пока речи не идет, нам бы клиента довести до ума и реализа.
